I may very well be asking this question prematurely, and I may actually already know the answer but have forgotten it. In either case, please be kind... In binary FSK demodulation, one normally puts a bandpass filter around each of the mark and space frequencies. How small can this filter be? My thoughts cycle like this: 1) We want the filter to be as small as possible to remove as much noise as possible. 2) But if the filter is too narrow compared to the baud rate, the filter output doesn't reach full output before the transmitter switches to the next baud (and thus possibly the other frequency), and so we get worse noise performance. This must be covered somewhere in the basics, but I'm missing and/or forgetting it. Memory refreshment would be appreciated! -- Randy Yates % "Watching all the days go by... Digital Signal Labs % Who are you and who am I?" mailto://yates@ieee.org % 'Mission (A World Record)', http://www.digitalsignallabs.com % *A New World Record*, ELO
Minimum Bandpass Filter Bandwidth for Binary FSK Demodulation
Started by ●July 10, 2011
Reply by ●July 10, 20112011-07-10
Randy Yates wrote:> I may very well be asking this question prematurely, and I may > actually already know the answer but have forgotten it. In either > case, please be kind... > > In binary FSK demodulation, one normally puts a bandpass filter around > each of the mark and space frequencies. How small can this filter be? > > My thoughts cycle like this: > > 1) We want the filter to be as small as possible to remove as much > noise as possible. > > 2) But if the filter is too narrow compared to the baud rate, the > filter output doesn't reach full output before the transmitter > switches to the next baud (and thus possibly the other frequency), > and so we get worse noise performance. > > This must be covered somewhere in the basics, but I'm missing and/or > forgetting it. Memory refreshment would be appreciated!It depends. If you cut off a part of the original spectrum of a signal, you will get ISI as the result. The power of ISI equals to the power of the part of the spectrum which was cut off. The over simplified view would be consider ISI as noise; hence the optimum bandwidth is when the power of noise in the bandwidth PLUS the power of ISI is at minimum. VLV
Randy Yates wrote:> I may very well be asking this question prematurely, and I may > actually already know the answer but have forgotten it. In either > case, please be kind... > > In binary FSK demodulation, one normally puts a bandpass filter around > each of the mark and space frequencies. How small can this filter be?RANDY = STUPIDENT. In AWGN, the best filter is the filter that matches the transmit pulse shape. If noise is not white, the filter should match the SNR. This is in the first page of any ABC book.
On 07/09/2011 08:47 PM, Vladimir Vassilevsky wrote:> > > Randy Yates wrote: > >> I may very well be asking this question prematurely, and I may >> actually already know the answer but have forgotten it. In either >> case, please be kind... >> >> In binary FSK demodulation, one normally puts a bandpass filter around >> each of the mark and space frequencies. How small can this filter be? > > RANDY = STUPIDENT. > > In AWGN, the best filter is the filter that matches the transmit pulse > shape. If noise is not white, the filter should match the SNR. > This is in the first page of any ABC book.Whoa -- the two faces of Vladimir. In _really old_ FSK practice (continuous phase not guaranteed, wide shift/baud ratio), you would, indeed, have filtered each frequency separately, and you would have probably used envelope detection techniques to determine mark and space (and your circuit would have had 6AU6's, 12AK6's, and the like). In that case, the optimal filter from an _overall_ standpoint would not have been matched -- you could have maybe made it, but then no one would have been able to afford your demodulator except the military. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
On 07/09/2011 08:15 PM, Randy Yates wrote:> I may very well be asking this question prematurely, and I may > actually already know the answer but have forgotten it. In either > case, please be kind... > > In binary FSK demodulation, one normally puts a bandpass filter around > each of the mark and space frequencies. How small can this filter be? > > My thoughts cycle like this: > > 1) We want the filter to be as small as possible to remove as much > noise as possible. > > 2) But if the filter is too narrow compared to the baud rate, the > filter output doesn't reach full output before the transmitter > switches to the next baud (and thus possibly the other frequency), > and so we get worse noise performance. > > This must be covered somewhere in the basics, but I'm missing and/or > forgetting it. Memory refreshment would be appreciated!What kind of FSK? What's the shift/baud ratio? In narrow FSK modes, like MSK and Bell 103 modems, the spectra of the individual tones bleed into each other (this is extreme in the MSK case, which is either PSK or FSK depending on how you look at things). In wideband FSK modes the spectra of the individual tones are distinct, and individual matched filters followed by a detection scheme that compares the power out of each filter at each bit time is the way to go. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" was written for you. See details at http://www.wescottdesign.com/actfes/actfes.html
