On 8/7/11 7:52 PM, Tim Wescott wrote:> On Sun, 07 Aug 2011 17:34:05 -0500, DonMack wrote: > >> "Tim" wrote in message >> news:NsednU-bJLX4eaPTnZ2dnUVZ_t2dnZ2d@web-ster.com... >> >> Please answer without looking at Wikipedia or otherwise finding the >> answer. Please answer, even if the answer is "no". I'm trying to get a >> measure of the extent of a bit of knowledge, here: >> >> How many of you know, off the top of your head, that the defining >> characteristic of a linear system is superposition? >> >> That if a system obeys superposition it must be linear? >> >> The difference between a time-varying and a non-linear system? >> >> Why the fact that a system obeys superposition vastly eases the task of >> analyzing its dynamic behavior? >>...> > Thanks for the answer, Don. > > Thanks also for pointing out that superposition does not always imply > linearity -- IIRC, it does either for any 'reasonable' signal or any > 'reasonable' system, but there is some combination of oddball signals and/ > or oddball systems that exemplifies the opposite. >Tim, didn't Dilip Sarwate set you straight? he emailed me right after you posted (and i replied to) this thread. in 2009 Dilip pointed out simply that complex conjugation satisfies superposition, but not scaling (where i've been thinking that scaling comes from superposition). and i realized that the same also applies to the Re{} and Im{} operators. for real signals and scalers, i think that superposition will lead you to scaling (so superposition is all that is needed), but i don't know exactly how to take it to the irrational scalers. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Systems Knowledge Question
Started by ●August 7, 2011
Reply by ●August 7, 20112011-08-07
On 8/7/2011 9:11 PM, robert bristow-johnson wrote:> On 8/7/11 7:52 PM, Tim Wescott wrote: >> On Sun, 07 Aug 2011 17:34:05 -0500, DonMack wrote: >> >>> "Tim" wrote in message >>> news:NsednU-bJLX4eaPTnZ2dnUVZ_t2dnZ2d@web-ster.com... >>> >>> Please answer without looking at Wikipedia or otherwise finding the >>> answer. Please answer, even if the answer is "no". I'm trying to get a >>> measure of the extent of a bit of knowledge, here: >>> >>> How many of you know, off the top of your head, that the defining >>> characteristic of a linear system is superposition? >>> >>> That if a system obeys superposition it must be linear? >>> >>> The difference between a time-varying and a non-linear system? >>> >>> Why the fact that a system obeys superposition vastly eases the task of >>> analyzing its dynamic behavior? >>> > ... >> >> Thanks for the answer, Don. >> >> Thanks also for pointing out that superposition does not always imply >> linearity -- IIRC, it does either for any 'reasonable' signal or any >> 'reasonable' system, but there is some combination of oddball signals >> and/ >> or oddball systems that exemplifies the opposite. >> > > Tim, didn't Dilip Sarwate set you straight? he emailed me right after > you posted (and i replied to) this thread. > > in 2009 Dilip pointed out simply that complex conjugation satisfies > superposition, but not scaling (where i've been thinking that scaling > comes from superposition). and i realized that the same also applies to > the Re{} and Im{} operators. > > for real signals and scalers, i think that superposition will lead you > to scaling (so superposition is all that is needed), but i don't know > exactly how to take it to the irrational scalers. > >Scalers: http://en.wikipedia.org/wiki/Scaler Scalars: http://en.wikipedia.org/wiki/Scalar
Reply by ●August 8, 20112011-08-08
On 8/7/11 10:18 PM, John S wrote:> On 8/7/2011 9:11 PM, robert bristow-johnson wrote: >> On 8/7/11 7:52 PM, Tim Wescott wrote: >>> On Sun, 07 Aug 2011 17:34:05 -0500, DonMack wrote: >>> >>>> "Tim" wrote in message >>>> news:NsednU-bJLX4eaPTnZ2dnUVZ_t2dnZ2d@web-ster.com... >>>> >>>> Please answer without looking at Wikipedia or otherwise finding the >>>> answer. Please answer, even if the answer is "no". I'm trying to get a >>>> measure of the extent of a bit of knowledge, here: >>>> >>>> How many of you know, off the top of your head, that the defining >>>> characteristic of a linear system is superposition? >>>> >>>> That if a system obeys superposition it must be linear? >>>> >>>> The difference between a time-varying and a non-linear system? >>>> >>>> Why the fact that a system obeys superposition vastly eases the task of >>>> analyzing its dynamic behavior? >>>> >> ... >>> >>> Thanks for the answer, Don. >>> >>> Thanks also for pointing out that superposition does not always imply >>> linearity -- IIRC, it does either for any 'reasonable' signal or any >>> 'reasonable' system, but there is some combination of oddball signals >>> and/ >>> or oddball systems that exemplifies the opposite. >>> >> >> Tim, didn't Dilip Sarwate set you straight? he emailed me right after >> you posted (and i replied to) this thread. >> >> in 2009 Dilip pointed out simply that complex conjugation satisfies >> superposition, but not scaling (where i've been thinking that scaling >> comes from superposition). and i realized that the same also applies to >> the Re{} and Im{} operators. >> >> for real signals and scalers, i think that superposition will lead you >> to scaling (so superposition is all that is needed), but i don't know >> exactly how to take it to the irrational scalers. >> >> > > Scalers: > http://en.wikipedia.org/wiki/Scaler > > Scalars: > http://en.wikipedia.org/wiki/Scalarit's good to know. sometimes it's dependence instead of dependance (or is it defendent vs. defendant?) phasers vs. phasors (one is star trek, the other is reactive circuits). -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
On Sun, 07 Aug 2011 21:18:37 -0500, John S wrote:> On 8/7/2011 9:11 PM, robert bristow-johnson wrote: >> On 8/7/11 7:52 PM, Tim Wescott wrote: >>> On Sun, 07 Aug 2011 17:34:05 -0500, DonMack wrote: >>> >>>> "Tim" wrote in message >>>> news:NsednU-bJLX4eaPTnZ2dnUVZ_t2dnZ2d@web-ster.com... >>>> >>>> Please answer without looking at Wikipedia or otherwise finding the >>>> answer. Please answer, even if the answer is "no". I'm trying to get >>>> a measure of the extent of a bit of knowledge, here: >>>> >>>> How many of you know, off the top of your head, that the defining >>>> characteristic of a linear system is superposition? >>>> >>>> That if a system obeys superposition it must be linear? >>>> >>>> The difference between a time-varying and a non-linear system? >>>> >>>> Why the fact that a system obeys superposition vastly eases the task >>>> of analyzing its dynamic behavior? >>>> >> ... >>> >>> Thanks for the answer, Don. >>> >>> Thanks also for pointing out that superposition does not always imply >>> linearity -- IIRC, it does either for any 'reasonable' signal or any >>> 'reasonable' system, but there is some combination of oddball signals >>> and/ >>> or oddball systems that exemplifies the opposite. >>> >>> >> Tim, didn't Dilip Sarwate set you straight? he emailed me right after >> you posted (and i replied to) this thread. >> >> in 2009 Dilip pointed out simply that complex conjugation satisfies >> superposition, but not scaling (where i've been thinking that scaling >> comes from superposition). and i realized that the same also applies to >> the Re{} and Im{} operators. >> >> for real signals and scalers, i think that superposition will lead you >> to scaling (so superposition is all that is needed), but i don't know >> exactly how to take it to the irrational scalers. >> >> >> > Scalers: > http://en.wikipedia.org/wiki/Scaler > > Scalars: > http://en.wikipedia.org/wiki/ScalarI thought it was going to be this: http://en.wikipedia.org/wiki/Log_scaler. There _are_ rational scalers: in some states when you do the computation for log scaling off of state lands you have to stick a '3' into the equation where one would normally stick pi*. So in those states, scaling _is_ rational! * This has to be part of the source of the "such-and-such a state legislates that pi = 3" hoopla. The truth is that the stuff is going out to bid, and everyone knows how its calculated, so you could stick _any_ number** in there and the prices would still be the same. ** I vote for 42, in memory of Douglas Adams. -- www.wescottdesign.com
On Sun, 07 Aug 2011 23:39:27 -0400, robert bristow-johnson wrote:> On 8/7/11 10:18 PM, John S wrote: >> On 8/7/2011 9:11 PM, robert bristow-johnson wrote: >>> On 8/7/11 7:52 PM, Tim Wescott wrote: >>>> On Sun, 07 Aug 2011 17:34:05 -0500, DonMack wrote: >>>> >>>>> "Tim" wrote in message >>>>> news:NsednU-bJLX4eaPTnZ2dnUVZ_t2dnZ2d@web-ster.com... >>>>> >>>>> Please answer without looking at Wikipedia or otherwise finding the >>>>> answer. Please answer, even if the answer is "no". I'm trying to get >>>>> a measure of the extent of a bit of knowledge, here: >>>>> >>>>> How many of you know, off the top of your head, that the defining >>>>> characteristic of a linear system is superposition? >>>>> >>>>> That if a system obeys superposition it must be linear? >>>>> >>>>> The difference between a time-varying and a non-linear system? >>>>> >>>>> Why the fact that a system obeys superposition vastly eases the task >>>>> of analyzing its dynamic behavior? >>>>> >>> ... >>>> >>>> Thanks for the answer, Don. >>>> >>>> Thanks also for pointing out that superposition does not always imply >>>> linearity -- IIRC, it does either for any 'reasonable' signal or any >>>> 'reasonable' system, but there is some combination of oddball signals >>>> and/ >>>> or oddball systems that exemplifies the opposite. >>>> >>>> >>> Tim, didn't Dilip Sarwate set you straight? he emailed me right after >>> you posted (and i replied to) this thread. >>> >>> in 2009 Dilip pointed out simply that complex conjugation satisfies >>> superposition, but not scaling (where i've been thinking that scaling >>> comes from superposition). and i realized that the same also applies >>> to the Re{} and Im{} operators. >>> >>> for real signals and scalers, i think that superposition will lead you >>> to scaling (so superposition is all that is needed), but i don't know >>> exactly how to take it to the irrational scalers. >>> >>> >>> >> Scalers: >> http://en.wikipedia.org/wiki/Scaler >> >> Scalars: >> http://en.wikipedia.org/wiki/Scalar > > it's good to know. sometimes it's dependence instead of dependance (or > is it defendent vs. defendant?) phasers vs. phasors (one is star trek, > the other is reactive circuits).I'll bet those phasers have reactive circuits in them, though. -- www.wescottdesign.com
>Please answer without looking at Wikipedia or otherwise finding the >answer. Please answer, even if the answer is "no". I'm trying to get a >measure of the extent of a bit of knowledge, here: > >How many of you know, off the top of your head, that the defining >characteristic of a linear system is superposition?Isn't that backwards? Isn't it a defining quality of a system obeying superposition, that all its branches must be linear?>That if a system obeys superposition it must be linear?That seems like a consequence of the above.>The difference between a time-varying and a non-linear system?They don't seem to be intimately connected. x^2 is non-linear, but doesn't vary with time. x+t has a steadily sweeping DC offset, which is clearly a timer varying response, but doesn't have a non-linear element - until it hits an end-stop somewhere in the real world.>Why the fact that a system obeys superposition vastly eases the task of >analyzing its dynamic behavior?If the system obeys superposition you can break it into a number of sections, in a simple way, and independently analyse each of them. Is that form of simplification what you are looking for? I can't really see where this series of questions is going. Steve
>>Please answer without looking at Wikipedia or otherwise finding the >>answer. Please answer, even if the answer is "no". I'm trying to get a>>measure of the extent of a bit of knowledge, here: >> >>How many of you know, off the top of your head, that the defining >>characteristic of a linear system is superposition? > >Isn't that backwards? Isn't it a defining quality of a system obeying >superposition, that all its branches must be linear?Sorry, I was thinking of the wrong kind of superposition (superposition in network analysis) when I wrote that. My mind was already on the wrong path when I read the question. :-\ Regards, Steve
Am 08.08.2011 04:11, schrieb robert bristow-johnson:> On 8/7/11 7:52 PM, Tim Wescott wrote:>> Thanks for the answer, Don. >> >> Thanks also for pointing out that superposition does not always imply >> linearity -- IIRC, it does either for any 'reasonable' signal or any >> 'reasonable' system, but there is some combination of oddball signals >> and/ >> or oddball systems that exemplifies the opposite. >> > > Tim, didn't Dilip Sarwate set you straight? he emailed me right after > you posted (and i replied to) this thread. > > in 2009 Dilip pointed out simply that complex conjugation satisfies > superposition, but not scaling (where i've been thinking that scaling > comes from superposition). and i realized that the same also applies to > the Re{} and Im{} operators.This is because "linearity" is not well-defined. Speaking as a mathematician, there is "real-linearity" as in: superposition under addition of terms and multiplication with real scalars, and "complex-linearity" which also implies linearity under multiplication of complex scalars. Of course complex conjugation is real-linear, but complex-antilinear (this is the point!), and hence, all linear combinations of conjugation and non-conjugation, as Re() and Im() are hence also real-linear, but not complex-linear.> for real signals and scalers, i think that superposition will lead you > to scaling (so superposition is all that is needed), but i don't know > exactly how to take it to the irrational scalers.You need continuity of the operation in question. Without that, of course, not. With that, it is trivial: Every real number can be sufficiently closely approximated by a rational number, and by continuity, then you have linearity in the limit as well. Greetings, Thomas
robert bristow-johnson wrote:> On 8/7/11 10:18 PM, John S wrote: >> On 8/7/2011 9:11 PM, robert bristow-johnson wrote: >>> On 8/7/11 7:52 PM, Tim Wescott wrote: >>>> On Sun, 07 Aug 2011 17:34:05 -0500, DonMack wrote: >>>> >>>>> "Tim" wrote in message >>>>> news:NsednU-bJLX4eaPTnZ2dnUVZ_t2dnZ2d@web-ster.com... >>>>> >>>>> Please answer without looking at Wikipedia or otherwise finding the >>>>> answer. Please answer, even if the answer is "no". I'm trying to get a >>>>> measure of the extent of a bit of knowledge, here: >>>>> >>>>> How many of you know, off the top of your head, that the defining >>>>> characteristic of a linear system is superposition? >>>>> >>>>> That if a system obeys superposition it must be linear? >>>>> >>>>> The difference between a time-varying and a non-linear system? >>>>> >>>>> Why the fact that a system obeys superposition vastly eases the >>>>> task of >>>>> analyzing its dynamic behavior? >>>>> >>> ... >>>> >>>> Thanks for the answer, Don. >>>> >>>> Thanks also for pointing out that superposition does not always imply >>>> linearity -- IIRC, it does either for any 'reasonable' signal or any >>>> 'reasonable' system, but there is some combination of oddball signals >>>> and/ >>>> or oddball systems that exemplifies the opposite. >>>> >>> >>> Tim, didn't Dilip Sarwate set you straight? he emailed me right after >>> you posted (and i replied to) this thread. >>> >>> in 2009 Dilip pointed out simply that complex conjugation satisfies >>> superposition, but not scaling (where i've been thinking that scaling >>> comes from superposition). and i realized that the same also applies to >>> the Re{} and Im{} operators. >>> >>> for real signals and scalers, i think that superposition will lead you >>> to scaling (so superposition is all that is needed), but i don't know >>> exactly how to take it to the irrational scalers. >>> >>> >> >> Scalers: >> http://en.wikipedia.org/wiki/Scaler >> >> Scalars: >> http://en.wikipedia.org/wiki/Scalar > > it's good to know. sometimes it's dependence instead of dependance (or > is it defendent vs. defendant?) phasers vs. phasors (one is star trek, > the other is reactive circuits). >Back in 60's the joke was of form "Yesterday I couldn't spall engineur, now I are one" ;)
Reply by ●August 9, 20112011-08-09
On 08/07/2011 03:15 PM, Tim wrote:> Please answer without looking at Wikipedia or otherwise finding the > answer. Please answer, even if the answer is "no". I'm trying to get a > measure of the extent of a bit of knowledge, here: > > How many of you know, off the top of your head, that the defining > characteristic of a linear system is superposition? > > That if a system obeys superposition it must be linear? > > The difference between a time-varying and a non-linear system? > > Why the fact that a system obeys superposition vastly eases the task of > analyzing its dynamic behavior? > > Thanks. >You have to be a bit careful about your universe of basis functions, though--the usual definition requires scale invariance as well as superposition--you have to be able to multiply your signal by any real number and have the response come out multiplied by the same factor. You also need time-invariance if you want the usual linear systems theory to hold. And there are generalizations, e.g. an analogue multiplier, which is a bilinear system. Cheers Phil Hobbs -- Dr Philip C D Hobbs Principal Consultant ElectroOptical Innovations LLC Optics, Electro-optics, Photonics, Analog Electronics 160 North State Road #203 Briarcliff Manor NY 10510 845-480-2058 hobbs at electrooptical dot net http://electrooptical.net
