continuous fourier transform c#
Started by tinkerz ●May 27, 2011
Hi,
I have seen lots of links on google and yahoo, to the FFT, DFT etc.
But nothing for CTFT, can anybody please point me in the right directions
to coded examples of CTFT and laplace transforms in a control process.
Thanks
Tinkerz
On 5/27/2011 10:10 AM, tinkerz wrote:
> Hi, > > I have seen lots of links on google and yahoo, to the FFT, DFT etc. > > But nothing for CTFT, can anybody please point me in the right directions > to coded examples of CTFT and laplace transforms in a control process. > > Thanks > > Tinkerz
If it's continuous, then it's not sampled so it's not digital either. If it's not sampled then you might look for the Finite Fourier Transform which is at least continuous. and then consider looking at the Fourier Series which is likely equivalent to what you're asking about. Either way, it sounds like you're asking about an analytic solution which you might get with Maple, Matlab, Derive, etc. So, "coded examples" sounds a bit strange unless you plan to code things up using Matlab or ... whatever. And whatever "code" means to you. In the sampled, digital world: Laplace Transform goes to Z-Transform Fourier Transform goes to Finite, Discrete Fourier Transform Fred
Mathematica has analytic CTFT http://reference.wolfram.com/mathematica/ref/FourierTransform.html But ss was mentioned, in the real wold, one used the discrete versions. To go from CTFT to DTFT, here is a demo http://demonstrations.wolfram.com/FromContinuousToDiscreteTimeFourierTransformBySamplingMethod/ --Nasser
On May 27, 1:10=A0pm, "tinkerz" <nwoodhamuk@n_o_s_p_a_m.googlemail.com>
1/s in laplace is an integral, so I write it out the transform as integrals and numerically integrate it, trapezoidal rule is good enough
On 5/29/2011 6:30 PM, steve wrote:
> On May 27, 1:10 pm, "tinkerz"<nwoodhamuk@n_o_s_p_a_m.googlemail.com> > wrote: >> Hi, >> >> I have seen lots of links on google and yahoo, to the FFT, DFT etc. >> >> But nothing for CTFT, can anybody please point me in the right directions >> to coded examples of CTFT and laplace transforms in a control process. >> >> Thanks >> >> Tinkerz > > 1/s in laplace is an integral, so I write it out the transform as > integrals and numerically integrate it, trapezoidal rule is good enough
It *is* all about context isn't it? Fred
On May 27, 7:10=A0pm, "tinkerz" <nwoodhamuk@n_o_s_p_a_m.googlemail.com>
Those kinds of things are not done as part of the numerical computations. They are analysis tools that help decide how to configure the numerical computations. Rune
On Sun, 29 May 2011 17:24:13 -0700, "Nasser M. Abbasi" <nma@12000.org>
wrote:
>On 5/27/2011 10:10 AM, tinkerz wrote: >> Hi, >> >> I have seen lots of links on google and yahoo, to the FFT, DFT etc. >> >> But nothing for CTFT, can anybody please point me in the right directions >> to coded examples of CTFT and laplace transforms in a control process. >> >> Thanks >> >> Tinkerz > >Mathematica has analytic CTFT > >http://reference.wolfram.com/mathematica/ref/FourierTransform.html > >But ss was mentioned, in the real wold, one used the discrete versions. > >To go from CTFT to DTFT, here is a demo > >http://demonstrations.wolfram.com/FromContinuousToDiscreteTimeFourierTransformBySamplingMethod/ > >--Nasser
Hello Nasser, At that 2nd web site, the text under the sub-title 'Details' states that Mathematica's built-in function FourierTransform implements the CTFT of a continuous x_a(t) signal. Can you tell us how a User is supposed to apply a continuous x_a(t) input signal (perhaps a voltage) to a computer running Mathematica software? Does Mathematica have a way of performing continous (analog) signal processing? The reason I ask is because the frequency variable in the CTFT is radians-per-second and is a continuous variable. Likewise the frequency variable in the DTFT is radians-per-sample (not 'radians' as stated on the web page) and is also a continuous variable. I'm trying to figure out how Mathematica can compute the values of continous (analog) variables. Wouldn't such processing require an infinite number of binary bits to represent a single value? [-Rick-]
On May 31, 8:25&#4294967295;am, Rick Lyons <R.Lyons@_BOGUS_ieee.org> wrote:
 &#4294967295;
the values of continous (analog) variables.Wouldn't
> such processing require an infinite number of binary > bits to represent a single value?
that's true for all fourier transforms
Rick Lyons <R.Lyons@_bogus_ieee.org> wrote:
(snip)
> Does Mathematica have a way of performing > continous (analog) signal processing? The reason > I ask is because the frequency variable in the > CTFT is radians-per-second and is a continuous > variable. Likewise the frequency variable in the > DTFT is radians-per-sample (not 'radians' as stated > on the web page) and is also a continuous variable.
Mathematica can do symbolic math. That way you can do things that can't be done numerically.
> I'm trying to figure out how Mathematica can compute > the values of continous (analog) variables. Wouldn't > such processing require an infinite number of binary > bits to represent a single value?
I have nearby my TI-92 calculator, but not Mathematica. If I wanted, for example, the integral from 0 to 2pi of sin(a x) I just put that in ... \int(sin(a*x),x,0,2\pi) (using the TeX names, but the keyboard has an integral sign and a pi sign.) I get: -cos(2*a*x)/a + 1/a If I wanted the Fourier transform of a continuous square wave, then I could call that the transform. The result is accurate to any number of bits. I can do the integral of 1/sqrt(1-x^2) from -1 to 1, and the result comes out as one character, accurate to an infinite number of bits. You can always ask for approximate answers. If you put in ln(256) you get out 8*ln(2). Mathematica can do all these, and more. -- glen
On 5/31/2011 3:56 PM, steve wrote:
> On May 31, 8:25 am, Rick Lyons<R.Lyons@_BOGUS_ieee.org> wrote: > > I'm trying to figure out how Mathematica can compute > the values of continous (analog) variables.Wouldn't >> such processing require an infinite number of binary >> bits to represent a single value? > > that's true for all fourier transforms
Precision and continuity are two different things. Let us say that you want to know the expression for some integral of some other expression - with defined limits, etc. including +/- infinity. OK - so you get a symbolic result which can be evaluated for any value of the independent variable. Let's just say for the sake of argument that the value selected is a suitably small integer - so no precision problems there! But the result will have some precision depending on how many digits you choose to carry it out on paper, with a sliderule, with a calculator, with a computer ... except in special cases where the result has nothing but trailing zeros..... where the sliderule may not be the best tool to get infinite precision. This has nothing to do with the expression being continuous and everything to do with your arithmetic. Fred
