On Jun 24, 3:35�am, "basgoossen" <bas@n_o_s_p_a_m.2dive.nl> wrote:> Thanks everybody for the answers, > > The matlab code mentionned is not something i use but an example of > overlap-save progressing found on this forum. I implement the source in > Java so i can't use the matlab's filter function ;-). > > For now i have got rid of 99% of the filter artifacts, my current approach > is to use a buffer size that is twice the requested buffer size and use > only the middle portion of the processed buffer to write the output. Since > the chunks are only 20ms that adds a delay of roughly 5ms, which is > acceptable in the application. >Bas, is the impulse response or transfer function of your filter static or is it changing? FYI, there are two, slightly different, techniques both called "overlap-add" or OLA. one is for use with more esoteric algorithms where the spectrum is often modified in a more sophisticated manner than just a static FIR filter. could be time-varying filtering or compression or a phase vocoder or some kinda sinusoidal modeling. in this technique, you will likely use some kind of overlapping and complementary windows, like the Hann window. depending on what you are doing, there may be zero padding in addition to the windowing. the frame hop is half of the width of the complementary window. there *could* be artifacts because of framing (and whatever nasty thing your algorithm is doing to the spectrum), even if you employ this OLA properly. the other OLA technique is for implementing "fast convolution" and is the alternative to "overlap-save" or OLS. in both of these cases, your window is rectangular. in OLS, it is essentially no-window (the rectangular window width is the entire frame of data) and in OLA, the rectangular window width is no larger than N-L+1 where N is the FFT length and L is the FIR length. in both cases, the frame hop is no more than N-L+1 samples. in both cases, the transfer function, H[k], must be the DFT of an impulse response, h[n], that is finite (as in "FIR") in length and with length L which should be quite a bit smaller than N. it can't be any ol' H[k] if you want to avoid artifacts at the frame boundaries. if h[n] is non-zero only for 0 <= n < L, and if you do your OLS or OLA correctly, there should be *no* artifacts at the frame boundaries (assuming no numerical issues because of insufficient word width). but if you dial in whatever H[k] your heart desires (without guaranteeing that the length of h[n] is limited to L) and use this technique, *even* in the static case, you can get artifacts at the frontier between frames. as with the time-variant case of OLA, there is no reason you cannot change the H[k] between frames (but h[n] still must be limited in length to L samples) in the "fast convolution" case, but you may very well get artifacts at the frame boundaries. you can get *click* artifacts using OLS and changing H[k] (between adjacent frames) and a somewhat better transition between frames using OLA. r b-j
Bandfilters with FFT on Sampled in-/output
Started by ●June 23, 2011
Reply by ●June 26, 20112011-06-26
