dvsarwate <dvsarwate@yahoo.com> writes:> On Apr 20, 11:44 am, Tim Wescott <t...@seemywebsite.com> wrote:[snip]> For the specific case > brought up by the OP, the probability density function of > theta is > > exp(-1/(2*sigma^2)) > + cos(theta)/(2*sigma*sqrt{2 pi}*[1 + erf{cos(theta)/ > (sigma*sqrt{2})}]*exp(-sin^2(theta)/(2*sigma^2) > > for theta between -pi and +pi, and the OP needs to compute > E[cos(theta)] via LOTUS from this pdf. Numerical evaluation > of the integral is likely to be easier than trying to evaluate it > analytically, though giving it to Mathematica or Maple is > probably worthwhile. I am sure that someone has computed an > analytical expression already or a good approximation thereof.I was unable to make sense of your expression since the parentheses don't match, and simply closing them didn't seem to work out numerically. (I might have done something wrong.) Anyway, I had my own expression which differed somewhat from yours. Fortunately, the messiest term in the expression collapsed to zero upon definite integration due to symmetries and I was able to find the following closed form solution. (I used Mathematica, but it needed a lot of help from me to get this.): Let q = 1/(2*sigma) then the expected value of the original poster's expression is: sqrt(pi/2) * q * exp(-q^2) * (I_0(q^2)+I_1(q^2)) where I_n is the Modified Bessel function of the first kind. see: http://mathworld.wolfram.com/ModifiedBesselFunctionoftheFirstKind.html The original poster's approximation function is: 1 / sqrt(1+2*sigma^2) This function shares some similarities with the actual solution: 1. The series expansion at sigma=0 looks like 1-sigma^2, while the solution looks like 1-sigma^2/2. So they agree on the function value and the first derivative. 2. The series expansion at sigma=infinity looks like 1/sqrt(2)*1/sigma, while the solution looks like sqrt(pi/8)*1/sigma. So as sigma goes to infinity, they both go like 1/sigma, with the coefficient of the approximation being about 0.707 and the coefficient of the solution being about 0.627. So it works out that the minimum error is -0.0345375 at sigma = 0.384517 and the maximum error is 0.0307944 at sigma = 1.61243. Not too bad for absolute error.> >> I'm also not sure that it's wise to pull trigonometry back into the >> problem once you've gotten rid of it, unless the aim is just to better >> visualize the problem to help you along to a solution. > > Different strokes for different folks.... Best of luck trying to > simplify your > >>expression in the rectilinear variables >>along with a bunch of operations against constants. >>Unfortunately there's a radical and more than one >>fraction involvedAs you did, I brought trigonometry back into the problem to eliminate the radical. Scott -- Scott Hemphill hemphill@alumni.caltech.edu "This isn't flying. This is falling, with style." -- Buzz Lightyear
Proof for Expected Value Problem
Started by ●April 18, 2011
Reply by ●April 22, 20112011-04-22
On Apr 22, 4:07�pm, Scott Hemphill <hemph...@hemphills.net> wrote:> > > exp(-1/(2*sigma^2)) > > + cos(theta)/(2*sigma*sqrt{2 pi}*[1 + erf{cos(theta)/ > > (sigma*sqrt{2})}]*exp(-sin^2(theta)/(2*sigma^2)> > I was unable to make sense of your expression since the parentheses > don't match, and simply closing them didn't seem to work out > numerically.I think it was supposed to be exp{-1/(2*sigma^2)}/(2*pi) + cos(theta)/(2*sigma*sqrt{2 pi})*[1 + erf{cos(theta)/ (sigma*sqrt{2})}]*exp{-sin^2(theta)/(2*sigma^2)} but I don't guarantee parsing of this one either. Thanks for your careful reading of this stuff. --Dilip Sarwate
Reply by ●April 23, 20112011-04-23
dvsarwate <dvsarwate@yahoo.com> writes:> On Apr 22, 4:07 pm, Scott Hemphill <hemph...@hemphills.net> wrote: > >> >> > exp(-1/(2*sigma^2)) >> > + cos(theta)/(2*sigma*sqrt{2 pi}*[1 + erf{cos(theta)/ >> > (sigma*sqrt{2})}]*exp(-sin^2(theta)/(2*sigma^2) > >> >> I was unable to make sense of your expression since the parentheses >> don't match, and simply closing them didn't seem to work out >> numerically. > > I think it was supposed to be > > exp{-1/(2*sigma^2)}/(2*pi) > + cos(theta)/(2*sigma*sqrt{2 pi})*[1 + erf{cos(theta)/ > (sigma*sqrt{2})}]*exp{-sin^2(theta)/(2*sigma^2)} > > but I don't guarantee parsing of this one either. Thanks > for your careful reading of this stuff.Yes, that works. So you multiply by cos(theta) and integrate theta between -Pi and Pi. The great thing is that the term with erf(...) drops out during the integration, giving you the same result I posted earlier. Scott -- Scott Hemphill hemphill@alumni.caltech.edu "This isn't flying. This is falling, with style." -- Buzz Lightyear
Reply by ●April 26, 20112011-04-26
>dvsarwate <dvsarwate@yahoo.com> writes: > >> On Apr 22, 4:07 pm, Scott Hemphill <hemph...@hemphills.net> wrote: >> >>> >>> > exp(-1/(2*sigma^2)) >>> > + cos(theta)/(2*sigma*sqrt{2 pi}*[1 + erf{cos(theta)/ >>> > (sigma*sqrt{2})}]*exp(-sin^2(theta)/(2*sigma^2) >> >>> >>> I was unable to make sense of your expression since the parentheses >>> don't match, and simply closing them didn't seem to work out >>> numerically. >> >> I think it was supposed to be >> >> exp{-1/(2*sigma^2)}/(2*pi) >> + cos(theta)/(2*sigma*sqrt{2 pi})*[1 + erf{cos(theta)/ >> (sigma*sqrt{2})}]*exp{-sin^2(theta)/(2*sigma^2)} >> >> but I don't guarantee parsing of this one either. Thanks >> for your careful reading of this stuff. > >Yes, that works. So you multiply by cos(theta) and integrate theta >between -Pi and Pi. The great thing is that the term with erf(...) >drops out during the integration, giving you the same result I posted >earlier. > >Scott >-- >Scott Hemphill hemphill@alumni.caltech.edu >"This isn't flying. This is falling, with style." -- Buzz Lightyear >Thank you guys for your answers, I appreciate very much your effort. I also tried to find the theoretical expected value by using the p.d.f. suggested by Dilip (multiplying by cos(theta) and integrating between -pi and pi), arriving at Scott's expression: sqrt(pi/2) * q * exp(-q^2) * (I_0(q^2)+I_1(q^2)), with q = 1/(2*sigma) As commented by Scott, it seems that the approximation I found empirically fits quite well the "real" expected value. However, I am a bit dissappointed for not having found a simpler explanation. I expected that, under some theoretical assumption, the real expected value would boil down to the approximated expression. Best regards, maco
