Hi! I just implemented an IFFT on a DSP and now I=B4d like to know, what has = to be done, so that I can use that IFFT as an IDCT. Thanks, Matthias
IDCT
Started by ●January 21, 2004
Reply by ●January 22, 20042004-01-22
Matthias Alles wrote:> I just implemented an IFFT on a DSP and now I�d like to know, what has > to be done, so that I can use that IFFT as an IDCT.See the FFTPACK source code (or FFTW) for an example of how you can compute an IDCT (a.k.a. a type-III DCT) via pre/post-processing of a real-input FFT. (If you have a complex FFT algorithm, of course there are standard tricks to use it for a real-data transform of twice the length.)
Steven G. Johnson wrote:> See the FFTPACK source code (or FFTW) for an example of how you can > compute an IDCT (a.k.a. a type-III DCT) via pre/post-processing of a > real-input FFT. (If you have a complex FFT algorithm, of course there > are standard tricks to use it for a real-data transform of twice the > length.)Thanks for the tip!
