On 8/7/2011 12:15 PM, Tim wrote:> Please answer without looking at Wikipedia or otherwise finding the > answer. Please answer, even if the answer is "no". I'm trying to get a > measure of the extent of a bit of knowledge, here: > > How many of you know, off the top of your head, that the defining > characteristic of a linear system is superposition?I don't know yet. Let's wait and see how many. But, if you're asking "is the defining characteristic of a linear system superposition?" I would say Yes.> > That if a system obeys superposition it must be linear?Yes.> > The difference between a time-varying and a non-linear system?Yes, I know the difference.> > Why the fact that a system obeys superposition vastly eases the task of > analyzing its dynamic behavior?Yes? I'm better at arithmetic than other processes? Fred
Systems Knowledge Question
Started by ●August 7, 2011
Reply by ●August 9, 20112011-08-09
Fred Marshall <fmarshallxremove_the_x@acm.org> wrote:> On 8/7/2011 12:15 PM, Tim wrote: >> Please answer without looking at Wikipedia or otherwise finding the >> answer. Please answer, even if the answer is "no". I'm trying to get a >> measure of the extent of a bit of knowledge, here:>> How many of you know, off the top of your head, that the defining >> characteristic of a linear system is superposition?It is, at least, in physics. (Whether I would remember that if asked out of context, I am not so sure.) I think it is the other way around in math. That is, superposition is a characteristic of linear systems, which result from linear operators. In learning to solve differential equations, you first learn linear equations with constant coefficients. Not because of superposition (yet), but because the techniques are easier. Then, a little later, you learn that for linear differential equations the sum of solutions is also a solution (superposition, but usually not using that word.) For non-homogeneous linear equations, the solution is a linear combination of the homogeneous solutions, plus one solution to the non-homogeneous equation. It seems that in math terms, time independent means constant coefficients, assuming that time is the independent variable. -- glen
On 8/9/11 5:08 PM, Fred Marshall wrote:> On 8/7/2011 12:15 PM, Tim wrote: >> Please answer without looking at Wikipedia or otherwise finding the >> answer. Please answer, even if the answer is "no". I'm trying to get a >> measure of the extent of a bit of knowledge, here: >> >> How many of you know, off the top of your head, that the defining >> characteristic of a linear system is superposition? > > I don't know yet. Let's wait and see how many. > But, if you're asking "is the defining characteristic of a linear system > superposition?" > I would say Yes. > >> >> That if a system obeys superposition it must be linear? > > Yes.are you saying "yes" that you know this or "yes" that superposition *must* imply linearity? because i used to say yes to both, but i was mistaken regarding linear systems operating with complex quantities. recently my misconception was corrected by Dilip (for which i am grateful for). for real signals and real scalars (is it "a" or "e"?), you can show that superposition is sufficient for the scaling property for rational scalars. i think you need one more assumption of continuity to extend it to every real scalar. but Dilip pointed out that a system that performs the complex conjugate of the input does satisfy superposition but does *not* have the scaling property. to be linear, the scalar should be moved from inside the operator to outside without being conjugated. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Reply by ●August 10, 20112011-08-10
On 10/08/2011 00:05, robert bristow-johnson wrote: ..> for real signals and real scalars (is it "a" or "e"?),"a". the word "scaler" means something like "someone [or something] who scales". Scalar is the maths term, scaler applies to some form of action. I can't think of another a/e pair offhand, but will report it here if I find one. Richard Dobson
On Aug 10, 4:12�am, Richard Dobson <richarddob...@blueyonder.co.uk> wrote:> On 10/08/2011 00:05, robert bristow-johnson wrote: > .. > > > for real signals and real scalars (is it "a" or "e"?), > > "a". �the word "scaler" means something like "someone [or something] who > scales". Scalar is the maths term, scaler applies to some form of > action. I can't think of another a/e pair offhand, but will report it > here if I find one. > > Richard DobsonNot a/e, but compliment and complement are often misused. Therefor/ therefore. Ax me no questions.... Jerry -- Engineering is the art of making what you want from things you can get.
On Aug 10, 2:07�pm, Jerry Avins <j...@ieee.org> wrote: ...> Ax me no questions....affect/effect Jerry -- Engineering is the art of making what you want from things you can get.
Reply by ●August 11, 20112011-08-11
On 8/7/11 3:15 PM, Tim wrote:> > How many of you know, off the top of your head, that the defining > characteristic of a linear system is superposition? > > That if a system obeys superposition it must be linear?so Tim, can you take a clear position on this? must superposition imply linearity? i've brought this up a couple of times and haven't seen you take a stand on it. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
>On 8/7/11 3:15 PM, Tim wrote: >> >> How many of you know, off the top of your head, that the defining >> characteristic of a linear system is superposition? >> >> That if a system obeys superposition it must be linear? > >so Tim, can you take a clear position on this? must superposition imply >linearity? > >i've brought this up a couple of times and haven't seen you take a stand >on it.How very confrontational. Steve
On Wed, 10 Aug 2011 23:29:05 -0400, robert bristow-johnson wrote:> On 8/7/11 3:15 PM, Tim wrote: >> >> How many of you know, off the top of your head, that the defining >> characteristic of a linear system is superposition? >> >> That if a system obeys superposition it must be linear? > > so Tim, can you take a clear position on this? must superposition imply > linearity? > > i've brought this up a couple of times and haven't seen you take a stand > on it.That's because I was madly Wiki-ing. As near as I can tell, it's got to be superposition _and_ scaling (with complex numbers) as you said. I haven't sat down and actually done the math, although the fact that the complex conjugate operation obeys superposition certainly points to a problem in my original assertion. I was led astray because in real analysis you can start with superposition and deduce scaling -- apparently that's not the case with complex analysis. -- www.wescottdesign.com
On 8/11/11 2:42 AM, steveu wrote:>> On 8/7/11 3:15 PM, Tim wrote: >>> >>> How many of you know, off the top of your head, that the defining >>> characteristic of a linear system is superposition? >>> >>> That if a system obeys superposition it must be linear? >> >> so Tim, can you take a clear position on this? must superposition imply >> linearity? >> >> i've brought this up a couple of times and haven't seen you take a stand >> on it. > > How very confrontational.i ain't trying to be confrontational. i'm just trying to move the conversation (in the direction that the OP, Tim, had originally pointed it). first, it shouldn't surprize anyone that i respect Tim a whole lot and i have a lot of technical "sentiments" in common with him (and i should probably buy his book). but his original questions, which are just fine, are also what i would call "leading questions". it *appears* to me, that the questions are leading to a conclusion that superposition: L{ x1(t) + x2(t) } = L{ x1(t) } + L{ x2(t) } is equivalent to linearity, which in most textbooks would be superposition (as above) along with the scaling (or "homogeneity") property: L{ a*x(t) } = a*L{ x(t) } this is something i believed since college (that superposition implies scaling and thus the complete linearity property) because it was easy to see it for the case of a=2: L{ 2*x(t) } = L{ x(t) + x(t) } = L{ x(t) } + L{ x(t) } = 2*L{ x(t) } this can be extended, by the (nearly trivial) use of inductive proof, for any other real integer, N. then it can be further extended for the reciprocal of any integer, 1/M, and from that to any rational (and real) value of a = N/M . and, with any decent degree of continuity, it would also be the case for any real value of a since any irrational a can be squeezed between two rational values (where we *know* that superposition implies scaling) as tightly as you want. so, in the real world, it is true "[t]hat if a system obeys superposition it must be linear". often when some mathematical fact exists for reals, it can also be analytically extended for complex values and i was satisfied with this (without bothering to check it). but, coincidentally, the same hour that i first responded to Tim's question, i was informed of a simple counter-example for how, with ostensibly "linear" systems that deal with complex signals and scalars, it *isn't* true. that simple example is a system that outputs the complex conjugate (and similarly for systems that output only the real or imaginary part) of the complex input. here is a case where superposition holds, but scaling does not. i just wanted Tim (and/or others) to consider this and comment (after 3 or 4 days). call it "very confrontational", but it ain't nuttin' like when we fight about whether or not the DFT inherently transforms one discrete and periodic sequence of period N to another discrete and periodic sequence of the same period. we can jump into that and i may get truly confrontational. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
