Suggest good references to understand the Math of Direct Coversion Receivers
Started by johnlovestohate ●May 31, 2011
On 05/31/2011 10:10 PM, Rune Allnor wrote:
> On Jun 1, 5:03 am, Randy Yates<ya...@ieee.org> wrote: >> On 05/31/2011 11:02 PM, Randy Yates wrote: >> >> >> >> >> >>> On 05/31/2011 10:45 PM, robert bristow-johnson wrote: >>>> On May 31, 2:19 pm, Tauno Voipio<tauno.voi...@notused.fi.invalid> >>>> wrote: >>>>> Tim Wescott wrote: >>>>>> On 05/31/2011 09:18 AM, johnlovestohate wrote: >>>>>>> Hi, >>>>>>> Please suggest some good references for the Math involved in Direct >>>>>>> Covnersion Receivers. I am interested in Math and not circuitry. >> >>>>>> What's your math background so far? Any basic Signals& Systems book >>>>>> should have the math you need. Get a copy of the ARRL handbook for a >>>>>> discussion of the math as it pertains specifically to DC receivers. >> >>>>> A good next step will be Rick Lyons' book. >> >>>> duh, whatsa direct conversion receiver? >> >>> I think that's a position/play often used by teams in the NFL... >> >> But seriously, folks.. >> >> It's a receiver that goes from RF to baseband in one swell foop, >> i.e., without an intervening IF stage. > > Hmm... in that case, the question as stated by the OP is > equivalent 'what is the math of physics'. > > As far as I can tell, any comms modulation scheme might be > configured as BB<-> RF, with no intermediate IF steps. > Now, it might not be *wise* to do this in each and every > case, but it *can* be done. Mathematically, at least, if > not always practically.
It makes for an electrically simple receiver, however even moderately weak signals are swamped with DC offset at the mixer output, there are difficulties with oddball mixing products (a famous one in amateur radio practice happens when the local oscillator energy is rectified in the power supply diodes, re-radiated or conducted to the mixer, then demodulated as all the harmonics of the line frequency), and if you want to feed a speaker you have difficulty getting the necessary tons of gain all in one stage.
> So the OP essentially asks for a reference to all the math > pertinent to comm receivers.
Yup. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
On 05/31/2011 09:18 PM, robert bristow-johnson wrote:
> On May 31, 11:03 pm, Randy Yates<ya...@ieee.org> wrote: >> On 05/31/2011 11:02 PM, Randy Yates wrote: >> >> >> >>> On 05/31/2011 10:45 PM, robert bristow-johnson wrote: >>>> On May 31, 2:19 pm, Tauno Voipio<tauno.voi...@notused.fi.invalid> >>>> wrote: >>>>> Tim Wescott wrote: >>>>>> On 05/31/2011 09:18 AM, johnlovestohate wrote: >>>>>>> Hi, >>>>>>> Please suggest some good references for the Math involved in Direct >>>>>>> Covnersion Receivers. I am interested in Math and not circuitry. >> >>>>>> What's your math background so far? Any basic Signals& Systems book >>>>>> should have the math you need. Get a copy of the ARRL handbook for a >>>>>> discussion of the math as it pertains specifically to DC receivers. >> >>>>> A good next step will be Rick Lyons' book. >> >>>> duh, whatsa direct conversion receiver? >> >>> I think that's a position/play often used by teams in the NFL... >> >> But seriously, folks.. >> >> It's a receiver that goes from RF to baseband in one swell foop, >> i.e., without an intervening IF stage. > > i thought maybe. but wanted to make sure. > > still more questions: is there any analog signal processing between > the antenna terminals (or the transmission line from the antenna) and > the A/D converter? is a broadband amplifier allowed in there? if > yes, is there any compelling reason that this amplifier cannot be less > broad banded?
There can be. In general you want a bandpass filter to limit the required dynamic range of your mixer. In practice it's all about money and effort -- if you wanted the superest-zootest receiver you probably wouldn't be building a DC receiver.
> anyway, there is no reason why a lickity-split fast A/D and DSP can't > tune and bump it down to an internal quadrature IF and demodulate from > that. i am still not sure that it would be cost effective against > bumping it down to a non-quadrature IF in the analog domain in a > single tank circuit with the initial amplifier.
If you place the "IF" at baseband then you can establish its bandwidth with low-pass filters; it's far easier to realize a no-adjust circuit that way than with resonant coils, and far cheaper than crystal or ceramic filters. Digitally, whatever you do past the ADC is much more equivalent than with circuits. Whether your receiver is direct conversion "inside" or not matters less in the digital world than in analog. If you sample at 4x RF, then it's pretty easy to implement quadrature downconversion in digital-land. Quadrature downconversion followed by CIC filtering would also be easy to implement in simple hardware, and would give you a fairly nicely (and cheaply) processed signal to do further magic on with a more sophisticated processor running at a slower sampling rate.
> about 45 years ago i > had a short wave radio kit (from Knight-Kit, part of Allied Radio > Electronics) called the "Star Roamer". it was a cheapie little kit > that you could hook a simple long-wire antenna to. and the signal > from the antenna went directly into the mixer that bumped it down to > IF (455 kHz, IIRC). no RF amplifier and the tuning was strictly done > by what made it through the IF tank circuit. i think there was a > front-panel cap in parallel that was for antenna matching that you > would have to twist. so maybe that would make it inconvenient in > comparison to DC. > > now that i think about it, i dunno how that Star Roamer SW radio was > able, without *any* RF filtering, to keep the components at 910 kHz > below the frequency of interest from interfering with the negative- > frequency IF bandpass. somehow, you would have to knock that out > before mixing, no?
Older short-wave receivers were notorious for having poor image rejection. The "antenna matching" circuit probably gave you some RF selectivity, though. This is actually an advantage of DC receivers: image frequencies are at baseband, too, so there's no need (or at least no improvement to be had) for image-reject filters at RF. If you want image rejection, you need to do quadrature downconversion and baseband processing. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
On 1.6.11 7:08 , Tim Wescott wrote:
> On 05/31/2011 07:45 PM, robert bristow-johnson wrote: >> On May 31, 2:19 pm, Tauno Voipio<tauno.voi...@notused.fi.invalid> >> wrote: >>> Tim Wescott wrote: >>>> On 05/31/2011 09:18 AM, johnlovestohate wrote: >>>>> Hi, >>>>> Please suggest some good references for the Math involved in Direct >>>>> Covnersion Receivers. I am interested in Math and not circuitry. >>> >>>> What's your math background so far? Any basic Signals& Systems book >>>> should have the math you need. Get a copy of the ARRL handbook for a >>>> discussion of the math as it pertains specifically to DC receivers. >>> >>> A good next step will be Rick Lyons' book. >>> >> >> duh, whatsa direct conversion receiver? > > It's a receiver that multiplies the desired signal by sine and cosine > waves at the carrier frequency, to bring the signal all the way down to > baseband. > > In amateur radio usage it often just multiplies by the sine wave, to > receive single sideband. > > AKA "I/Q downconversion", "downconvert to baseband", etc.
You need both sine and cosine, an analytic signal, to get rid of the undesired sideband. One of the problems of a direct conversion receiver is the 1/f noise at the middle of the baseband. Pretty often usable results will be achieved by using moderate high-pass in the amplification chain, though it generates a hole in the middle of the passband. -- Tauno Voipio, OH2UG
robert bristow-johnson <rbj@audioimagination.com> wrote:
(snip on direct conversion receivers)
One way is by reducing the sources at image frequencies. As I understand it, the rules for assigning TV broadcase frequencies are partly to keep stations at the image frequency far enough away not to be a problem. Maybe they are better now, but some years ago the weren't so good, especially at UHF. -- glen
Rune Allnor <allnor@tele.ntnu.no> wrote:
(snip, someone wrote)
> As far as I can tell, any comms modulation scheme might be > configured as BB <-> RF, with no intermediate IF steps. > Now, it might not be *wise* to do this in each and every > case, but it *can* be done. Mathematically, at least, if > not always practically.
Hmm. I haven't followed SDR technology enough to know, but it would seem that you could sample at more than 2xRF, then do a digital mix down to IF, digital filter, digital mix to baseband and filter again. I suppose while you are there, you could do a triple conversion (with two IFs), as it is only logic, no complicated tuned IF transformers and such. -- glen
> Hi, > Please suggest some good references for the Math involved in Direct > Covnersion Receivers. I am interested in Math and not circuitry.
Marvin Frerking. "Digital Signal Processing in Communication Systems" VLV
On Tue, 31 May 2011 21:18:41 -0700 (PDT), robert bristow-johnson
>On May 31, 11:03=A0pm, Randy Yates <ya...@ieee.org> wrote: >> On 05/31/2011 11:02 PM, Randy Yates wrote: >> >> >> >> > On 05/31/2011 10:45 PM, robert bristow-johnson wrote: >> >> On May 31, 2:19 pm, Tauno Voipio<tauno.voi...@notused.fi.invalid> >> >> wrote: >> >>> Tim Wescott wrote: >> >>>> On 05/31/2011 09:18 AM, johnlovestohate wrote: >> >>>>> Hi, >> >>>>> Please suggest some good references for the Math involved in Direct >> >>>>> Covnersion Receivers. I am interested in Math and not circuitry. >> >> >>>> What's your math background so far? Any basic Signals& Systems book >> >>>> should have the math you need. Get a copy of the ARRL handbook for a >> >>>> discussion of the math as it pertains specifically to DC receivers. >> >> >>> A good next step will be Rick Lyons' book. >> >> >> duh, whatsa direct conversion receiver? >> >> > I think that's a position/play often used by teams in the NFL... >> >> But seriously, folks.. >> >> It's a receiver that goes from RF to baseband in one swell foop, >> i.e., without an intervening IF stage. > >i thought maybe. but wanted to make sure. > >still more questions: is there any analog signal processing between >the antenna terminals (or the transmission line from the antenna) and >the A/D converter? is a broadband amplifier allowed in there? if >yes, is there any compelling reason that this amplifier cannot be less >broad banded?
Typically an LNA, filter, and the quadrature mix to baseband. The filter and LNA have to cover the entire tuning range, which can be quite large with a direct conversion receiver.
>anyway, there is no reason why a lickity-split fast A/D and DSP can't >tune and bump it down to an internal quadrature IF and demodulate from >that. i am still not sure that it would be cost effective against >bumping it down to a non-quadrature IF in the analog domain in a >single tank circuit with the initial amplifier. about 45 years ago i >had a short wave radio kit (from Knight-Kit, part of Allied Radio >Electronics) called the "Star Roamer". it was a cheapie little kit >that you could hook a simple long-wire antenna to. and the signal >from the antenna went directly into the mixer that bumped it down to >IF (455 kHz, IIRC). no RF amplifier and the tuning was strictly done >by what made it through the IF tank circuit. i think there was a >front-panel cap in parallel that was for antenna matching that you >would have to twist. so maybe that would make it inconvenient in >comparison to DC.
Direct-conversion receivers are often used for a few basic reasons: they're cheap, they're small, and they can be made to work with a pretty enormous tuning range. It's difficult to get as much tuning range with an IF architecture. These days the desire for a wide tuning range is to be able to cover, for example, the entire 5GHz ISM band, with is about 1 GHz wide. You're not going to be able to do that as well or nearly as inexpensively with a sampled-RF or sampled-IF receiver.
>now that i think about it, i dunno how that Star Roamer SW radio was >able, without *any* RF filtering, to keep the components at 910 kHz >below the frequency of interest from interfering with the negative- >frequency IF bandpass. somehow, you would have to knock that out >before mixing, no? > >(and, by "mixer", i mean the radio meaning, not the audio meaning.) > >confusedly, > >r b-j
Eric Jacobsen http://www.ericjacobsen.org http://www.dsprelated.com/blogs-1//Eric_Jacobsen.php
On Tue, 31 May 2011 22:10:50 -0700 (PDT), Rune Allnor
>On Jun 1, 5:03=A0am, Randy Yates <ya...@ieee.org> wrote: >> On 05/31/2011 11:02 PM, Randy Yates wrote: >> >> >> >> >> >> > On 05/31/2011 10:45 PM, robert bristow-johnson wrote: >> >> On May 31, 2:19 pm, Tauno Voipio<tauno.voi...@notused.fi.invalid> >> >> wrote: >> >>> Tim Wescott wrote: >> >>>> On 05/31/2011 09:18 AM, johnlovestohate wrote: >> >>>>> Hi, >> >>>>> Please suggest some good references for the Math involved in Direct >> >>>>> Covnersion Receivers. I am interested in Math and not circuitry. >> >> >>>> What's your math background so far? Any basic Signals& Systems book >> >>>> should have the math you need. Get a copy of the ARRL handbook for a >> >>>> discussion of the math as it pertains specifically to DC receivers. >> >> >>> A good next step will be Rick Lyons' book. >> >> >> duh, whatsa direct conversion receiver? >> >> > I think that's a position/play often used by teams in the NFL... >> >> But seriously, folks.. >> >> It's a receiver that goes from RF to baseband in one swell foop, >> i.e., without an intervening IF stage. > >Hmm... in that case, the question as stated by the OP is >equivalent 'what is the math of physics'. > >As far as I can tell, any comms modulation scheme might be >configured as BB <-> RF, with no intermediate IF steps. >Now, it might not be *wise* to do this in each and every >case, but it *can* be done. Mathematically, at least, if >not always practically. > >So the OP essentially asks for a reference to all the math >pertinent to comm recievers. > >Rune
I don't think so. I think the OP is just asking about the math around the complex mixer, i.e., multiply by sin/cos to get to baseband. That's basic enough that I'm not sure where to point them. Didn't Brent just do a site on that? Eric Jacobsen http://www.ericjacobsen.org http://www.dsprelated.com/blogs-1//Eric_Jacobsen.php
