Hello, I have a signal, f(t), that has been sampled non uniformly (irregular). I need to find the DTF of this signal, F(omega). Since the FFT is very fast and I already have an implementation of it that I am familiar with; I want to regularize the data; that is approximate the signal at $t=i*\Delta t$, where i=0, 1, 2, ... and $\Delta t$ is the sampling. So far I have binned the sampled values. Example: I have the following irregular samples of f(t): f(1) = 2, f(2) = 3, f(6) = 1, f(7) = 3 and f(13) = 4. Choosing $\Delta t$ = 10 the result of the binning is: f(0) = f(1) + f(2) = 5 f(10) = f(6) + f(7) + f(13) = 8 Does the binning introduce aliasing? Is there a relatively simple way I can assign the non uniformly sampled values to the nodes in an uniform grid that gives a better ("smoother" ?) representation of f(t)? Thanks in advance for any answers!
FFT of a non uniformly sampled signal
Started by ●May 9, 2011
Reply by ●May 9, 20112011-05-09
No Latex support :-( ? the line>>that is approximate the signal at $t=i*\Delta t$, where i=0, 1, 2, ... >>and $\Delta t$ is the sampling.should read: that is approximate the signal at t = i*Dt, where i=0, 1, 2, ... and Dt is the sampling.
"Andy365" <andreas_w_paulsen@yahoo.com> wrote in message news:dc7d3ede-d09e-4c98-b549-ac9a30f49668@m10g2000yqd.googlegroups.com...> Hello, > I have a signal, f(t), that has been sampled non uniformly > (irregular). > I need to find the DTF of this signal, F(omega). > Since the FFT is very fast and I already have an implementation of it > that I am familiar with; I want to regularize the data; > that is approximate the signal at $t=i*\Delta t$, where i=0, 1, 2, ... > and $\Delta t$ is the sampling. > > So far I have binned the sampled values. > Example: > I have the following irregular samples of f(t): > f(1) = 2, f(2) = 3, f(6) = 1, f(7) = 3 and f(13) = 4. > Choosing $\Delta t$ = 10 the result of the binning is: > f(0) = f(1) + f(2) = 5 > f(10) = f(6) + f(7) + f(13) = 8That doesn't work. Say the signal was a constant level V e.g. f(1) = V, f(2) = V, f(6) = V, f(7) = V and f(13) = V. f(0) = f(1) + f(2) = 2*V f(10) = f(6) + f(7) + f(13) = 3*V Both f(0) and f(10) should equal V. You could use linear interpolation e.g. f(0) = f(1) - (f(2)-f(1)) f(10) = (f(7)+f(13))/2
On 05/09/2011 10:51 AM, Andy365 wrote:> Hello, > I have a signal, f(t), that has been sampled non uniformly > (irregular). > I need to find the DTF of this signal, F(omega). > Since the FFT is very fast and I already have an implementation of it > that I am familiar with; I want to regularize the data; > that is approximate the signal at $t=i*\Delta t$, where i=0, 1, 2, ... > and $\Delta t$ is the sampling. > > So far I have binned the sampled values. > Example: > I have the following irregular samples of f(t): > f(1) = 2, f(2) = 3, f(6) = 1, f(7) = 3 and f(13) = 4. > Choosing $\Delta t$ = 10 the result of the binning is: > f(0) = f(1) + f(2) = 5 > f(10) = f(6) + f(7) + f(13) = 8 > > Does the binning introduce aliasing? > > Is there a relatively simple way I can assign the non uniformly > sampled values to the nodes in an uniform grid that gives a better > ("smoother" ?) representation of f(t)?I don't know if this is the _best_ way, but here's _a_ way: I would consider using splines to make things fit. For each result sample, choose the three nearest neighboring source samples, and do the spline thing. The calculations for splines is only complex if you need to calculate for arbitrary sampling intervals -- if the intervals are known before hand, then the computation becomes one of multiplying the three samples by three known coefficients and taking the result. So if your actual sampling instants are really at integer increments of some faster clock, and if those integer increments are bounded tightly enough (i.e., if there's never an increment longer than 5, for instance), then you can pre-calculate some or all of the possible combinations of intervals and significantly speed up your on-line calculation. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
On May 9, 1:57=A0pm, Andy365 <andreas_w_paul...@yahoo.com> wrote:> No Latex support :-( ? > > the line > > >>that is approximate the signal at $t=3Di*\Delta t$, where i=3D0, 1, 2, =...> >>and $\Delta t$ is the sampling. > > should read: > that is approximate the signal at t =3D i*Dt, where i=3D0, 1, 2, ... and > Dt is the sampling.how do the dt samples relate to the nyquist rate? 10x, 5x, 2x? there will always be aliasing with resampling, to some degree linear or spline interpolation may be all that is needed, depends on the nature of your data and the problem your trying to solve
Hello Andrew, yes you are right I must normalize the data: f(0) = [ f(1) + f(2) ] / 2 f(10) = [ f(6) + f(7) + f(13) ] / 3 Would not linear interpolation be more vulnerable to noise? In my example I only had 2 and 3 samples in each bin cell. In reality I may have about 10 samples in each bin cell. If I sum together 10 samples the signal/noise ratio would improve by a factor of 10?
On May 9, 8:40=A0pm, steve <bungalow_st...@yahoo.com> wrote:> On May 9, 1:57=A0pm, Andy365 <andreas_w_paul...@yahoo.com> wrote: > > > No Latex support :-( ? > > > the line > > > >>that is approximate the signal at $t=3Di*\Delta t$, where i=3D0, 1, 2=, ...> > >>and $\Delta t$ is the sampling. > > > should read: > > that is approximate the signal at t =3D i*Dt, where i=3D0, 1, 2, ... an=d> > Dt is the sampling. > > how do the dt samples relate to the nyquist rate? =A010x, 5x, 2x? > > there will always be aliasing with resampling, to some degree > > linear or spline interpolation may be all that is needed, depends on > the nature of your data > > and the problem your trying to solveHello Steve, to me the binning I am doing seems to me a bit similar to the problem of rasterizing a line in computer graphics. Therefore I was wondering if there might be some techniques borrow from that field / image analysis that I could use?
Reply by ●May 10, 20112011-05-10
On May 9, 7:51=A0pm, Andy365 <andreas_w_paul...@yahoo.com> wrote:> Hello, > I have a signal, f(t), that has been sampled non uniformly > (irregular). > I need to find the DTF of this signal, F(omega).Wrong. You need to find the spectrum F(w) of this, sequence, not the DFT. The DFT is useful only with regularly sampled data, whereas the signal you are describing might be seen as a sequence of irregularly spaced Dirac deltas. Use the straight-forward inner product with the basis functions.> Since the FFT is very fast and I already have an implementation of it > that I am familiar with;That doesn't matter. The FFT is the wrong tool to use. A hammer is no good if the task is to cut a plank in half.> I want to regularize the data; > that is approximate the signal at $t=3Di*\Delta t$, where i=3D0, 1, 2, ..=.> and $\Delta t$ is the sampling.When? Before applying the FFT? Or is the interpolation the purpose of the FFT? Rune
On May 10, 5:39=A0am, Rune Allnor <all...@tele.ntnu.no> wrote:> On May 9, 7:51=A0pm, Andy365 <andreas_w_paul...@yahoo.com> wrote: > > > Hello, > > I have a signal, f(t), that has been sampled non uniformly > > (irregular). > > I need to find the DTF of this signal, F(omega). > > Wrong. You need to find the spectrum F(w) of this, > sequence, not the DFT. The DFT is useful only with > regularly sampled data, whereas the signal you are > describing might be seen as a sequence of irregularly > spaced Dirac deltas. > > Use the straight-forward inner product with the > basis functions. > > > Since the FFT is very fast and I already have an implementation of it > > that I am familiar with; > > That doesn't matter. The FFT is the wrong tool to use. > A hammer is no good if the task is to cut a plank in half. > > > I want to regularize the data; > > that is approximate the signal at $t=3Di*\Delta t$, where i=3D0, 1, 2, =...> > and $\Delta t$ is the sampling. > > When? Before applying the FFT? Or is the interpolation > the purpose of the FFT? > > RuneThank you Rune! Yes you are right; my signal is a sum of irregularly spaced Dirac deltas multiplied with sample values, therefore the Fourier transform of this is a sum of plane waves multiplied with sample values. And yes the spectrum is my goal, and the interpolation is just a step towards this. However in reality my signal is in 3 dimensions and I may have say about 10 000 irregular samples. I think that adding together the plane wave value over 10 000 waves for each point will be very time consuming and that it therefore is better to use FFT. Andreas
On May 10, 9:44=A0am, Andy365 <andreas_w_paul...@yahoo.com> wrote: ...> However in reality my signal is in 3 dimensions and I may have say > about 10 000 irregular samples. > I think that adding together the plane wave value over 10 000 waves > for each point will be very time consuming and that it therefore is > better to use FFT.You just don't get it. FFT (fast Fourier transform) is a class of algorithms that perform a DFT (discrete Fourier transform) on regularly sampled data. Using the procedure on irregularly sampled data is no more useful than deciphering coded data with the wrong key. While it may be true that using known correct methods on your samples is impractical, only wishful thinking leaps from there to the conclusion that incorrect methods will therefore yield a useful result. Jerry -- Engineering is the art of making what you want from things you can get.
