Jerry Avins wrote:> > Piergiorgio Sartor wrote: > > ... > > > the impulse maybe does not reflect > > the real filter performance. > > How not?The how was in the first half of the sentence that you snipped. He's talking about non-linear filters. But I don't know exactly how that relates to the original question. -jim -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =-----
Problem measuring frequency response of filters
Started by ●January 26, 2004
Reply by ●January 29, 20042004-01-29
An impulse is often not enough energy to get an accurate representation of the filter when dealing with longer fixed point filters. For example, a 100 tap FIR filter set up as a low pass filter with a fairly narrow bandwidth is going to have a rather small response to an impulse input. That response can easily get lost in the quantization that goes on in a fixed point implementation. A step input can provide the same information, and does not suffer from the quantization as badly. Frequency sweeps work too, but you have to be careful to sweep the frequency slowly enough that you don't get artifacts due to your sweep rate. A swept frequency test also takes longer to execute than an impulse or step response. When debuggin filter hardware, I normally start with an impulse because it is really easy to see if the coefficients are coming through correctly, followed by a step which confirms that contributions from each tap are summing correctly, followed by a sweep. If the impulse and step outputs of various magnitudes and polarities match a matlab model exactly, the time consuming (in hardware simulation) sweep simulation can usually be skipped. Piergiorgio Sartor wrote:> Rick Lyons wrote: > > > I've always wondered if it's better to test a > > filter implementation by applying a unit sample > > impulse, and then FFTing the impulse response, or > > apply "white" noise and average multiple > > FFTs of the filter's output. > > And what about a frequency sweep? > > I was always thinking that such a signal should > give the "visual" frequency response in the time > domain, but I never got if it is meaningful... > > > Off the top of my head, I can't answer that simple > > question. > > Well, I guess white noise is a must in non-linear > filters, since the impulse maybe does not reflect > the real filter performance. > > bye, > > -- > Piergiorgio Sartor-- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 email ray@andraka.com http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759
Piergiorgio Sartor wrote:> Jerry Avins wrote: > >>> the impulse maybe does not reflect >>> the real filter performance. >> >> >> How not? > > > If the filter is non-linear, it means it cannot > neccessarily be decomposed, so the impulse response > can be misleading. > > I think something like "abs(x)" is a simple example of this. > > bye,How do you make a digital filter non-linear without saturating? A truly non-linear filter doesn't have a single impulse response. I suppose that a liberal interpretation of "filter" would include squaring and transcendental functions, but that doesn't seem to be under consideration here. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●January 30, 20042004-01-30
Jerry Avins wrote:> How do you make a digital filter non-linear without saturating? A truly > non-linear filter doesn't have a single impulse response. I suppose that > a liberal interpretation of "filter" would include squaring and > transcendental functions, but that doesn't seem to be under > consideration here."Filter" is everything that transforms data. "grep" is a filter. The non-linear story was related to the white noise measurament technique. White noise must be used, even if is not necessarily sufficient, in case of non linear filters. Was just a comment on that. bye, -- piergiorgio
You may want to run the filter for X times the filter's impulse response to get it to settle down internally before capturing the next 1000 samples for yor DFT. Also, DC offset error can creep in due to the (sum of the DFT samples) not being equal to zero. This can add considerably to your "noise floor" in the bottom bin. I think you could divide that (sum of samples) by 1000 to produce a value which can then be subtracted from each and all the DFT samples to cancel the DC error over the whole block. I think. I did an audio spectrum analyzer as an exercise a while ago and used a simple HP filter, which approximates to the same thing. The reason then was to get rid of ADC offset errors, as a 1% DC error equates to a best noise floor of -40dB (poor). By the way, do you use DFT o/p bin averaging to tame your display? It helps a lot if you want to take measurements when using noise as a test signal. Jim Adamthwaite.
Jerry Avins wrote: (snip)> How do you make a digital filter non-linear without saturating? A truly > non-linear filter doesn't have a single impulse response. I suppose that > a liberal interpretation of "filter" would include squaring and > transcendental functions, but that doesn't seem to be under > consideration here.After just answering a post about X-ray diffraction spectroscopy with a reference to one of my favorite books, "Deconvolution, with applications to spectroscopy", by Jansson, which has a lot of discussion over linear and non-linear deconvolution, maybe some examples. Consider an optical emission spectrum, taken with a diffraction grating and finite width slits. Now, apply a linear deconvolution algorithm. One requirement of an emission spectrum is that the intensity is always positive. Restricting the result to always be positive makes a big difference in the results. Some of the more interesting results from deconvolution are from the original Hubble space telescope, with the defective mirror. (Also, good examples of the difference between accuracy and precision.) The mirror was very precisely made with the wrong shape, so that the spot function was very well known. One can then ask what input signal, that is never negative, would most likely result in the signal coming out of the telescope. -- glen
