Negative Group Delay Circuit
Started by HardySpicer July 8, 2011
http://www.kuee.kyoto-u.ac.jp/~kitano/paper/slp2/slp2.pdf
They appear to get an output before there is an input! Surely some
mistake...
Hardy
HardySpicer wrote:
> http://www.kuee.kyoto-u.ac.jp/~kitano/paper/slp2/slp2.pdf > > They appear to get an output before there is an input! Surely some > mistake...
Unfortunately they found it had already been reported in last month's journal. ;) I once wasted an entire day trying to do that (back when I was 21 or so). These guys don't seem to have got the memo about causality. Love to see them build one that works. Cheers Phil Hobbs -- Dr Philip C D Hobbs Principal Consultant ElectroOptical Innovations LLC Optics, Electro-optics, Photonics, Analog Electronics 160 North State Road #203 Briarcliff Manor NY 10510 845-480-2058 email: hobbs (atsign) electrooptical (period) net http://electrooptical.net
No mistake. They really do appear to advance the signal. They don't actually advance it, but they do appear to. Jerry -- Engineering is the art of making what you want from things you can get.
> HardySpicer wrote: >> http://www.kuee.kyoto-u.ac.jp/~kitano/paper/slp2/slp2.pdf >> >> They appear to get an output before there is an input! Surely some >> mistake... >>
The real input is when the switch is closed. As the article itself points out, neither signal is actually delayed at all. Both appear as soon as the switch is closed. The apparent advancement of the output pulse arises because the observer is attaching an inappropriate significance to its shape. Now, you might think you could put a switch after the signal labelled input, and thereby achieve a reverse causality. But it wouldn't work as you expect. You'd see a discontinuity in the output signal that occurs at the time you open the switch, but not before. Sylvia.
"HardySpicer" <gyansorova@gmail.com> wrote in message
news:f66954fb-a6b5-4f36-9e4b-cc4140803426@x16g2000yqg.googlegroups.com...
| mistake...
| Hardy
OMG! Current leads voltage in a capacitor!  Who'd a thunk it?
Fig 7 shows a square wave input, but fig 8 is not square and
therefore not the input as claimed. Fig. 6 has two resistors both
labelled R1 and two capacitors both labelled C1, those guys
must have had too much saki.
On Fri, 08 Jul 2011 20:45:35 -0700, Les Cargill
I've read about something very similar, and it's not good: http://www.concatenation.org/futures/whatsexpected.pdf
>> >> >> >> Hardy > >Things are causal >This I know >'Cause the Second tells me so...
Why didn't I learn THAT one at age 5 in Sunday School?
On Jul 8, 10:50&#4294967295;pm, Ben Bradley <ben_u_brad...@etcmail.com> wrote:
> On Fri, 08 Jul 2011 20:45:35 -0700, Les Cargill >
> >Things are causal > >This I know > >'Cause the Second tells me so... > > &#4294967295; &#4294967295;Why didn't I learn THAT one at age 5 in Sunday School?
On Fri, 08 Jul 2011 21:34:26 -0400, Phil Hobbs
<pcdhSpamMeSenseless@electrooptical.net> wrote:
>HardySpicer wrote: >> http://www.kuee.kyoto-u.ac.jp/~kitano/paper/slp2/slp2.pdf >> >> They appear to get an output before there is an input! Surely some >> mistake... > > >Unfortunately they found it had already been reported in last month's >journal. ;) > >I once wasted an entire day trying to do that (back when I was 21 or >so). These guys don't seem to have got the memo about causality. > >Love to see them build one that works. > >Cheers > >Phil Hobbs
http://www.edn.com/article/517407-Anticipator_circuit_speeds_signal_settling_to_a_final_value.php John
> On Fri, 08 Jul 2011 20:45:35 -0700, Les Cargill > > <lcargil...@comcast.com> wrote: > >HardySpicer wrote: > >>http://www.kuee.kyoto-u.ac.jp/~kitano/paper/slp2/slp2.pdf > > >> They appear to get an output before there is an input! Surely some > >> mistake... > > &#4294967295; &#4294967295;I've read about something very similar, and it's not good: > > http://www.concatenation.org/futures/whatsexpected.pdf
That's old hat. All it takes is a dollop of thiotimoline. (Google The Endochronic Properties of Thiotimoline et seq.) ...
Unless you're older than I guess, it was old hat then too. Jerry -- Engineering is the art of making what you want from things you can get.
John Larkin wrote:
> On Fri, 08 Jul 2011 21:34:26 -0400, Phil Hobbs > <pcdhSpamMeSenseless@electrooptical.net> wrote: > >> HardySpicer wrote: >>> http://www.kuee.kyoto-u.ac.jp/~kitano/paper/slp2/slp2.pdf >>> >>> They appear to get an output before there is an input! Surely some >>> mistake... >> >> >> Unfortunately they found it had already been reported in last month's >> journal. ;) >> >> I once wasted an entire day trying to do that (back when I was 21 or >> so). These guys don't seem to have got the memo about causality. >> >> Love to see them build one that works. >> >> Cheers >> >> Phil Hobbs > > > http://www.edn.com/article/517407-Anticipator_circuit_speeds_signal_settling_to_a_final_value.php > > > John >
Okay, four months ago. Must be a better time machine than I thought. ;) (That's the one we ripped up here a few weeks ago, I remember--or is it just deja vu? Time machines are so confusing.) Cheers Phil Hobbs -- Dr Philip C D Hobbs Principal Consultant ElectroOptical Innovations LLC Optics, Electro-optics, Photonics, Analog Electronics 160 North State Road #203 Briarcliff Manor NY 10510 845-480-2058 email: hobbs (atsign) electrooptical (period) net http://electrooptical.net
