Systems Knowledge Question
Started by Tim ●August 7, 2011
On 8/11/11 12:07 PM, Tim Wescott wrote:
> On Wed, 10 Aug 2011 23:29:05 -0400, robert bristow-johnson wrote: > >> On 8/7/11 3:15 PM, Tim wrote: >>> >>> How many of you know, off the top of your head, that the defining >>> characteristic of a linear system is superposition? >>> >>> That if a system obeys superposition it must be linear? >> >> so Tim, can you take a clear position on this? must superposition imply >> linearity? >> >> i've brought this up a couple of times and haven't seen you take a stand >> on it. > > That's because I was madly Wiki-ing. > > As near as I can tell, it's got to be superposition _and_ scaling (with > complex numbers) as you said. I haven't sat down and actually done the > math, although the fact that the complex conjugate operation obeys > superposition certainly points to a problem in my original assertion.
hey, 4 days ago, i was at the very same place and Dilip emailed me the obvious counter example. i thought the timing was uncanny (8/7/11 3:33 PM EDT) and thought for sure he was also in conversation with you about it. later found that this assumption (by me) was also wrong.
> > I was led astray because in real analysis you can start with > superposition and deduce scaling -- apparently that's not the case with > complex analysis.
our posts literally just "crossed in the mail". we're on the same page. in the real and continuous world, superposition is equivalent to linearity. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
imply
stand
>> on it. > >That's because I was madly Wiki-ing. > >As near as I can tell, it's got to be superposition _and_ scaling (with >complex numbers) as you said. I haven't sat down and actually done the >math, although the fact that the complex conjugate operation obeys >superposition certainly points to a problem in my original assertion. > >I was led astray because in real analysis you can start with >superposition and deduce scaling -- apparently that's not the case with >complex analysis.
If superposition works, doesn't that imply that at least non-complex scaling works? If you superposition two copies of the same thing, that's scaling it. So, shouldn't it just be superposition, and complex scaling? Steve
On 8/11/11 12:37 PM, steveu wrote:
> > If superposition works, doesn't that imply that at least non-complex > scaling works?
yes! at least for real and *rational* scalars. but you gotta also hand-wave the irrational scalar thing (i.e. another assumption of continuity). -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
On 8/7/2011 12:15 PM, Tim wrote:
> Please answer without looking at Wikipedia or otherwise finding the > answer. Please answer, even if the answer is "no". I'm trying to get a > measure of the extent of a bit of knowledge, here: > > How many of you know, off the top of your head, that the defining > characteristic of a linear system is superposition? > > That if a system obeys superposition it must be linear? >
Well yeah, that statement's downright tautological.
> The difference between a time-varying and a non-linear system? >
Sure. In a time-varying system f{a(t)} = y(t) =/> f{a(t+t0)} = y(t+t0) Whereas in a non-linear system f{a1(t)} = y1(t) AND f{a2(t)} = y2(t) =/> f{a1(t) + a2(t)} = y1(t) + y2(t)
> Why the fact that a system obeys superposition vastly eases the task of > analyzing its dynamic behavior? >
All manner of reasons. The additive property is lovely all on it's own, but the more usually useful aspect is that multiplication just runs straight through. The other is that the idea of frequency domain analysis really only applies to linear systems. The whole idea that you draw a Bode plot and have 40dB of attenuation at 5 MHz is predicated on the fact that the input signal can be decomposed into a sum of sine waves of varying frequencies, and that each of those sine waves is non-interacting; knocking down the one at 5 MHz doesn't mean anything for the one at 5 kHz. As the degree of non-linearity of the system increases that statement becomes less and less true.
> Thanks. >
-- Rob Gaddi, Highland Technology Email address is currently out of order
>> >> That if a system obeys superposition it must be linear? >> > > Well yeah, that statement's downright tautological.
it's never been tautological. and it turns out to not be entirely true (but it can be shown to be true for scalars that are real and rational, but it's still not tautological). -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
On Thu, 11 Aug 2011 15:46:57 -0400, robert bristow-johnson
>On 8/11/11 2:43 PM, Rob Gaddi wrote: >> On 8/7/2011 12:15 PM, Tim wrote: >... >>> >>> That if a system obeys superposition it must be linear? >>> >> >> Well yeah, that statement's downright tautological. > >it's never been tautological. and it turns out to not be entirely true >(but it can be shown to be true for scalars that are real and rational, >but it's still not tautological). >
I think the practicality is that it is tautological in a broad sense. I was going to respond to Tim's initial post with some of the points that have since come out, mainly that for the most part superposition and linearity nearly define each other. In the majority of cases, and even with complex-valued signals, analysis of the linearity of operations is verifiable by confiming superposition (and scaling if one wishes). The fact that there is an exception doesn't mean, to me, anyway, that it doesn't hold, it just means that one should be aware of the exception. We do this all the time for other things so I don't think it's a stretch to say "yes" to Tim's question in a general sense. It's like saying an analog signal is really analog and continuously variable, even though we know deep down that everything is quantized at the quantum physics level. It's not helpful in most conversations (or teaching) to bring the exception up in every discussion, or throw a definition out, because it may ultimately create more confusion. Even recognized non-linear operations, done with non-linear devices, like mixing, can be treated as linear if held within a region of support where the behavior is linear. Likewise an amplifier can be driven into saturation, but that doesn't mean that linear analysis isn't completely appropriate if that's the operating mode of interest. So, yes, there's an exception. It's an exception that's good to know and perhaps interesting or fun or useful to bring up when the case warrants, but generally speaking I think the broad answer to Tim's question is 'yes'. There may be a footnote but there usually is with almost all of this stuff. The more time goes by the more I think that almost any assertion with a mathematical argument behind it is more likely to be opinion than fact. ;) Eric Jacobsen http://www.ericjacobsen.org http://www.dsprelated.com/blogs-1//Eric_Jacobsen.php
robert bristow-johnson <rbj@audioimagination.com> wrote:
(snip on superposition)
> but his original questions, which are just fine, are also what i would > call "leading questions". it *appears* to me, that the questions are > leading to a conclusion that superposition:
> L{ x1(t) + x2(t) } = L{ x1(t) } + L{ x2(t) }
(snip)
> is equivalent to linearity, which in most textbooks would be > superposition (as above) along with the scaling (or "homogeneity") property:
> L{ 2*x(t) } = L{ x(t) + x(t) } > = L{ x(t) } + L{ x(t) } > = 2*L{ x(t) }
> this can be extended, by the (nearly trivial) use of inductive proof, > for any other real integer, N. then it can be further extended for the > reciprocal of any integer, 1/M, and from that to any rational (and real) > value of a = N/M .
> and, with any decent degree of continuity, it would also be the case for > any real value of a since any irrational a can be squeezed between two > rational values (where we *know* that superposition implies scaling) as > tightly as you want.
I was just reading a few days ago, a derivation of natural log: "The traditional way of defining a logarithm, log a(b) is to define it as the number u such that a**u=b. .... However, that definition has a theoretical gap. The flaw is that we have not yet defined a**u when u is an irrational number, for example sqrt(2) or pi. This gap can be filled in, but that would require an extensive and sophisticated detour*." Then a footnote: "* Some calculus textbooks just ignore this difficulty. The assume that a**u is defines shen a>0 and u is any real number and that the usual laws for exponents apply." (Schaum's outlines, Calculus, 5th edition, p. 206.) (I would probably be one to just assume it, or, as you say, take the limit.) Reminds me also how fast we go from the derivative of x**n for integers, then for rationals, and then irrationals, without any questions.
> so, in the real world, it is true "[t]hat if a system obeys > superposition it must be linear". often when some mathematical fact > exists for reals, it can also be analytically extended for complex > values and i was satisfied with this (without bothering to check it).
> but, coincidentally, the same hour that i first responded to Tim's > question, i was informed of a simple counter-example for how, with > ostensibly "linear" systems that deal with complex signals and scalars, > it *isn't* true. that simple example is a system that outputs the > complex conjugate (and similarly for systems that output only the real > or imaginary part) of the complex input. here is a case where > superposition holds, but scaling does not.
Reminding me again, that it seems that the usual mathematical derivation goes from linearity to superposition, and not the other way around. But complex conjugate is a strange operation.
> i just wanted Tim (and/or others) to consider this and comment (after 3 > or 4 days). call it "very confrontational", but it ain't nuttin' like > when we fight about whether or not the DFT inherently transforms one > discrete and periodic sequence of period N to another discrete and > periodic sequence of the same period. we can jump into that and i may > get truly confrontational.
-- glen
In comp.dsp Tim Wescott <tim@seemywebsite.com> wrote:
(snip)
> I was led astray because in real analysis you can start with > superposition and deduce scaling -- apparently that's not the > case with complex analysis.
Complex conjugate is a strange operator. What, for example, is its derivative? -- glen
On Aug 11, 1:10&#4294967295;pm, eric.jacob...@ieee.org (Eric Jacobsen) wrote:
> ... > The fact that there is an exception doesn't mean, to me, anyway, that > it doesn't hold, it just means that one should be aware of the > exception. &#4294967295;
> Eric Jacobsen
I don't think we have any exceptions here. Thomas Richter commented on both the suggested conjugational and irrational exceptions. Dilip explained that the suggested complex domain exceptions come from operations that are not linear in the complex domain in a 2009 post: **** *Nov 24 2009, 7:10 am * *Complex conjugation is not a linear operation over *the complex field. For linearity to hold, it must be *that L(cX) = cL(X) for all complex numbers c, which *is not true. Complex conjugation *is* a linear operation *if we construe complex numbers as constituting a *two-dimensional space over the real field. The mapping *(a,b) --> (a, -b) is a linear map from R^2 to R^2, while *the mapping X --> X* is not a linear map from C to C. * *Hope this helps * *Dilip Sarwate ***** Applying consistent usage of "complex" to both "operations" and "linearity" removes the exceptions. Dale B. Dalrymple
On 8/11/11 5:24 PM, dbd wrote:
> On Aug 11, 1:10 pm, eric.jacob...@ieee.org (Eric Jacobsen) wrote: >> ... >> The fact that there is an exception doesn't mean, to me, anyway, that >> it doesn't hold, it just means that one should be aware of the >> exception. > ... > > I don't think we have any exceptions here.
in which direction? linearity ==> superposition or superposition ==> linearity ? the whole issue of the thread (well, half of it, TI was the other) is whether superposition <==> linearity i used to think "yes", now it's "no". (but it's "yes" for any real and practical system that satisfies superposition.)
> Applying consistent usage of "complex" to both "operations" and > "linearity" removes the exceptions.
i can't decode that. the simple question is: are there systems (or operations) that always satisfy superposition that do not satisfy linearity? since linearity is widely defined to mean superposition *and* homogeneous in scaling then, as best as my logic can tell, the question is equivalent to: are there systems (or operations) that always satisfy superposition that do not satisfy homogeneity in scaling? i had previous thought the answer to both is "no" (with some hand-waving regarding the irrationals), but, if complex scalars and signals part of the picture, the answer is "yes" and you prove it by use of an exception that you can identify. conj{}, Re{}, and Im{} are exceptions because, i suspect, they're not analytic functions. not "analytic" in the sense of Hilbert, but in the sense of Cauchy-Riemann. (because the derivative of imag w.r.t. imag does not equal the derivative of real w.r.t. real.) i suspect that this is the reason those complex functions do not satisfy scaling (even though they do satisfy superposition) and then are not linear operators (even though they do satisfy superposition). [thanks, glen.] -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
