Hello Forum, Consider a baseband signal of a certain bandwidth B. Using analog modulation (either AM, FM or phase modulation), in a single channel environment(i.e. not worrying about possible interference between multiple users and channels) can we impress that bandwidth B on carrier of any frequency f? Does the carrier frequency need to be always much larger than the bandwidth of the signal it carries (even in a single channel situation)? Or is there some limitation? Usually we are in a narrowband situation: B<<f. Would it be ok to have B>>f? If not, why not? Let's think of a pulse of light of duration T. If the period of the carrier frequency, which 1/f, is larger than pulse period T, then the pulse will not even contain a whole cycle of the sinusoid....is that a problem? thanks fisico32
carrier frequency limitations and bandwidth
Started by ●June 18, 2011
Reply by ●June 19, 20112011-06-19
fisico32 <marcoscipioni1@n_o_s_p_a_m.gmail.com> wrote:> Consider a baseband signal of a certain bandwidth B. > Using analog modulation (either AM, FM or phase modulation), in a single > channel environment(i.e. not worrying about possible interference between > multiple users and channels) can we impress that bandwidth B on carrier of > any frequency f? Does the carrier frequency need to be always much larger > than the bandwidth of the signal it carries (even in a single channel > situation)? Or is there some limitation?For AM, the highest frequency, which has to be at least B, should be lower than the carrier frequency. Maybe not a lot lower. For FM, you have to consider both the carrier frequency and the deviation. The luminance signal for VHS has bandwidth plus deviation close to the carrier frequency. -- glen
On Jun 18, 8:50�pm, "fisico32" <marcoscipioni1@n_o_s_p_a_m.gmail.com> wrote:> Hello Forum, > > Consider a baseband signal of a certain bandwidth B. > Using analog modulation (either AM, FM or phase modulation), in a single > channel environment(i.e. not worrying about possible interference between > multiple users and channels) can we impress that bandwidth B on carrier of > any frequency f? Does the carrier frequency need to be always much larger > than the bandwidth of the signal it carries (even in a single channel > situation)? Or is there some limitation?for double-sided AM, f needs to be at least 2B. for FM, i think there is something called "Carson's rule" that says what f needs to be. if i remember correctly, narrowband FM required the same bandwidth as AM.> > Usually we are in a narrowband situation: B<<f. Would it be ok to have > B>>f? > If not, why not? >aliasing?> Let's think of a �pulse of light of duration T. If the period of the > carrier frequency, which 1/f, is larger than pulse period T, then the pulse > will not even contain a whole cycle of the sinusoid....is that a problem?it depends on how you define "duration". if you want a real signal, for AM, x(t) = a(t) * cos(2*pi*f*t) now, here's the problem, you would have to use only the top sideband of x(t) to recover a(t), if B < f < 2B. but it's hopelessly aliased for 0 < f < B. or, if you're synched to the cos(2*pi*f*t), are you suggesting to divide by it?> > thanksi'll send you a bill. r b-j
robert bristow-johnson <rbj@audioimagination.com> wrote: (snip0>> Does the carrier frequency need to be always much larger >> than the bandwidth of the signal it carries (even in a single channel >> situation)? Or is there some limitation?> for double-sided AM, f needs to be at least 2B. for FM, i think there > is something called "Carson's rule" that says what f needs to be. if > i remember correctly, narrowband FM required the same bandwidth as AM.(snip)> aliasing?(snip)> now, here's the problem, you would have to use only the top sideband > of x(t) to recover a(t), if B < f < 2B. but it's hopelessly aliased > for 0 < f < B.> or, if you're synched to the cos(2*pi*f*t), are you suggesting to > divide by it?In other words, a synchronous demodulator? I believe with the appropriate demodulator (and appropriate modulator) you can recover and AM signal at more than 100% modulation. (That is, when the amplitude goes negative.) It seems to me that with a synchronous demodulator you might also recover for B > carrier. (If no other reason, the upper sideband is still there.) I mentioned the VHS luminance carrier before. It has to be FM, as the lower frequency is just about 0Hz. (That is, completely uniform picture.) Magnetic recording doesn't like DC. -- glen
