Why cplex filters?
Started by ZedToe January 23, 2004
"Randy Yates" <yates@ieee.org> wrote in message
news:vfmy836v.fsf@ieee.org...
> "Bhaskar Thiagarajan" <bhaskart@deja.com> writes: > > > "Randy Yates" <yates@ieee.org> wrote in message > > news:ptd74i85.fsf@ieee.org... > >> "Bhaskar Thiagarajan" <bhaskart@deja.com> writes: > >> > >> > "ZedToe" <acoustictech_zhangtao@yahoo.com.sg> wrote in message > >> > news:7c4bf533.0401231957.22326456@posting.google.com... > >> >> Dear all, > >> >> > >> >> Why need we design complex filters? What are the advantages they
have
> >> >> against the real-coefficient fitlers? Except the unsymmetric
spectrum,
> >> >> there indeed nothing special. Also it can be derived from a real > >> >> lowpass filter with an appropriated phase shift. What do you think? > >> >> > >> >> Thanks. > >> >> > >> >> Zedtoe > >> > > >> > I think you can use a complex FIR filter to correct for both
amplitude
> > as > >> > well as phase (you only get amplitude changes using a real FIR > >> > filter...linear phase of course). > >> > >> Wrong. You can design real, non-linear-phase FIR filters. The amount of > > control > > > > But can you use them on complex signals and achieve a desired phase and > > amplitude correction? (I'm not challenging, but asking). > > I'm pretty sure you can, but I can't really think of any canned filter > design packages that let you do this. You could try specifying a > vector of N complex numbers representing magnitude/phase at > frequencies from -Fs/2 to +Fs/2 and inverse transforming the result, > but there is certain to be some constraints on the length N versus the > amount of magnitude and phase control.
I always thought that, for complex signals, you need a complex filter to do amplitude and phase correction. Your statement says otherwise and I'm struggling to grasp it. I certainly do understand that real FIR filters of doing phase correction on real signals. Perhaps the part I have difficulty with is that the phase in a complex signal is determined by the relationship between the I,Q components and unless the phase of each component is changed by a different amount (complex filter) you can only achieve a shift in the overall phase of the complex signal but not change the shape of the phase response. Cheers Bhaskar
> -- > % Randy Yates % "And all that I can do > %% Fuquay-Varina, NC % is say I'm sorry, > %%% 919-577-9882 % that's the way it goes..." > %%%% <yates@ieee.org> % Getting To The Point', *Balance of
Power*, ELO
> http://home.earthlink.net/~yatescr
> "Randy Yates" <yates@ieee.org> wrote in message > news:vfmy836v.fsf@ieee.org... >> "Bhaskar Thiagarajan" <bhaskart@deja.com> writes: >> >> > "Randy Yates" <yates@ieee.org> wrote in message >> > news:ptd74i85.fsf@ieee.org... >> >> "Bhaskar Thiagarajan" <bhaskart@deja.com> writes: >> >> >> >> > "ZedToe" <acoustictech_zhangtao@yahoo.com.sg> wrote in message >> >> > news:7c4bf533.0401231957.22326456@posting.google.com... >> >> >> Dear all, >> >> >> >> >> >> Why need we design complex filters? What are the advantages they > have >> >> >> against the real-coefficient fitlers? Except the unsymmetric > spectrum, >> >> >> there indeed nothing special. Also it can be derived from a real >> >> >> lowpass filter with an appropriated phase shift. What do you think? >> >> >> >> >> >> Thanks. >> >> >> >> >> >> Zedtoe >> >> > >> >> > I think you can use a complex FIR filter to correct for both > amplitude >> > as >> >> > well as phase (you only get amplitude changes using a real FIR >> >> > filter...linear phase of course). >> >> >> >> Wrong. You can design real, non-linear-phase FIR filters. The amount of >> > control >> > >> > But can you use them on complex signals and achieve a desired phase and >> > amplitude correction? (I'm not challenging, but asking). >> >> I'm pretty sure you can, but I can't really think of any canned filter >> design packages that let you do this. You could try specifying a >> vector of N complex numbers representing magnitude/phase at >> frequencies from -Fs/2 to +Fs/2 and inverse transforming the result, >> but there is certain to be some constraints on the length N versus the >> amount of magnitude and phase control. > > I always thought that, for complex signals, you need a complex filter to do > amplitude and phase correction. Your statement says otherwise and I'm > struggling to grasp it. I certainly do understand that real FIR filters of > doing phase correction on real signals.
I may have been a bit imprecise - a real filter can correct a *portion* of a complex signal's phase response. Essentially, a real filter will have a Hermitian-symmetric frequency response, so you can only control one-half of the bandwidth (i.e., Fs/2 of the bandwidth), the other half being necessarily a reflection of the first half. In other words, you can control the phase from 0 to Fs/2, but then the phase from 0 to -Fs/2 will be odd symmetric with that of 0 to +Fs/2 (i.e., phi(-f) = -phi(f), 0 <= f < Fs/2).
> Perhaps the part I have difficulty with is that the phase in a complex > signal is determined by the relationship between the I,Q components and > unless the phase of each component is changed by a different amount (complex > filter) you can only achieve a shift in the overall phase of the complex > signal but not change the shape of the phase response.
Can you please rephrase, Bhaskar? I'm not understanding you here. -- % Randy Yates % "Though you ride on the wheels of tomorrow, %% Fuquay-Varina, NC % you still wander the fields of your %%% 919-577-9882 % sorrow." %%%% <yates@ieee.org> % '21st Century Man', *Time*, ELO http://home.earthlink.net/~yatescr
news:ad49xbb5.fsf@ieee.org...
> "Bhaskar Thiagarajan" <bhaskart@deja.com> writes: > > > "Randy Yates" <yates@ieee.org> wrote in message > > news:vfmy836v.fsf@ieee.org... > >> "Bhaskar Thiagarajan" <bhaskart@deja.com> writes: > >> > >> > "Randy Yates" <yates@ieee.org> wrote in message > >> > news:ptd74i85.fsf@ieee.org... > >> >> "Bhaskar Thiagarajan" <bhaskart@deja.com> writes: > >> >> > >> >> > "ZedToe" <acoustictech_zhangtao@yahoo.com.sg> wrote in message > >> >> > news:7c4bf533.0401231957.22326456@posting.google.com... > >> >> >> Dear all, > >> >> >> > >> >> >> Why need we design complex filters? What are the advantages they > > have > >> >> >> against the real-coefficient fitlers? Except the unsymmetric > > spectrum, > >> >> >> there indeed nothing special. Also it can be derived from a real > >> >> >> lowpass filter with an appropriated phase shift. What do you
think?
> >> >> >> > >> >> >> Thanks. > >> >> >> > >> >> >> Zedtoe > >> >> > > >> >> > I think you can use a complex FIR filter to correct for both > > amplitude > >> > as > >> >> > well as phase (you only get amplitude changes using a real FIR > >> >> > filter...linear phase of course). > >> >> > >> >> Wrong. You can design real, non-linear-phase FIR filters. The amount
of
> >> > control > >> > > >> > But can you use them on complex signals and achieve a desired phase
and
> >> > amplitude correction? (I'm not challenging, but asking). > >> > >> I'm pretty sure you can, but I can't really think of any canned filter > >> design packages that let you do this. You could try specifying a > >> vector of N complex numbers representing magnitude/phase at > >> frequencies from -Fs/2 to +Fs/2 and inverse transforming the result, > >> but there is certain to be some constraints on the length N versus the > >> amount of magnitude and phase control. > > > > I always thought that, for complex signals, you need a complex filter to
do
> > amplitude and phase correction. Your statement says otherwise and I'm > > struggling to grasp it. I certainly do understand that real FIR filters
of
> > doing phase correction on real signals. > > I may have been a bit imprecise - a real filter can correct a > *portion* of a complex signal's phase response. Essentially, a real > filter will have a Hermitian-symmetric frequency response, so you can > only control one-half of the bandwidth (i.e., Fs/2 of the bandwidth), > the other half being necessarily a reflection of the first half. In > other words, you can control the phase from 0 to Fs/2, but then the > phase from 0 to -Fs/2 will be odd symmetric with that of 0 to +Fs/2 > (i.e., phi(-f) = -phi(f), 0 <= f < Fs/2). > > > Perhaps the part I have difficulty with is that the phase in a complex > > signal is determined by the relationship between the I,Q components and > > unless the phase of each component is changed by a different amount
(complex
> > filter) you can only achieve a shift in the overall phase of the complex > > signal but not change the shape of the phase response. > > Can you please rephrase, Bhaskar? I'm not understanding you here.
Never mind Randy...I can't even make out what I was trying to say here - I guess I can't really think in phase domain.
> -- > % Randy Yates % "Though you ride on the wheels of
tomorrow,
> %% Fuquay-Varina, NC % you still wander the fields of your > %%% 919-577-9882 % sorrow." > %%%% <yates@ieee.org> % '21st Century Man', *Time*, ELO > http://home.earthlink.net/~yatescr
> "Randy Yates" <yates@ieee.org> wrote in message > news:ad49xbb5.fsf@ieee.org... >> "Bhaskar Thiagarajan" <bhaskart@deja.com> writes: >> >> > "Randy Yates" <yates@ieee.org> wrote in message >> > news:vfmy836v.fsf@ieee.org... >> >> "Bhaskar Thiagarajan" <bhaskart@deja.com> writes: >> >> >> >> > "Randy Yates" <yates@ieee.org> wrote in message >> >> > news:ptd74i85.fsf@ieee.org... >> >> >> "Bhaskar Thiagarajan" <bhaskart@deja.com> writes: >> >> >> >> >> >> > "ZedToe" <acoustictech_zhangtao@yahoo.com.sg> wrote in message >> >> >> > news:7c4bf533.0401231957.22326456@posting.google.com... >> >> >> >> Dear all, >> >> >> >> >> >> >> >> Why need we design complex filters? What are the advantages they >> > have >> >> >> >> against the real-coefficient fitlers? Except the unsymmetric >> > spectrum, >> >> >> >> there indeed nothing special. Also it can be derived from a real >> >> >> >> lowpass filter with an appropriated phase shift. What do you > think? >> >> >> >> >> >> >> >> Thanks. >> >> >> >> >> >> >> >> Zedtoe >> >> >> > >> >> >> > I think you can use a complex FIR filter to correct for both >> > amplitude >> >> > as >> >> >> > well as phase (you only get amplitude changes using a real FIR >> >> >> > filter...linear phase of course). >> >> >> >> >> >> Wrong. You can design real, non-linear-phase FIR filters. The amount > of >> >> > control >> >> > >> >> > But can you use them on complex signals and achieve a desired phase > and >> >> > amplitude correction? (I'm not challenging, but asking). >> >> >> >> I'm pretty sure you can, but I can't really think of any canned filter >> >> design packages that let you do this. You could try specifying a >> >> vector of N complex numbers representing magnitude/phase at >> >> frequencies from -Fs/2 to +Fs/2 and inverse transforming the result, >> >> but there is certain to be some constraints on the length N versus the >> >> amount of magnitude and phase control. >> > >> > I always thought that, for complex signals, you need a complex filter to > do >> > amplitude and phase correction. Your statement says otherwise and I'm >> > struggling to grasp it. I certainly do understand that real FIR filters > of >> > doing phase correction on real signals. >> >> I may have been a bit imprecise - a real filter can correct a >> *portion* of a complex signal's phase response. Essentially, a real >> filter will have a Hermitian-symmetric frequency response, so you can >> only control one-half of the bandwidth (i.e., Fs/2 of the bandwidth), >> the other half being necessarily a reflection of the first half. In >> other words, you can control the phase from 0 to Fs/2, but then the >> phase from 0 to -Fs/2 will be odd symmetric with that of 0 to +Fs/2 >> (i.e., phi(-f) = -phi(f), 0 <= f < Fs/2). >> >> > Perhaps the part I have difficulty with is that the phase in a complex >> > signal is determined by the relationship between the I,Q components and >> > unless the phase of each component is changed by a different amount > (complex >> > filter) you can only achieve a shift in the overall phase of the complex >> > signal but not change the shape of the phase response. >> >> Can you please rephrase, Bhaskar? I'm not understanding you here. > > Never mind Randy...I can't even make out what I was trying to say here - I > guess I can't really think in phase domain.
I'll take that as a rephrasal! :) Let me give you my understanding of the term "phase domain" or "phase response." If we have a filter with impulse resonse h(t) or h(n*Ts), then we can find its frequency response by taking the Fourier transform of its impulse response H(w) = F{h(n)}. The frequency response H(w) is, in general, a complex function of the real variable w, therefore we can express it as H(w) = A(w) * e^{j*phi(w)}, where A(w) is a non-negative, real function and phi(w) is a real function. This is simply the polar form of a complex number, but it is a function of frequency w. Then A(w) is said to be the "magnitude response" and phi(w) the "phase response" of the filter. Any sine wave sin(w*t + theta) with phase theta that passes through the filter will have a phase (theta + phi(w)) when it reaches the output, i.e., the output sine wave will be A(w) * sin(w*t + theta + phi(w)). Since 2*pi radians corresponds to one cycle at the frequency w, we can translate phase to time. Since any input signal can be decomposed into a sum of sinusoids we can then use the filter's phase response phi(w) to see the amount of time it will delay each sinusoid. For example, a linear-phase filter has a constant *time delay* at all frequencies. If we denote that time delay as Td, then we can convert time delay into phase according to the following simple formula phi(w) = 2 * pi * (Td / T) = ((2 * pi) / T) * Td = (2 * pi * f) * Td = w * Td, where w = 2*pi*f and T = 1/f. Since Td is a constant, phi(w) is a linear function of w - hence the phrase "linear phase." Does that help? -- % Randy Yates % "Rollin' and riding and slippin' and %% Fuquay-Varina, NC % sliding, it's magic." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Living' Thing', *A New World Record*, ELO http://home.earthlink.net/~yatescr
Randy Yates wrote:
> Since 2*pi radians corresponds to one cycle at the frequency w, we can > translate phase to time. Since any input signal can be decomposed > into a sum of sinusoids we can then use the filter's phase response > phi(w) to see the amount of time it will delay each sinusoid.
Caveat: From that, the time is known with an ambiguity of n*2*pi/w, where n is an arbitrary integer. The ambiguity can often be resolved by knowing a boundary condition and the continuity of the function. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
news:65ew8z0u.fsf@ieee.org...
> "Bhaskar Thiagarajan" <bhaskart@deja.com> writes: > > > "Randy Yates" <yates@ieee.org> wrote in message > > news:ad49xbb5.fsf@ieee.org... > >> "Bhaskar Thiagarajan" <bhaskart@deja.com> writes: > >> > >> > "Randy Yates" <yates@ieee.org> wrote in message > >> > news:vfmy836v.fsf@ieee.org... > >> >> "Bhaskar Thiagarajan" <bhaskart@deja.com> writes: > >> >> > >> >> > "Randy Yates" <yates@ieee.org> wrote in message > >> >> > news:ptd74i85.fsf@ieee.org... > >> >> >> "Bhaskar Thiagarajan" <bhaskart@deja.com> writes: > >> >> >> > >> >> >> > "ZedToe" <acoustictech_zhangtao@yahoo.com.sg> wrote in message > >> >> >> > news:7c4bf533.0401231957.22326456@posting.google.com... > >> >> >> >> Dear all, > >> >> >> >> > >> >> >> >> Why need we design complex filters? What are the advantages
they
> >> > have > >> >> >> >> against the real-coefficient fitlers? Except the unsymmetric > >> > spectrum, > >> >> >> >> there indeed nothing special. Also it can be derived from a
real
> >> >> >> >> lowpass filter with an appropriated phase shift. What do you > > think? > >> >> >> >> > >> >> >> >> Thanks. > >> >> >> >> > >> >> >> >> Zedtoe > >> >> >> > > >> >> >> > I think you can use a complex FIR filter to correct for both > >> > amplitude > >> >> > as > >> >> >> > well as phase (you only get amplitude changes using a real FIR > >> >> >> > filter...linear phase of course). > >> >> >> > >> >> >> Wrong. You can design real, non-linear-phase FIR filters. The
amount
> > of > >> >> > control > >> >> > > >> >> > But can you use them on complex signals and achieve a desired
phase
> > and > >> >> > amplitude correction? (I'm not challenging, but asking). > >> >> > >> >> I'm pretty sure you can, but I can't really think of any canned
filter
> >> >> design packages that let you do this. You could try specifying a > >> >> vector of N complex numbers representing magnitude/phase at > >> >> frequencies from -Fs/2 to +Fs/2 and inverse transforming the result, > >> >> but there is certain to be some constraints on the length N versus
the
> >> >> amount of magnitude and phase control. > >> > > >> > I always thought that, for complex signals, you need a complex filter
to
> > do > >> > amplitude and phase correction. Your statement says otherwise and I'm > >> > struggling to grasp it. I certainly do understand that real FIR
filters
> > of > >> > doing phase correction on real signals. > >> > >> I may have been a bit imprecise - a real filter can correct a > >> *portion* of a complex signal's phase response. Essentially, a real > >> filter will have a Hermitian-symmetric frequency response, so you can > >> only control one-half of the bandwidth (i.e., Fs/2 of the bandwidth), > >> the other half being necessarily a reflection of the first half. In > >> other words, you can control the phase from 0 to Fs/2, but then the > >> phase from 0 to -Fs/2 will be odd symmetric with that of 0 to +Fs/2 > >> (i.e., phi(-f) = -phi(f), 0 <= f < Fs/2). > >> > >> > Perhaps the part I have difficulty with is that the phase in a
complex
and
> >> > unless the phase of each component is changed by a different amount > > (complex > >> > filter) you can only achieve a shift in the overall phase of the
complex
> >> > signal but not change the shape of the phase response. > >> > >> Can you please rephrase, Bhaskar? I'm not understanding you here. > > > > Never mind Randy...I can't even make out what I was trying to say here -
I
> > guess I can't really think in phase domain. > > I'll take that as a rephrasal! :) > > Let me give you my understanding of the term "phase domain" or "phase > response." If we have a filter with impulse resonse h(t) or h(n*Ts), > then we can find its frequency response by taking the Fourier > transform of its impulse response > > H(w) = F{h(n)}. > > The frequency response H(w) is, in general, a complex function of the > real variable w, therefore we can express it as > > H(w) = A(w) * e^{j*phi(w)}, > > where A(w) is a non-negative, real function and phi(w) is a real > function. This is simply the polar form of a complex number, but it is > a function of frequency w. Then A(w) is said to be the "magnitude > response" and phi(w) the "phase response" of the filter. > > Any sine wave sin(w*t + theta) with phase theta that passes through > the filter will have a phase (theta + phi(w)) when it reaches the > output, i.e., the output sine wave will be A(w) * sin(w*t + theta + > phi(w)). > > Since 2*pi radians corresponds to one cycle at the frequency w, we can > translate phase to time. Since any input signal can be decomposed > into a sum of sinusoids we can then use the filter's phase response > phi(w) to see the amount of time it will delay each sinusoid. > > For example, a linear-phase filter has a constant *time delay* at all > frequencies. If we denote that time delay as Td, then we can > convert time delay into phase according to the following simple > formula > > phi(w) = 2 * pi * (Td / T) > = ((2 * pi) / T) * Td > = (2 * pi * f) * Td > = w * Td, > > where w = 2*pi*f and T = 1/f. Since Td is a constant, phi(w) is a > linear function of w - hence the phrase "linear phase." > > Does that help?
Absolutely. I appreciate your taking the time and I guess this helps me get back to what I was trying to say/ask. The phase response of a complex signal phi(w) is essentially tan_inv(Q(w)/I(w)) right? Now, when a real filter is applied (say with linear phase resp) to this signal (essentially, the same filter is applied separately to the I and Q components) the Q(w) and I(w) each go through a linear shift in phase as a function of w. So the final phase response of the signal tan_inv(Q(w)/I(w)) doesn't really change because the numerator and denominator went through the same change. So even if the real filter has non-linear phase response, it wouldn't help in 'shaping' the phase response of the complex signal. A complex filter on the other hand is basically 2 different real filter with 2 different phase responses applied to the I,Q components. Controlling how each of these 2 filters modify the phase response of the I, Q individually, you can now control the overall output phase response of the complex signal. This is what I was trying to say initially, but I suspect I got something wrong in my statements regarding how the real filter affects the complex signal's phase response. Cheers Bhaskar
> -- > % Randy Yates % "Rollin' and riding and slippin' and > %% Fuquay-Varina, NC % sliding, it's magic." > %%% 919-577-9882 % > %%%% <yates@ieee.org> % 'Living' Thing', *A New World Record*,
ELO
On Mon, 26 Jan 2004 02:29:07 GMT, Randy Yates <yates@ieee.org> wrote:
  (snipped)
> >Zedtoe, to answer your question, I think you must ask another >question: When is it necessary or convenient to process complex >signals? (once you have a complex signal, then obviously you need >complex filters to filter them with) > >In my experience, the answer to this has been "when we are processing >a signal with modulation." The reason is that such a signal is almost >always modulated on a carrier frequency Fc with bandwidth B, i.e., the >signal information is from Fc - B/2 to Fc + B/2 (Hz). In that case >it makes sense to utilize the whole digital bandwidth from -Fs/2 to +Fs/2 >and sample at Fs = B, quadrature downconverting the comm signal so that >the carrier center frequency Fc is translated to DC. If you translated >this down to a real signal, you'd be wasting have the bandwidth. >
Yep, there are *all sorts* of applications where it's useful to monitor (measure) the instantaneous time-domain phase of a sinusoid, instantaneous frequency of a sinusoid, or the relative phase of spectral components. * digital communications systems (modulation & demodulation) * radar systems, * time difference of arrival processing in radio direction finding schemes, * coherent pulse measurement systems, * antenna beamforming applications, [-Rick-]
