Compensating for microphone frequency response in FFT
Started by Tyler Mandry ●July 10, 2011
On Jul 14, 1:10&#4294967295;am, Les Cargill <lcargil...@comcast.com> wrote:
> Tyler Mandry wrote: > > On Jul 11, 1:43 am, Les Cargill<lcargil...@comcast.com> &#4294967295;wrote: > >> Tyler Mandry wrote: > >>> I'm making an application that displays an FFT of sound data from a > >>> microphone. One thing I need to be able to support is calibrating to > >>> the frequency response of the microphone, which will be given to the > >>> program via a calibration file. The calibration file contains + or - > >>> dB values for different frequencies, like this:http://pastebin.com/raw.php?i=wFBwZaTS > >>> . I can just apply the calibration after the FFT and before displaying > >>> it on the screen. > > >>> My problem is this: how should I interpolate between those values, > >>> which are essentially just select points of the whole frequency > >>> response of the microphone? A naive approach might be to define rigid > >>> rectangular bands around those points and, for each frequency in an > >>> FFT, pick one or another calibration line to apply to that frequency. > >>> This would cause visible jumps in the FFT graph, however. Another > >>> solution might be to use linear interpolation, but I'm still not sure > >>> that's the best way. > > >>> Is there a "standard" way to do this, that programs like Smaart or FFT > >>> devices do? What would be the best way to generate a continuous curve > >>> from those few fixed points? > > >> You can spline it. > > >> If the dataset just proves to be completely inadequate, you can make a > >> spark gap generator from an old strobe flash unit, some sort of spark > >> gap and an inductive loop pickup. Deconvolve the mic's read of the > >> impulse against the loop pickup's read of it. That produces a > >> convolution signature from which a response curve can be derived. > > >> Voxengo makes a good deconvolver. > > >> -- > >> Les Cargill > > > I hadn't thought about using splines, that may be the best option. > > > And while that was -very- good and interesting information on how to > > measure the impulse response of a microphone, it doesn't do me much > > good, as it's the end user of my application that will be providing > > both the microphone and calibration, and I don't think I will be > > telling them to take apart a strobe lamp in the help/how-to :). Thanks > > though, I might be able to use that someday! > > That might be a small service sub-business to go with the app... most > might be perfectly happy with the 12-point cal, but some might not... > > -- > Les Cargill
What kind of service do you mean? I think I will be allowing as many points as the user wants.
