On May 19, 1:00�pm, Tim Wescott <t...@seemywebsite.com> wrote:> On 05/19/2011 09:42 AM, mcode wrote: > > > Hello! > > > Does anyone have references on (lowpass) filters with maximally flat > > magnitude at DC and minimum phase? A first look only turned up linear- > > phase and reduced-delay designs. I'm particularly interested in FIR > > right now, but also IIR. > > In the continuous-time world that's a Bessel filter. �I don't know if > there's an equivalent IIR sampled-time filter. > > In FIR, a filter with a Gaussian shape may get you that. > > -- > > Tim Wescott > Wescott Design Serviceshttp://www.wescottdesign.com > > Do you need to implement control loops in software? > "Applied Control Theory for Embedded Systems" was written for you. > See details athttp://www.wescottdesign.com/actfes/actfes.htmlBessel filter is maximally flat in group delay. Butterworth is maximally flat in magnitude. Dirk
Max-flat min-phase filters
Started by ●May 19, 2011
Reply by ●May 20, 20112011-05-20
Reply by ●May 22, 20112011-05-22
Okay, I underspecified the problem. What I really wanted to know is whether the lit has a *closed form* for FIR with *independent* flatness degrees (n zero tangents at DC, k roots at Nyquist) and minimum phase. After reading the classic study of Selesnick and Burrus, I thought someone might have cracked the mp special case. But I just found this paper, whose existence I guess implies a definitive No: http://dx.doi.org/10.1016/S0196-8858(03)00022-8 Thanks folks, Martin
