Changing gain in frequency domain creates funny artefacts
Started by John ●May 26, 2011
Hi,
I need some help with a simulation I am working on in matlab.
I am working on a noise suppression algorithm for speech signals sampled at
8kHz.
When I modify the amplitude of a number of frequency bins, I get distortions
in the modified signal when I transfer it back to the time domain.
Here is a copy of my script ....I am hoping that somebody in this group
could tell me what I am doing wrong.
clc
close all
clear all
%% Load signal
% x: noisy speech signal
% s: clean speech signal
% n: noise signal
addpath '..\audiofiles'
% Load speech signal
TargetFs = 8000;
Tsec = 7;
[s,fs]=wavread('cleanspeech.wav',1);
[s,fs]=wavread('cleanspeech.wav',fs*Tsec);
s = s';
s = resample(s,TargetFs,fs);
% Add white noise to the speech signal
dBSNR = 30;
x = awgn(s,dBSNR,'measured');
n = x-s;
%% Init Variables
% sout: final output signal
sout = [];
% number of samples in a sample block
blockSize = TargetFs/100;
% reset block counter
blockCounter = 0;
% calculate total number of blocks to process
numberOfBlocks = floor(length(x)/blockSize);
% calculate fft size
fftSize = 2^nextpow2(3*blockSize);
% define frame size
frameSize = fftSize;
% init sampleframe for output samples
sampleFrameOut = zeros(1,frameSize);
% init phi angle
phi = 0;
%% Main DSP Loop
while (1)
    audioBlockIn =
x(1+blockCounter*blockSize:blockSize+blockCounter*blockSize);
    % Do fft of audio block
    audioVector = zeros(1,fftSize);
    audioVector(1:blockSize) = audioBlockIn;
    X = fft(audioVector);
    % simulate gain changes
    gainVec = [abs(cos(phi)) abs(cos(phi)) abs(cos(phi)) abs(cos(phi))
abs(cos(phi)) abs(cos(phi)) abs(cos(phi)) ones(1,120)];
    phi = phi + 0.03;
    % Create gain vector
    G = [1 gainVec 1 gainVec(end:-1:1)];
    % Modify spectrum
    Y = G.*X;
    % Overlap-Add
    sampleFrameOut = sampleFrameOut + real(ifft(Y));
    audioBlockOut = sampleFrameOut(1:blockSize);
    sampleFrameOut = [sampleFrameOut(blockSize+1:end) zeros(1,blockSize)];
    sout = [sout audioBlockOut];
    blockCounter = blockCounter + 1;
    if (blockCounter == numberOfBlocks)
        break;
    end
end
wavplay(sout,TargetFs)
Here I do it in the time domain and it sounds fine:
%% Main DSP Loop (TIME DOMAIN)
numberOfFilterCoefficients = 128;
delayLine = zeros(1,numberOfFilterCoefficients-1);
while (1)
    audioBlockIn =
    % Create filter
    h = fir1(numberOfFilterCoefficients-1,0.5+0.4*cos(phi));
    phi = phi + 0.03;
    % Filter audio block
    [audioBlockOut,delayLine] = filter(h,1,audioBlockIn,delayLine);
        break;
    end
end
Hi Tim,
It works fine when the gain vector does not vary with time. Then there are
no
artefacts....but as soon as I make the gains time varying (which they would
have to be
in a noise suppression scheme) I get noise artefacts when I transfer the
modified signal back to the time domain.
On 05/26/2011 11:44 AM, John wrote:
(too bad you took out your context)
> Here I do it in the time domain and it sounds fine: > > %% Main DSP Loop (TIME DOMAIN) > numberOfFilterCoefficients = 128; > delayLine = zeros(1,numberOfFilterCoefficients-1); > while (1) > audioBlockIn = > x(1+blockCounter*blockSize:blockSize+blockCounter*blockSize); > > % Create filter > h = fir1(numberOfFilterCoefficients-1,0.5+0.4*cos(phi)); > phi = phi + 0.03; > > % Filter audio block > [audioBlockOut,delayLine] = filter(h,1,audioBlockIn,delayLine); > > sout = [sout audioBlockOut]; > > blockCounter = blockCounter + 1; > if (blockCounter == numberOfBlocks) > break; > end > > end
I didn't plow through your code, but in general if you multiply in the frequency domain that's the same as filtering in the time domain. Either your time-domain filter isn't derived from your frequency domain filter, or you're suffering from wrapping when you do the ifft. Try taking the IFFT of _just_ your frequency-domain filter and plotting it. Then take the FFT of _just_ the impulse response of your time-domain filter. Compare the time-domain version of your original frequency domain filter, and the frequency-domain version of your original time-domain filter. Ideally, all should match. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
Figured it out...
    % Create filter
    h = fir1(fftSize/2-1,0.5+0.4*cos(phi));
    G = fft(h,fftSize);
    phi = phi + 0.03;
    % Modify spectrum
    Y = G.*X;
The problem was that the phase response of the filter also has to be
included in G. So I can't do it like this:
    % Create filter
    G = abs(fft(h,fftSize));   % Creates artefacts when taking the abs value
of the impulse resp.
    phi = phi + 0.03;
    % Modify spectrum
    Y = G.*X;
I thought I could get away with modifying the amplitude of the noisy speech
signal and then doing the IFFT of the modified spectrum, but obviously I
also have to change the phase.
Is that correct?
On 05/26/2011 12:23 PM, John wrote:
> Figured it out... > > % Create filter > h = fir1(fftSize/2-1,0.5+0.4*cos(phi)); > G = fft(h,fftSize); > phi = phi + 0.03; > > % Modify spectrum > Y = G.*X; > > The problem was that the phase response of the filter also has to be > included in G. So I can't do it like this: > > % Create filter > h = fir1(fftSize/2-1,0.5+0.4*cos(phi)); > G = abs(fft(h,fftSize)); % Creates artefacts when taking the abs value > of the impulse resp. > phi = phi + 0.03; > > % Modify spectrum > Y = G.*X; > > I thought I could get away with modifying the amplitude of the noisy > speech signal and then doing the IFFT of the modified spectrum, but > obviously I also have to change the phase. > > Is that correct? >
Looks that way to me. That 'abs' just hurts to look at, in that context. Certainly, you have to take phase into account or you'll mess everything up. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
On May 26, 3:23&#4294967295;pm, "John" <j...@nospam.thanks> wrote:
> Figured it out...
i can't tell that. if you're using the FFT and iFFT to do filtering, you have to use either the overlap-add or overlap-save methods. i can't tell you're doing that. the FIR length must be less than the block size and you may advance only the difference between the block size and the FIR length (plus 1 sample, if you want). normally you will have artifacts when changing the FIR characteristic between blocks, which is simply a problem of processing block-by- block. but if the characteristics do not change greatly between blocks, you might be able to get away with overlap-add. i would not use overlap-save with a time-varying transfer function. r b-j
> i can't tell that.
well...it seems to work
>if you're using the FFT and iFFT to do filtering, you have to use >either the overlap-add or overlap-save methods. i can't tell you're >doing that.
What is this then? sampleFrameOut = sampleFrameOut + real(ifft(Y)); audioBlockOut = sampleFrameOut(1:blockSize); sampleFrameOut = [sampleFrameOut(blockSize+1:end) zeros(1,blockSize)];
You could change your code such that only the magnitude is changed and
the 'noisy phase' is preserved just as in typical noise reduction.
You may have problems with time-aliasing.
You need to smooth your frequency-domain filter in order to truncate
the length of the corresponding time-domain filter. remember that you
are doing a circular convolution and that constrains the length of
your filter.
I'm not sure it is the problem though as I have only glanced quickly
over your code.
Cheers
niarn
John, you can use a oversampled filter bank for varying with time filtering
in the  frequency domain and to avoid aliasing  artifacts.
