Hi, Is there a fix for this issue? ---> http://permalink.gmane.org/gmane.comp.audio.compression.speex.devel/2959 I am seeing the same thing when I compile speex in visualdsp These are the errors I get from using the assembly version of vq_nbest: ..\..\..\..\algorithms\voice\speex\src\vq.c [Error ea5004] "C:\Users\coder\AppData\Local\Temp \acc22e8547f000\acc22e8547f001.s":482 Syntax Error in : LOOP vq_loopR2= LC0 = P4; syntax error is at or near text '='. Attempting error recovery by ignoring text until the ';' [Error ea5004] "C:\Users\coder\AppData\Local\Temp \acc22e8547f000\acc22e8547f001.s":483 Syntax Error in : LOOP_BEGIN vq_loopR2=; syntax error is at or near text '='. Attempting error recovery by ignoring text until the ';' [Error ea5004] "C:\Users\coder\AppData\Local\Temp \acc22e8547f000\acc22e8547f001.s":485 Syntax Error in : LOOP_END vq_loopR2=; syntax error is at or near text '='. Attempting error recovery by ignoring text until the ';' [Error ea5004] "C:\Users\coder\AppData\Local\Temp \acc22e8547f000\acc22e8547f001.s":650 Syntax Error in : LOOP entries_loopR4= LC0; syntax error is at or near text '='. Attempting error recovery by ignoring text until the ';' [Error ea5004] "C:\Users\coder\AppData\Local\Temp \acc22e8547f000\acc22e8547f001.s":651 Syntax Error in : LOOP_BEGIN entries_loopR4=; syntax error is at or near text '='. Attempting error recovery by ignoring text until the ';' [Error ea5004] "C:\Users\coder\AppData\Local\Temp \acc22e8547f000\acc22e8547f001.s":656 Syntax Error in : LOOP vq_loopR4= LC1 = P1; syntax error is at or near text '='. Attempting error recovery by ignoring text until the ';' [Error ea5004] "C:\Users\coder\AppData\Local\Temp \acc22e8547f000\acc22e8547f001.s":657 Syntax Error in : LOOP_BEGIN vq_loopR4=; syntax error is at or near text '='. Attempting error recovery by ignoring text until the ';' [Error ea5004] "C:\Users\coder\AppData\Local\Temp \acc22e8547f000\acc22e8547f001.s":659 Syntax Error in : LOOP_END vq_loopR4=; syntax error is at or near text '='. Attempting error recovery by ignoring text until the ';' [Error ea5004] "C:\Users\coder\AppData\Local\Temp \acc22e8547f000\acc22e8547f001.s":665 Syntax Error in : LOOP_END entries_loopR4=; syntax error is at or near text '='. Attempting error recovery by ignoring text until the ';' Previous errors prevent assembly Assembler totals: 9 error(s) and 0 warning(s) cc3089: fatal error: Assembler failed Tool failed with exit/exception code: 1. Build was unsuccessful. void vq_nbest(i16 *in, const i16 *codebook, int len, int entries, i32 *E, int N, int *nbest, i32 *best_dist, i8 *stack) { if (N == 1) { best_dist[0] = 2147483647; { i32 dist; __asm__ __volatile__ ( "LC0 = %8;\n\t" "R2 = 0;\n\t" "I0 = %6;\n\t" "B0 = %6;\n\t" "L0 = %9;\n\t" "LOOP entries_loop%= LC0;\n\t" "LOOP_BEGIN entries_loop%=;\n\t" "%0 = [%4++];\n\t" "%0 >>= 1;\n\t" "A0 = %0;\n\t" "R0.L = W[%1++%7] || R1.L = W[I0++];\n\t" "LOOP vq_loop%= LC1 = %5;\n\t" "LOOP_BEGIN vq_loop%=;\n\t" "%0 = (A0 -= R0.L*R1.L) (IS) || R0.L = W[%1++%7] || R1.L = W[I0++];\n \t" "LOOP_END vq_loop%=;\n\t" "%0 = (A0 -= R0.L*R1.L) (IS);\n\t" "cc = %0 < %2;\n\t" "if cc %2 = %0;\n\t" "if cc %3 = R2;\n\t" "R2 += 1;\n\t" "LOOP_END entries_loop%=;\n\t" : "=&D" (dist), "=&a" (codebook), "=&d" (best_dist[0]), "=&d" (nbest[0]), "=&a" (E) : "a" (len-1), "a" (in), "a" (2), "d" (entries), "d" (len<<1), "1" (codebook), "4" (E), "2" (best_dist[0]), "3" (nbest[0]) : "R0", "R1", "R2", "I0", "L0", "B0", "A0", "cc", "memory" ); } } else { int i, k, used; used = 0; for (i = 0; i < entries; i++) { i32 dist; __asm__ ( "%0 >>= 1;\n\t" "A0 = %0;\n\t" "I0 = %3;\n\t" "L0 = 0;\n\t" "R0.L = W[%1++%4] || R1.L = W[I0++];\n\t" "LOOP vq_loop%= LC0 = %2;\n\t" "LOOP_BEGIN vq_loop%=;\n\t" "%0 = (A0 -= R0.L*R1.L) (IS) || R0.L = W[%1++%4] || R1.L = W[I0++];\n \t" "LOOP_END vq_loop%=;\n\t" "%0 = (A0 -= R0.L*R1.L) (IS);\n\t" : "=D" (dist), "=a" (codebook) : "a" (len-1), "a" (in), "a" (2), "1" (codebook), "0" (E[i]) : "R0", "R1", "I0", "L0", "A0" ); if (i < N || dist < best_dist[N - 1]) { for (k = N - 1; (k >= 1) && (k > used || dist < best_dist[k - 1]); k--) { best_dist[k] = best_dist[k - 1]; nbest[k] = nbest[k - 1]; } best_dist[k] = dist; nbest[k] = i; used++; } } } }
Compile Speex for Blackfin in VisualDsp
Started by ●August 2, 2011
