Nomenclature question - what does LTI imply
Started by Richard Owlett ●August 1, 2011
On Tue, 02 Aug 2011 14:27:59 -0400, robert bristow-johnson wrote:
> On 8/2/11 12:51 PM, Tim Wescott wrote: >> On Tue, 02 Aug 2011 06:28:21 +0000, glen herrmannsfeldt wrote: >> >>> Tim Wescott<tim@seemywebsite.com> wrote: >>> >>> (snip, someone wrote) >>>>> IIRC all the LTI networks I encountered in class were also >>>>> *PASSIVE*. >>> >>> (snip) >>>> Linear and Time Invariant don't depend on passivity (there is, by the >>>> way, a method of nonlinear systems stability analysis where you try >>>> to determine if subsystems are effectively passive, and use that to >>>> prove overall stability). >>> >>> It seems to me, though, that passive systems are close to linear over >>> a wider range. (snip) >> >> Diodes are passive. > > so are op-amps when no power is connected to them. > >> Perhaps it's safe to say that it's easier to get linear operation over >> a wider range with passive (electronic) components than with active >> ones. > > passivity and linearity (and/or time-invariancy) are orthogonal > concepts. R's L's and C's are passive and linear. nicely biased > transistors and op-amps are active and, over some range, decently > linear. negative feedback using linear components (like resistors) can > make a decently linear amplifier *very* linear. > > "active" means you need to hook on external power from somewhere to make > it work. "linear" means the operation performed on a sum of signals is > the same as the sum of the same operation performed on each signal > individually. even though DSP systems are, strictly speaking, "active", > that goes without saying and "active" vs. "passive" just is not in the > lexicon for algs running in a DSP. "linear" vs. "non-linear" surely is. > "time-variant" vs. "time-invariant"
I'm not sure what your point is. If you mean that because mathematically passivity and linearity are orthogonal concepts that one can't talk about passive components being easier to make linear -- well: Position and wetness are mathematically orthogonal concepts. But if go to latitude 45N, and longitude 125W, then go a few hundred miles east to latitude 45N and 120W, you may find that in the real world, mathematically orthogonal concepts ain't so orthogonal any more. -- www.wescottdesign.com
>On Tue, 02 Aug 2011 14:27:59 -0400, robert bristow-johnson wrote: > >> On 8/2/11 12:51 PM, Tim Wescott wrote: >>> On Tue, 02 Aug 2011 06:28:21 +0000, glen herrmannsfeldt wrote: >>> >>>> Tim Wescott<tim@seemywebsite.com> wrote: >>>> >>>> (snip, someone wrote) >>>>>> IIRC all the LTI networks I encountered in class were also >>>>>> *PASSIVE*. >>>> >>>> (snip) >>>>> Linear and Time Invariant don't depend on passivity (there is, by
the
>>>>> way, a method of nonlinear systems stability analysis where you try >>>>> to determine if subsystems are effectively passive, and use that to >>>>> prove overall stability). >>>> >>>> It seems to me, though, that passive systems are close to linear over >>>> a wider range. (snip) >>> >>> Diodes are passive. >> >> so are op-amps when no power is connected to them. >> >>> Perhaps it's safe to say that it's easier to get linear operation over >>> a wider range with passive (electronic) components than with active >>> ones. >> >> passivity and linearity (and/or time-invariancy) are orthogonal >> concepts. R's L's and C's are passive and linear. nicely biased >> transistors and op-amps are active and, over some range, decently >> linear. negative feedback using linear components (like resistors) can >> make a decently linear amplifier *very* linear. >> >> "active" means you need to hook on external power from somewhere to
make
>> it work. "linear" means the operation performed on a sum of signals is >> the same as the sum of the same operation performed on each signal >> individually. even though DSP systems are, strictly speaking,
"active",
>> that goes without saying and "active" vs. "passive" just is not in the >> lexicon for algs running in a DSP. "linear" vs. "non-linear" surely
is.
>> "time-variant" vs. "time-invariant" > >I'm not sure what your point is. If you mean that because mathematically
>passive components being easier to make linear -- well: > >Position and wetness are mathematically orthogonal concepts. But if go >to latitude 45N, and longitude 125W, then go a few hundred miles east to >latitude 45N and 120W, you may find that in the real world, >mathematically orthogonal concepts ain't so orthogonal any more.
Are passive components easy to make linear? An air cored inductor is pretty linear at low frequencies, but doesn't have infinite bandwidth. A ferrite cored inductor isn't very linear at all. Electrolytic capacitors and many modern SMD non-electrolytics aren't very linear. All capacitors have a breakdown voltage, too. Carbon resistors are pretty linear, but they also have breakdown issues, and for small SMDs the breakdown voltage may not be that high. So, I'm not sure that passives are any more linear than active devices. None of these look very linear outside their "safe zone". Steve
Hi,
this sounds like an operational amplifier.
L-inear is equivalent with the amplification - a scaling factor.
T-ime-I-nvariant means that it could be done any time - now, tomorrow in
two years - and the output will always be the same.
Am 02.08.2011 04:39, schrieb Richard Owlett:
> It's been ~40 years since I took a "Signals and Systems" course and > never used most of it in the "real world" ;/ > > Recently I've been thinking -- an admittedly dangerous hobby. > > IIRC all the LTI networks I encountered in class were also *PASSIVE*. > > But now I'm musing on two port multi node networks with some internal > couplings being ideal unity gain amplifiers (infinite input impedance > and zero output impedance). > > Are there gotchas? > If so, what is/are keyword(s) for Google search? > > TIA > >
On Tue, 02 Aug 2011 21:02:13 -0500, steveu wrote:
>>On Tue, 02 Aug 2011 14:27:59 -0400, robert bristow-johnson wrote: >> >>> On 8/2/11 12:51 PM, Tim Wescott wrote: >>>> On Tue, 02 Aug 2011 06:28:21 +0000, glen herrmannsfeldt wrote: >>>> >>>>> Tim Wescott<tim@seemywebsite.com> wrote: >>>>> >>>>> (snip, someone wrote) >>>>>>> IIRC all the LTI networks I encountered in class were also >>>>>>> *PASSIVE*. >>>>> >>>>> (snip) >>>>>> Linear and Time Invariant don't depend on passivity (there is, by > the >>>>>> way, a method of nonlinear systems stability analysis where you try >>>>>> to determine if subsystems are effectively passive, and use that to >>>>>> prove overall stability). >>>>> >>>>> It seems to me, though, that passive systems are close to linear >>>>> over a wider range. (snip) >>>> >>>> Diodes are passive. >>> >>> so are op-amps when no power is connected to them. >>> >>>> Perhaps it's safe to say that it's easier to get linear operation >>>> over a wider range with passive (electronic) components than with >>>> active ones. >>> >>> passivity and linearity (and/or time-invariancy) are orthogonal >>> concepts. R's L's and C's are passive and linear. nicely biased >>> transistors and op-amps are active and, over some range, decently >>> linear. negative feedback using linear components (like resistors) >>> can make a decently linear amplifier *very* linear. >>> >>> "active" means you need to hook on external power from somewhere to > make >>> it work. "linear" means the operation performed on a sum of signals >>> is the same as the sum of the same operation performed on each signal >>> individually. even though DSP systems are, strictly speaking, > "active", >>> that goes without saying and "active" vs. "passive" just is not in the >>> lexicon for algs running in a DSP. "linear" vs. "non-linear" surely > is. >>> "time-variant" vs. "time-invariant" >> >>I'm not sure what your point is. If you mean that because >>mathematically > >>passivity and linearity are orthogonal concepts that one can't talk >>about > >>passive components being easier to make linear -- well: >> >>Position and wetness are mathematically orthogonal concepts. But if go >>to latitude 45N, and longitude 125W, then go a few hundred miles east to >>latitude 45N and 120W, you may find that in the real world, >>mathematically orthogonal concepts ain't so orthogonal any more. > > Are passive components easy to make linear? An air cored inductor is > pretty linear at low frequencies, but doesn't have infinite bandwidth. A > ferrite cored inductor isn't very linear at all. Electrolytic capacitors > and many modern SMD non-electrolytics aren't very linear. All capacitors > have a breakdown voltage, too. Carbon resistors are pretty linear, but > they also have breakdown issues, and for small SMDs the breakdown > voltage may not be that high. So, I'm not sure that passives are any > more linear than active devices. None of these look very linear outside > their "safe zone".
I believe it's more a matter that active components tend to have a much narrower range of values over which they are linear than passives. As mentioned elsewhere in this thread, most circuit design with active components involves wrapping them with feedback, and trading a considerable amount of amplification in return for a greater linear range, with the feedback coming from passive components. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
steveu <steveu@n_o_s_p_a_m.coppice.org> wrote:
(snip on linearity and active/passive devices)
> Are passive components easy to make linear? An air cored inductor > is pretty linear at low frequencies, but doesn't have infinite > bandwidth.
Yes, many materials are pretty linear at frequencies up to and through the optical range.
> A ferrite cored inductor isn't very linear at all. Electrolytic > capacitors and many modern SMD non-electrolytics aren't very linear. > All capacitors have a breakdown voltage, too.
Yes. It isn't so hard to make them linear in the sense here, but keeping the inductance low isn't so easy.
> Carbon resistors are pretty linear, but they also have > breakdown issues, and for small SMDs the breakdown voltage > may not be that high.
Yes, but they work over a reasonably wide frequency range. Graphite is black, as it is a resistor at optical frequencies, absorbing the incoming wave.
> So, I'm not sure that passives are any more linear than > active devices. None of these look very linear outside > their "safe zone".
Well, there are two considerations. One is frequency and the other is breakdown voltage. -- glen
>steveu <steveu@n_o_s_p_a_m.coppice.org> wrote: > >(snip on linearity and active/passive devices) > >> Are passive components easy to make linear? An air cored inductor >> is pretty linear at low frequencies, but doesn't have infinite >> bandwidth. > >Yes, many materials are pretty linear at frequencies up to and through >the optical range. > >> A ferrite cored inductor isn't very linear at all. Electrolytic >> capacitors and many modern SMD non-electrolytics aren't very linear. >> All capacitors have a breakdown voltage, too. > >Yes. It isn't so hard to make them linear in the sense here, >but keeping the inductance low isn't so easy. > >> Carbon resistors are pretty linear, but they also have >> breakdown issues, and for small SMDs the breakdown voltage >> may not be that high. > >Yes, but they work over a reasonably wide frequency range. >Graphite is black, as it is a resistor at optical frequencies, >absorbing the incoming wave. > >> So, I'm not sure that passives are any more linear than >> active devices. None of these look very linear outside >> their "safe zone". > >Well, there are two considerations. One is frequency and the >other is breakdown voltage.
There are others, like slowly forming and relaxing polarisation effects in dielectrics. Many materials we use in electronics demonstrate these effects. Try laying your hand on a flexible PCB and you obviously affect the capacitance. Try holding your hand there for a couple of minutes, and then remove it. With some substrates the capacitance immediately returns to its original level. With others it can take a minute or two to return. The effect is quite strong with some varieties of kapton. You have to be really careful choosing materials for things like capacitive touch sensors because of this. Similar effects happen in many capacitors. You will find the effective capacitance loading an AC signal is dependent on the DC content of that signal, and the time for which the DC has been present. Its a similar polarisation effect to the PCB one. A lot of passive components are far less LTI than they appear at first sight. Its just easier to see the non-LTI behaviour in an amp. Steve
