Greetz, Can someone point me to an actual coded implementation of an RLS filter? I've dug all over the net and all I keep turning up is professorial papers full of maths, or ads for student DSP toolboxes. TIA, Rob VK3XVK SDR-1000 project http://www.flex-radio.com
LMS
Started by ●January 21, 2004
Reply by ●January 22, 20042004-01-22
Matlab code is all I have at the moment...pick your way through that lot. Aren't I nice? col function [y,h,e]=adapt_rls(x,desired,gamma,sigma,len,Ntrain,lock,init,wghts,M,chnl_len); % Adaptive RLS Filter % % [y,h,e]=adapt_rls(x,desired,gamma,sigma,len,Ntrain,lock,init,wghts,M,chnl_len) % % y = output signal % h = filter coefficients % e = error signal % x = input signal % d = desired signal % mu = step size % len = filter length, positive integer. the centre tap is asssumed to be % the reference tap % % Check Input/Output Arguments % Initialise Output, Error & Filter Vectors N=length(x); filter_len=len; if (wghts~=0) h = wghts; else % initialise main tap h = zeros(filter_len,1); h(ceil((filter_len + 1)/2)) = init; end if (sigma == 0) sigma = cov(x); end % initialise output y=zeros(N,1); % initialise error e=zeros(N,1); % initialise data buffer m=zeros(filter_len,1); % construct autocorrelation matrix p=sigma*eye(len); % initialise gain vector k=zeros(filter_len,1); % filter data for n=1:N m = [x(n);m(1:filter_len-1)]; % shift next input sample in y(n) = h' * m; % compute output if (~lock & n > Ntrain) % disp('in sliced') e(n) = mpsk_slicer(y(n),M)-y(n); % feedback decisions else e(n) = desired(n) - y(n); % else use pilot signal % disp('using pilot') end % really we discard chnl_len-1 symbols, so this is correct if((n >= chnl_len & ~lock) | (n >= chnl_len & n <= Ntrain)) division = 1 / (gamma + m' * p * m); % compute Kalman gain vector k = p * m * division; h = h + k * conj(e(n)); % update coefficients p = ( p - k * m' * p) / gamma; % update inverse correlation matrix end end Rob Judd <judd@ob-wan.com> wrote in message news:<400E946D.473A8BCC@ob-wan.com>...> Greetz, > > Can someone point me to an actual coded implementation of an RLS filter? > I've dug all over the net and all I keep turning up is professorial > papers full of maths, or ads for student DSP toolboxes. > > TIA, > > Rob VK3XVK > SDR-1000 project > http://www.flex-radio.com
