Alireza <dastgheib@gmail.com> wrote: (snip)> "A 12-bit 800-MS/s switched-capacitor DAC with open-loop output > driver and digital predistortion".> I didn't intend to discuss the main idea here so I didn't provide > enough information. My question was merely about an implementation > detail: how to build a fast refreshable lookup table.Many who post here like to learn new things. I would have thought it easier to build a linear DAC than ADC, but I do see that a slow linear ADC could be easier than a fast linear DAC.> I learned that even though the internal clocking rates of FPGAs > are lower than my speed requirements they can still handle much > faster data streams through SerDes. I can use the block RAM in > the FPGA as a lookup table and I can write to it through e.g. > the PCIe interface. All is left to do is just quite a bit of > work to set it all up and running...There is an FPGA group. Though some of the same people likely read that, and will still be interested in why. -- glen
implementation of a very fast lookup table
Started by ●June 10, 2011
Reply by ●June 21, 20112011-06-21
Reply by ●June 22, 20112011-06-22
On Jun 21, 9:05=A0pm, Alireza <dastgh...@gmail.com> wrote:> Thanks for the comments everyone. > > The main idea of the project is that we can build nonlinear analog circui=ts and correct for nonlinearity with DSP. Relaxing the linearity requiremen= ts in analog saves power and on the other hand DSP is cheap and efficient t= hanks to scaling. Here, instead of a fast and accurate DAC we build a fast = and nonlinear DAC plus a slow and accurate calibration ADC plus a digital c= alibration circuit and a lookup table. Not any nonlinear DAC can easily be = calibrated, it has to be carefully designed such that the correction is fea= sible. A proof-of-concept is already built and what I am trying to do is to= simplify the digital calibration algorithm. So instead of carefully designing a linear device, you now equally carefully design a nonlinear device? Sounds like you might be walking the tightrope above a Pandora's box. The linear design aims at countering any nonlinearities at as many occasions as possible. Granted, the efforts are not always successful, but they are always made. Once you accept nonlinearities to be present in the system, the design task is no longer to *counter* the nonlinearities, but to *control* them. Sounds like hearding cats, to me: "*This* nonlinearity is OK but *that* one is bad." A challenging task, if I ever saw one. Rune
