I was thinking about osculating polynomial interpolation (of which Hermite is the first order member) in relation to sample rate conversion. As I understand it, osculating interpolation is a method where the interpolating function is a polynomial that matches a function's value(s) plus a certain number of its derivatives (0, 1, 2*, etc.) at those values. This makes good sense when you are approximating a continuous function, for example approximating log(x) with a polynomial. However, the concept of the derivative doesn't make sense when all you have is a few data points. What am I missing? -Jon * Typically 0 is known as Lagrange and 1 is known as Hermite interpolation
Osculating/Hermite Interpolation on sampled data
Started by ●January 21, 2004
Reply by ●January 21, 20042004-01-21
"Jon Harris" <goldentully@hotmail.com> wrote in message news:bumukv$jo88n$1@ID-210375.news.uni-berlin.de...> I was thinking about osculating polynomial interpolation (of which Hermite > is the first order member) in relation to sample rate conversion. As I > understand it, osculating interpolation is a method where theinterpolating> function is a polynomial that matches a function's value(s) plus a certain > number of its derivatives (0, 1, 2*, etc.) at those values. This makesgood> sense when you are approximating a continuous function, for example > approximating log(x) with a polynomial. However, the concept of the > derivative doesn't make sense when all you have is a few data points.What> am I missing? >Jon, Why would few (or many) data points make a difference? I'm thinking about properly sampled data where the bandwidth was limited to begin with or where the data points were discrete LPFd prior to interpolation. [On occasion we've had folks suggest that a sine burst is bandlimited - which of course it isn't. We had another case where a sinusoid at exactly fs/2 was sampled. Until I saw the latter, I had always assumed that *any* sequence of regular samples represents a bandlimited function that can be reconstructed. That latter anomalous case convinced me otherwise. Sinc reconstruction blows up in that case. ] To make sure anomalous things aren't buried in the data, perhaps an up-front LPF with the widest possible bandwidth is indicated. If you compute the DFT (of an even number of samples as in an FFT) and a nonzero, or more than insignificant, value results at fs/2, then something is wrong. The other thing that can be said is that some interpolators don't preserve even the first derivative and guarantee break points - which wouldn't result in a bandlimited function after interpolation. So, if you've sampled the data properly then it must be bandlimited - or pick your own definition from the "real" world. Even if you've sampled at the lowest possible rate to generate "few" data points, the bandlimitation has an affect on the derivatives I do believe. This is one perspective at least - that may answer your question. Fred
Reply by ●January 22, 20042004-01-22
In article bumukv$jo88n$1@ID-210375.news.uni-berlin.de, Jon Harris at goldentully@hotmail.com wrote on 01/21/2004 17:37:> I was thinking about osculating polynomial interpolation (of which Hermite > is the first order member) in relation to sample rate conversion. As I > understand it, osculating interpolation is a method where the interpolating > function is a polynomial that matches a function's value(s) plus a certain > number of its derivatives (0, 1, 2*, etc.) at those values.yup.> This makes good > sense when you are approximating a continuous function, for example > approximating log(x) with a polynomial.i dunno. i use a remes polynomial solution to do log2() and exp2() and sqrt() and the like.> However, the concept of the > derivative doesn't make sense when all you have is a few data points. What > am I missing?if you have sampled data, then it is reasonable to presume it was sampled from a bandlimited continuous-time (or continuous-something-else) signal. isn't a continuous-time signal also one with continuity of the function and all its derivative? if so, it seems to me a reasonable goal to try to preserve the continuity of as many derivatives as possible. am i missing something? BTW, there are many other concerns for deciding polynomial interpolation over some other kind and which kind of polynomial to use. so i am not saying Hermite is the best, but i do think there is at least one attractive property of them. r b-j
robert bristow-johnson <rbj@surfglobal.net> wrote in message news:BC34BC76.7F1E%rbj@surfglobal.net...> In article bumukv$jo88n$1@ID-210375.news.uni-berlin.de, Jon Harris at > goldentully@hotmail.com wrote on 01/21/2004 17:37: > > > I was thinking about osculating polynomial interpolation (of which Hermite > > is the first order member) in relation to sample rate conversion. As I > > understand it, osculating interpolation is a method where the interpolating > > function is a polynomial that matches a function's value(s) plus a certain > > number of its derivatives (0, 1, 2*, etc.) at those values. > > yup. > > > This makes good > > sense when you are approximating a continuous function, for example > > approximating log(x) with a polynomial. > > i dunno. i use a remes polynomial solution to do log2() and exp2() and > sqrt() and the like. > > > However, the concept of the > > derivative doesn't make sense when all you have is a few data points. What > > am I missing? > > if you have sampled data, then it is reasonable to presume it was sampled > from a bandlimited continuous-time (or continuous-something-else) signal. > isn't a continuous-time signal also one with continuity of the function and > all its derivative? if so, it seems to me a reasonable goal to try to > preserve the continuity of as many derivatives as possible. am i missing > something?I don't think you're missing anything, I'm just confused about the mechanics of the process. For instance: Say you are trying to do 3rd order Hermite interpolation. All you have is 4 data points and you need to calculate an intermediate point. So you supposedly construct a cubic polynomical that matches (some of) the original data points and their derivatives. What is the derivative of the original data points? It sounds like you are saying it is "the derivative of the continuous function that would be created by zero padding those 4 points infinitely, and then doing an ideal band-limited interpolation". Is that right? Another point of confusion, I know that there is some fundamental thereom that states that there is only 1 cubic polynomial that passes through 4 points. And that would be the so-called Lagrange polynomical. So the Hermite and other osculating functions must not pass through all the points. So do they trade off exact matches at points for exact matches of derivatives? If so, would the 3rd order Hermite polynomical pass through 3 of the 4 points and match the first derivative at one of those 4 points?> BTW, there are many other concerns for deciding polynomial interpolation > over some other kind and which kind of polynomial to use. so i am not > saying Hermite is the best, but i do think there is at least one attractive > property of them.Right. I'm just trying to get my brain around the concept in general. (Guess where I heard of the concept in the first place--your paper. :-)> r b-jJon
"Jon Harris" <goldentully@hotmail.com> wrote in message news:<bumukv$jo88n$1@ID-210375.news.uni-berlin.de>...> I was thinking about osculating polynomial interpolation (of which Hermite > is the first order member) in relation to sample rate conversion. As I > understand it, osculating interpolation is a method where the interpolating > function is a polynomial that matches a function's value(s) plus a certain > number of its derivatives (0, 1, 2*, etc.) at those values. This makes good > sense when you are approximating a continuous function, for example > approximating log(x) with a polynomial. However, the concept of the > derivative doesn't make sense when all you have is a few data points. What > am I missing? > > -Jon > > * Typically 0 is known as Lagrange and 1 is known as Hermite interpolationI think one way of thinking of this is to imagine an inductor L and both a voltmeter in parallel and an ammeter in series with it and you simultaneously take samples of both voltage and current. Since V = LdI/dt you have now sampled both the function I and its 1st derivative. The Hermite interpolator is now applicable to the set of voltage and current samples you have taken to reconstruct the current as function of time. Notice, that you do not need to perform any numerical differentiation, instead the derivative, i.e., the voltage, must be measured independently of the current. Interestingly, one can extend the Nyquist sampling theorem to cases you are asking about. Roughly speaking, it is possible to reconstruct a bandlimited function if it is sampled at 2W rate, where W is its bandwidth and the samples are "independent". Sampling here may mean the function values or its derivatives, 1st, 2nd, etc., and these do not have to be at the sample place. Hope this helps.
In article buntf1$jv8i2$1@ID-210375.news.uni-berlin.de, Jon Harris at goldentully@hotmail.com wrote on 01/22/2004 02:20:> robert bristow-johnson <rbj@surfglobal.net> wrote in message > news:BC34BC76.7F1E%rbj@surfglobal.net......>> if you have sampled data, then it is reasonable to presume it was sampled >> from a bandlimited continuous-time (or continuous-something-else) signal. >> isn't a continuous-time signal also one with continuity of the function and >> all its derivative? if so, it seems to me a reasonable goal to try to >> preserve the continuity of as many derivatives as possible. am i missing >> something? > > I don't think you're missing anything, I'm just confused about the mechanics > of the process. > For instance: Say you are trying to do 3rd order Hermite interpolation. All > you have is 4 data points and you need to calculate an intermediate point. So > you supposedly construct a cubic polynomical that matches (some of) the > original data points and their derivatives. What is the derivative of the > original data points?good question, but it's not matching the "original data" derivative since it does not exist, of course, being discrete-time.> It sounds like you are saying it is "the derivative of the continuous function > that would be created by zero padding those 4 points infinitely, and then > doing an ideal band-limited interpolation". Is that right?okay, look at it this way: you have *5* points with indices 0, 1, 2, 3, and 4. those discrete samples are x[n] and the interpolated function is x(t) (note the use of brackets for discrete-time and parenths for continuous-time). so first, we take the first 4 points (x[0], x[1], x[2], x[3]) and create some cubic polynomial, x(t), that we are interested in its behavior between points 1 and 2. the actual normalized "time" value for the interpolation is 1+a where 0 <= a < 1. then secondly, we take the next 4 points (x[1], x[2], x[3], x[4]) and create some cubic polynomial, x(t), that we are interested in its behavior between points 2 and 3. the actual normalized "time" value for the interpolation is 2+a where 0 <= a < 1. this cubic polynomial is spliced to the previous one at x[2]. now we want x(t) to be continuous everywhere and as many derivatives and we can get to be continuous. so, at x(2) we want both polynomials and as many derivatives to be the same since that is the point they share in common. the only way for that to happen is if the polynomial values and as many derivatives as possible *at* the point x(2), to depend on the values of the *same* shared set of points, that is x[1], x[2], x[3]. so for the first cubic Hermite polynomial, when a=1, the polynomial value must depend only on x[1], x[2], x[3] (and in fact, it depends only on x[2]) and the polynomial derivative must depend only on x[1], x[2], x[3] (and in fact, it depends only on x[1] and x[3]). and for the second cubic Hermite polynomial, when a=0, the polynomial value must depend only on x[1], x[2], x[3] (and in fact, it depends only on x[2]) and the polynomial derivative must depend only on x[1], x[2], x[3] (and in fact, it depends only on x[1] and x[3]). that's the philosophy behind the cubic Hermite.> Another point of confusion, I know that there is some fundamental thereom that > states that there is only 1 cubic polynomial that passes through 4 points. > And that would be the so-called Lagrange polynomical. So the Hermite and > other osculating functions must not pass through all the points.yes. it only passes through the two neighboring points (think of that as matching the zeroeth derivative) to where you are interpolating.> So do they trade off exact matches at points for exact matches of derivatives?yeah, but where do we care where the polynomials match? when i'm interpolating between 1 and 2, i care about matching to x[1] and x[2] but why would i give a rat's ass to whether *this* polynomial hits at x[0] or at x[3]? when i'm interpolating between 2 and 3, *then* i'll care if i hit at x[3]. when i'm interpolating between 0 and 1, *then* i'll care if i hit at x[0].> If so, > would the 3rd order Hermite polynomical pass through 3 of the 4 points and > match the first derivative at one of those 4 points?it passes though the inner 2 points and misses on the outer 2. the Lagrange passes through all 4 but, when spliced to the adjacent Lagrange, the derivative is not guaranteed to be continuous. r b-j
Reply by ●January 23, 20042004-01-23
> yeah, but where do we care where the polynomials match? when i'm > interpolating between 1 and 2, i care about matching to x[1] and x[2] but > why would i give a rat's ass to whether *this* polynomial hits at x[0] orat> x[3]? when i'm interpolating between 2 and 3, *then* i'll care if i hitat> x[3]. when i'm interpolating between 0 and 1, *then* i'll care if i hitat> x[0]. > > > If so, > > would the 3rd order Hermite polynomical pass through 3 of the 4 pointsand> > match the first derivative at one of those 4 points? > > it passes though the inner 2 points and misses on the outer 2. theLagrange> passes through all 4 but, when spliced to the adjacent Lagrange, the > derivative is not guaranteed to be continuous. > > r b-j >Very good explaination Robert. Can Hermite polynomial based interpolation be used for interpolating 2D data, like images? I shall appreciate any references or links? Ishtiaq.
Reply by ●September 29, 20052005-09-29
Speaking about continuity when using interpolating polynomials make sense since we can set up equations of constraints for this when constructing the polynomials (such as for splines). When using windowed sinc interpolation, does it make sense to talk about interpolation continuity? If so, how is this measured? This message was sent using the Comp.DSP web interface on www.DSPRelated.com
"snappy" <glad@kth.se> wrote in message news:GpCdnbQrNNy_OqbeRVn-hw@giganews.com...> Speaking about continuity when using interpolating polynomials make sense > since we can set up equations of constraints for this when constructing > the polynomials (such as for splines). > > When using windowed sinc interpolation, does it make sense to talk about > interpolation continuity? If so, how is this measured?It seems like it might. I wonder if the question were posed as: "When using windowed Dirichlet Kernel interpolation, does it make sense to talk about interpolation continuity?" It seems that the periodic nature of this "sinc" would remove the discontinuities otherwise evident in windowing infinitely long sincs. After all, this is often what we're doing (or should be doing?). Fred
in article GpCdnbQrNNy_OqbeRVn-hw@giganews.com, snappy at glad@kth.se wrote on 09/29/2005 04:34:> Speaking about continuity when using interpolating polynomials make sense > since we can set up equations of constraints for this when constructing > the polynomials (such as for splines).you might refer to Olli Niemitalo's paper on polynomial interpolation at http://www.biochem.oulu.fi/~oniemita/dsp/deip.pdf it is a definite improvement on an earlier paper on the same topic that Duane Wise and i did sometime in the 90s. ours doesn't live on the web, but i can send you a copy if you want.> When using windowed sinc interpolation, does it make sense to talk about > interpolation continuity?sure.> If so, how is this measured?you mean how is this determined? the sinc() function is fully continuous (the 0/0 singularity is a "removable" singularity) in all of its derivatives. if the window is continuous (at least to the point where it ends), then the windowed sinc() is continuous (at least to the point where it ends). -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
