On 04/25/2011 03:27 AM, dhaval_shah wrote:> I got some idea, poles are considered bcoz real part of the poses are > placed as a damping factor when u perform inverse Z-Transform.You're confusing the z transform and the Laplace transform. In the _Laplace_ transform the real parts of the poles determine how rapidly they damp out (but are different from the damping factor). In the z domain it's the magnitude of the pole -- a pole with magnitude greater than 1 is unstable, one with magnitude equal to one is metastable, and one with magnitude less than one is stable. The lower the pole amplitude, the more rapidly it damps out. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
Z-Transform
Started by ●April 21, 2011
Reply by ●April 25, 20112011-04-25
On Apr 21, 2:56�pm, Tim Wescott <t...@seemywebsite.com> wrote:> On 04/21/2011 11:35 AM, dhaval_shah wrote: > > > What is the role of "zeros" in deciding the stability of the system? > > why only "poles" are being used to decide the stability of the system? > > See http://www.wescottdesign.com/articles/zTransform/z-transforms.html . >just to add to Tim's response. The main mathematical reason that the pole loci exclusively determine the stability of the system is because of partial fraction expansion. Note Eqs (17) and (20) in Tim's document. Even though it's X(z), not H(z) (the transfer function), the principle is the same. The factors in the denominator of X(z) in Eq (17) are the same as the little denominators in the partial fraction expanded form of Eq (20). There is a double term (a double pole if this were H(z)), so maybe it can be more simply explained without it. Consider a system with transfer function (i suggest to view using Google Groups with a fixed-width font): (z-q1)(z-q2) ... (z-qM) H(z) = ------------------------- (z-p1)(z-p2) ... (z-pN) q1, q2, ... qN are the M zeros. p1, p2, ... pN are the N poles. Usually we assume that the number of poles is at least as many as the number of zeros: M <= N, otherwize we can perform a form of long division and get terms like z and z^2 outside of this big fraction. the zeros q1, q2, ... qN and poles p1, p2, ... pN should be considered possibly complex. Now let's also assume (for simplicity) that none of the poles are identical to any other poles. The above transfer function can be represented as a sum of partial fractions (instead of as a product of factors with zeros divided by a product of factors with poles): A_1 A_2 A_N H(z) = -------- + -------- + ... + -------- z - p1 z - p2 z - pN The denominators of each partial fraction are the same factors as those in the denominator of the form of H(z) we started with. The poles are the same in both cases. That makes sense because, if the two forms are equivalent, when H(z) is evaluated at any pole location, |H(z)| will blow up. In the first form, it blows up because the denominator of the whole transfer function goes to zero. in the second form (with partial fractions), it blows up because one of the partial fractions blow up (because its denominator goes to zero). The symbols A_1, A_2, ... A_N are *constants* that have to be just right so that when all of these partial fractions are summed (and placed over a common denominator), it adds up to the same H(z) as before. Now the zeros have some effect in the latter transfer function (they have to), but they do not affect any partial fractions denominator, only the numerators. Then when we perform the inverse Z transform of this transfer function, H(z), we get the impulse response that looks like h[n] = u[n]*( A_1*p1^n + A_2*p2^n + ... + A_N*pN^n ) where u[n] is the unit step function. p1^n is an exponential function. in order for the impulse response to be stable and not blow up when a unit impulse is applied to the input, then all of the pole values must have magnitude of less than 1. |p1| < 1, |p2| < 1, ... |pN| < 1 . if any of those get as big as 1, the impulse response will never settle down and decay to zero. if any exceed 1, the exponential functions will blow up. that is the fundamental answer to your question. if you're an EE student, it's something you should learn by your 3rd year and something similar for Laplace transforms, H(s). r b-j
