Hi, I am trying to segment an image according to color, i am trying to achieve that using mean-shift segmentation. Segmentation should be according to color and position ( not intensity ) The Algorithm in a nutshell 1.The image is split to regions 2.For each region the kernel of each of it�s associated pixels is calculated 3.The region centroid is moved to the position maximizing the kernel value 4.Neighboring regions are merged 5.Convergence == centroid/s are not changing ( thresholded ) In order to properly calculate the kernel color is to be presented using a single dimension, that is, the 3D RGB color space need to be converted to a 1D color space such as the color spectrum color-wheel ( http://en.wikipedia.org/wiki/File:Computer_color_spectrum.svg ) A.Is it really required to convert 3D RGB to 1D in order to efficiently segment the image using mean-shift? B.How do I convert 3D RGB color to a 1D ~color-wheel~ variable ? Any help will B appreciated Nadav Rubinstein http://www.sophin.com
Image Segmentation
Started by ●June 15, 2011
Reply by ●June 15, 20112011-06-15
Nadav wrote:> Hi, > > I am trying to segment an image according to color, i am trying to > achieve that using mean-shift segmentation.[...nonsense skipped...] Think of each pixel as a vector in 3d space (R,G,B). Then the difference in coloration between two pixels X, Y is the angle between the corresponding vectors: X * Y acos --------- |X| |Y| Take it from there.> > Any help will B appreciatedIt depends. How much is the appreciation ?> Nadav RubinsteinWow. Nadav and Rubinstein at the same time? Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Reply by ●June 16, 20112011-06-16
On Jun 15, 6:06�am, Nadav <nadav...@gmail.com> wrote:> Hi, > > I am trying to segment an image according to color, i am trying to > achieve that using mean-shift segmentation. > Segmentation should be according to color and position ( not > intensity ) > The Algorithm in a nutshell > 1.The image is split to regions > 2.For each region the kernel of each of it�s associated pixels is > calculated > 3.The region centroid is moved to the position maximizing the kernel > value > 4.Neighboring regions are merged > 5.Convergence == centroid/s are not changing ( thresholded ) > > In order to properly calculate the kernel color is to be presented > using a single dimension, that is, the 3D RGB color space need to be > converted to a 1D color space such as the color spectrum color-wheel > (http://en.wikipedia.org/wiki/File:Computer_color_spectrum.svg) > > A.Is it really required to convert 3D RGB to 1D in order to > efficiently segment the image using mean-shift? > B.How do I convert 3D RGB color to a 1D ~color-wheel~ variable ? > > Any help will B appreciated > > Nadav Rubinsteinhttp://www.sophin.comIf you look at computer graphics texts and the representations of colour, you'll find there are 3 common systems (probably more). One is RGB, another is HSL (Hue, Saturation, Level). Hue represents the colour on the colour wheel, while the other values affect the shade and brightness. I would suggest to looking colour conversions, ... or as you are more likely to find on the Internet "color conversions". A quick search for RGB and HSV or HSL gave the following: http://en.wikipedia.org/wiki/HSL_and_HSV Cheers, Dave
Dave wrote:> If you look at computer graphics textsHeh. Those texts are full of nonsense and pompous meaningless phrases like "we apply a Hugh transform to the Zobel kernel processed...". In fact they meant something very trivial. Image processing is no science but a fairly primitive bit-byte manipulation. It has to be very fast; therefore it has to be simple.> and the representations of > colour, you'll find there are 3 common systems (probably more). One is > RGB, another is HSL (Hue, Saturation, Level). Hue represents the > colour on the colour wheel, while the other values affect the shade > and brightness.Those representations have to do with the human perception and the human convenience. Being tied to the human features when doing an image analysis by a computer is a common mistake.> I would suggest to looking colour conversions, ... or as you are more > likely to find on the Internet "color conversions". A quick search for > RGB and HSV or HSL gave the following: > http://en.wikipedia.org/wiki/HSL_and_HSVIt doesn't matter what is the system of representation of the image. If the image is made of 3 basic colors then the coloration is a 2d parameter. If the OP stupident wants to do the image segmentation based on coloration but not the luminance, then he should normalize every pixel to the same brightness. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
