I've got a single channel of 16-bit/44.1kHz audio that I'd like to resample to 16-bit/88.1kHz. I'll start with this since I believe that it might be easier than dealing with uneven mutiples if I chose another rate (like 48kHz for example). Please let me know if my understanding is correct: 1. First I need to zero pad each sample. I assume that I can just write a simple program to do this part. Is there any reason to use cubic splines or a Lagrange interpolation here? It's my understanding that the latter two may be audible, so it's best to just use zero padding for audio. Won't my data file now be twice as large at this stage? 2. Next, I need to low pass filter the data. In order to just learn how this all works, couldn't I just use a simple 1st order filter with a corner frequency of 20kHz? Not sure what else I need to do. I saw some diagram that illustrated an anti-imaging filter followed by an anti-aliasing filter. I'm unclear as to what the differences are. Won't the LPF I described handle both of these. Please post your comments about how to resample audio at an even integer multiple sampling frequency. Thanks. RK
Resampling Questions - Newbie requests your help
Started by ●January 17, 2004
Reply by ●January 17, 20042004-01-17
sorry I meant 16-bit/88.2kHz In article <YUiOb.898$Ew2.412141677@newssvr11.news.prodigy.com>, pleaserespond@tothisgroup.com says...> >I've got a single channel of 16-bit/44.1kHz audio that I'd like to resampleto>16-bit/88.1kHz. I'll start with this since I believe that it might be easier >than dealing with uneven mutiples if I chose another rate (like 48kHz for >example). Please let me know if my understanding is correct: > >1. First I need to zero pad each sample. I assume that I can just write a >simple program to do this part. Is there any reason to use cubic splines or a >Lagrange interpolation here? It's my understanding that the latter two may be >audible, so it's best to just use zero padding for audio. Won't my data file >now be twice as large at this stage? > >2. Next, I need to low pass filter the data. In order to just learn how this >all works, couldn't I just use a simple 1st order filter with a corner >frequency of 20kHz? > >Not sure what else I need to do. I saw some diagram that illustrated an >anti-imaging filter followed by an anti-aliasing filter. I'm unclear as >to what the differences are. Won't the LPF I described handle both of these. > >Please post your comments about how to resample audio at an even integer >multiple sampling frequency. > >Thanks. >RK >
Reply by ●January 18, 20042004-01-18
Got the answers to some of my questions. For one, since I know which samples are zero-stuffed, I can reduce the number of MACs (in my case by half) since the zero-stuffed values don't contribute to the summation in the filter. So from what I can tell, I don't need to recreate a new file twice as long since the filter can be calculated 'on the fly'. Also, the term I should have used was interpolation as this implies upsampling with filtering according to www.dspguru.com. So after completing the upsampling portion by zero-stuffing I'll need to add a LPF. Does anyone know if using Lagrange interpolation or cubic splines is suitable for audio? In article <nhjOb.899$7g3.415171735@newssvr11.news.prodigy.com>, pleaserespond@tothisgroup.com says...> >sorry I meant 16-bit/88.2kHz > > >In article <YUiOb.898$Ew2.412141677@newssvr11.news.prodigy.com>, >pleaserespond@tothisgroup.com says... >> >>I've got a single channel of 16-bit/44.1kHz audio that I'd like to resample >to >>16-bit/88.1kHz. I'll start with this since I believe that it might be easier >>than dealing with uneven mutiples if I chose another rate (like 48kHz for >>example). Please let me know if my understanding is correct: >> >>1. First I need to zero pad each sample. I assume that I can just write a >>simple program to do this part. Is there any reason to use cubic splines ora>>Lagrange interpolation here? It's my understanding that the latter two maybe>>audible, so it's best to just use zero padding for audio. Won't my data file >>now be twice as large at this stage? >> >>2. Next, I need to low pass filter the data. In order to just learn how this >>all works, couldn't I just use a simple 1st order filter with a corner >>frequency of 20kHz? >> >>Not sure what else I need to do. I saw some diagram that illustrated an >>anti-imaging filter followed by an anti-aliasing filter. I'm unclear as >>to what the differences are. Won't the LPF I described handle both of these. >> >>Please post your comments about how to resample audio at an even integer >>multiple sampling frequency. >> >>Thanks. >>RK >> >
Please Respond Here wrote:> > Got the answers to some of my questions. > > For one, since I know which samples are zero-stuffed, I can reduce the number > of MACs (in my case by half) since the zero-stuffed values don't contribute > to the summation in the filter. So from what I can tell, I don't need to > recreate a new file twice as long since the filter can be calculated 'on the > fly'. > > Also, the term I should have used was interpolation as this implies upsampling > with filtering according to www.dspguru.com. So after completing the > upsampling portion by zero-stuffing I'll need to add a LPF. > > Does anyone know if using Lagrange interpolation or cubic splines is suitable > for audio?The only resampling method suitable for audio is sinc interpolation. Try Secret Rabbit Code: http://www.mega-nerd.com/SRC/ Erik -- +-----------------------------------------------------------+ Erik de Castro Lopo nospam@mega-nerd.com (Yes it's valid) +-----------------------------------------------------------+ UNIX *is* user-friendly, just picky about who it chooses for friends!
Reply by ●January 19, 20042004-01-19
Erik de Castro Lopo <nospam@mega-nerd.com> wrote in message news:400AE35D.4DBF5229@mega-nerd.com...> Please Respond Here wrote: > > > > Got the answers to some of my questions. > > > > For one, since I know which samples are zero-stuffed, I can reduce thenumber> > of MACs (in my case by half) since the zero-stuffed values don't contribute > > to the summation in the filter. So from what I can tell, I don't need to > > recreate a new file twice as long since the filter can be calculated 'on the > > fly'. > > > > Also, the term I should have used was interpolation as this impliesupsampling> > with filtering according to www.dspguru.com. So after completing the > > upsampling portion by zero-stuffing I'll need to add a LPF. > > > > Does anyone know if using Lagrange interpolation or cubic splines issuitable> > for audio? > > The only resampling method suitable for audio is sinc interpolation. > > Try Secret Rabbit Code: > > http://www.mega-nerd.com/SRC/While I agree that sinc interpolation is superior, there has been plenty of audio interpolation done with Lagrange or other methods (even my PC's sound card/driver). Depending on the application and the signal, that may be adequate. But for top quality stuff, it often isn't. We've been discussing this a bit in the thread "Fast Interpolation ?". You might want to check that out as well.
