On Thu, 11 Aug 2011 21:05:16 +0000 (UTC), glen herrmannsfeldt <gah@ugcs.caltech.edu> wrote:>In comp.dsp Tim Wescott <tim@seemywebsite.com> wrote: >(snip) > >> That's because I was madly Wiki-ing. > >> As near as I can tell, it's got to be superposition _and_ scaling (with >> complex numbers) as you said. I haven't sat down and actually done the >> math, although the fact that the complex conjugate operation obeys >> superposition certainly points to a problem in my original assertion. > >> I was led astray because in real analysis you can start with >> superposition and deduce scaling -- apparently that's not the >> case with complex analysis. > >Complex conjugate is a strange operator. What, for example, is >its derivative? > >-- glenThe denominator of a fraction does not exist in and by itself, a more correct question is what is the derivative of the fraction? ?-)
Systems Knowledge Question
Started by ●August 7, 2011
Reply by ●August 12, 20112011-08-12
On Thu, 11 Aug 2011 11:43:18 -0700, Rob Gaddi <rgaddi@technologyhighland.com> wrote:>On 8/7/2011 12:15 PM, Tim wrote: >> Please answer without looking at Wikipedia or otherwise finding the >> answer. Please answer, even if the answer is "no". I'm trying to get a >> measure of the extent of a bit of knowledge, here: >> >> How many of you know, off the top of your head, that the defining >> characteristic of a linear system is superposition? >> >> That if a system obeys superposition it must be linear? >> > >Well yeah, that statement's downright tautological. > >> The difference between a time-varying and a non-linear system? >> > >Sure. In a time-varying system > f{a(t)} = y(t) > =/> f{a(t+t0)} = y(t+t0) > >Whereas in a non-linear system > f{a1(t)} = y1(t) AND f{a2(t)} = y2(t) > =/> f{a1(t) + a2(t)} = y1(t) + y2(t) > >> Why the fact that a system obeys superposition vastly eases the task of >> analyzing its dynamic behavior? >> > >All manner of reasons. The additive property is lovely all on it's own, >but the more usually useful aspect is that multiplication just runs >straight through. > >The other is that the idea of frequency domain analysis really only >applies to linear systems. The whole idea that you draw a Bode plot and >have 40dB of attenuation at 5 MHz is predicated on the fact that the >input signal can be decomposed into a sum of sine waves of varying >frequencies, and that each of those sine waves is non-interacting; >knocking down the one at 5 MHz doesn't mean anything for the one at 5 >kHz. As the degree of non-linearity of the system increases that >statement becomes less and less true.Well of course, both the Fourier transform and the Laplace transform are linear and consistently defined for linear systems only.> >> Thanks. >>
In comp.dsp josephkk <joseph_barrett@sbcglobal.net> wrote: (snip, someone wrote)>>> I was led astray because in real analysis you can start with >>> superposition and deduce scaling -- apparently that's not the >>> case with complex analysis.(then I wrote)>>Complex conjugate is a strange operator. What, for example, is >>its derivative?> The denominator of a fraction does not exist in and by itself, a more > correct question is what is the derivative of the fraction?If you write f(x)=conj(x), and try to compute df/dx... Yes, the denominator doesn't exist by itself, but you can take the derivative of 1/x, or a/x, or even the partial derivative of y/x. -- glen
On 08/12/2011 12:31 AM, josephkk wrote:> On Thu, 11 Aug 2011 21:05:16 +0000 (UTC), glen herrmannsfeldt > <gah@ugcs.caltech.edu> wrote: > >> In comp.dsp Tim Wescott<tim@seemywebsite.com> wrote: >> (snip) >> >>> That's because I was madly Wiki-ing. >> >>> As near as I can tell, it's got to be superposition _and_ scaling (with >>> complex numbers) as you said. I haven't sat down and actually done the >>> math, although the fact that the complex conjugate operation obeys >>> superposition certainly points to a problem in my original assertion. >> >>> I was led astray because in real analysis you can start with >>> superposition and deduce scaling -- apparently that's not the >>> case with complex analysis. >> >> Complex conjugate is a strange operator. What, for example, is >> its derivative? >> >> -- glen > > The denominator of a fraction does not exist in and by itself, a more > correct question is what is the derivative of the fraction? > > ?-)In order for a complex function u(x,y)+i*v(x,y) to have a derivative, the derivative has to be the same in all directions in the complex plane, which leads to the the Cauchy-Riemann condition, i.e. partial u/partial x = partial v/partial y and partial v/partial x = - partial u/partial y. Complex conjugate doesn't satisfy them, so it has no derivative. Cheers Phil Hobbs -- Dr Philip C D Hobbs Principal Consultant ElectroOptical Innovations LLC Optics, Electro-optics, Photonics, Analog Electronics 160 North State Road #203 Briarcliff Manor NY 10510 845-480-2058 hobbs at electrooptical dot net http://electrooptical.net
11. August schrieb robert bristow-johnson:> On 8/11/11 12:07 PM, Tim Wescott wrote: > > On Wed, 10 Aug 2011 23:29:05 -0400, robert bristow-johnson wrote: > > > >> On 8/7/11 3:15 PM, Tim wrote: > >>> > >>> How many of you know, off the top of your head, that the defining > >>> characteristic of a linear system is superposition? > >>> > >>> That if a system obeys superposition it must be linear? > >> > >> so Tim, can you take a clear position on this? must superposition imply > >> linearity? > >> > >> i've brought this up a couple of times and haven't seen you take a stand > >> on it. > > > > That's because I was madly Wiki-ing. > > > > As near as I can tell, it's got to be superposition _and_ scaling (with > > complex numbers) as you said. I haven't sat down and actually done the > > math, although the fact that the complex conjugate operation obeys > > superposition certainly points to a problem in my original assertion. > > hey, 4 days ago, i was at the very same place and Dilip emailed me the > obvious counter example. i thought the timing was uncanny (8/7/11 3:33 > PM EDT) and thought for sure he was also in conversation with you about > it. later found that this assumption (by me) was also wrong. > > > > > I was led astray because in real analysis you can start with > > superposition and deduce scaling -- apparently that's not the case with > > complex analysis. > > our posts literally just "crossed in the mail". > > we're on the same page. in the real and continuous world, superposition > is equivalent to linearity.Hi Robert You forget the conversation we had about this back in 2007, where eventually Robert E. Beaudoin set us straight and gave an exmaple of a system operating on real signal that is additive but not linear. Those where the days ... :-). Regards, Andor
On 8/12/11 11:23 AM, Andor wrote:> 11. August schrieb robert bristow-johnson:...>> >> we're on the same page. in the real and continuous world, superposition >> is equivalent to linearity. > > Hi Robert > > You forget the conversation we had about this back in 2007, where eventually Robert E. Beaudoin set us straight and gave an example of a systemoperating on real signal that is additive but not linear. Those where the days ... :-).> > Regards, > Andori did forget that conversation. for others' information here is the link: http://groups.google.com/group/comp.dsp/msg/1baf2abb7c0dbc26 i hadn't forgotten the issue but, for whatever unknown reason, i didn't think about the case with complex signals and scalars and operations that are not analytic functions. i was saying the same thing back then: superposition implies homogeneity in scaling for rational scalars and i didn't know how to extend it to irrational without the additional assumption of continuity. Robert Beaudoin put out a counter-example, i guess, but i don't exactly understand it. it's sorta mathy. i would say, for *real* systems that *really* exist (so they work on and output *real* quantities), it would be pretty hard to create a physical system that is so discontinuous that it discriminates between rational and irrational values (it probably sees everything as a finite precision value, therefore rational), then in that case, if you test it for superposition and it passes, then i think it's safe, in this practical case, that it's linear in the full sense. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
On Fri, 12 Aug 2011 01:15:24 -0400, Phil Hobbs <pcdhSpamMeSenseless@electrooptical.net> wrote:>On 08/12/2011 12:31 AM, josephkk wrote: >> On Thu, 11 Aug 2011 21:05:16 +0000 (UTC), glen herrmannsfeldt >> <gah@ugcs.caltech.edu> wrote: >> >>> In comp.dsp Tim Wescott<tim@seemywebsite.com> wrote: >>> (snip) >>> >>>> That's because I was madly Wiki-ing. >>> >>>> As near as I can tell, it's got to be superposition _and_ scaling (with >>>> complex numbers) as you said. I haven't sat down and actually done the >>>> math, although the fact that the complex conjugate operation obeys >>>> superposition certainly points to a problem in my original assertion. >>> >>>> I was led astray because in real analysis you can start with >>>> superposition and deduce scaling -- apparently that's not the >>>> case with complex analysis. >>> >>> Complex conjugate is a strange operator. What, for example, is >>> its derivative? >>> >>> -- glen >> >> The denominator of a fraction does not exist in and by itself, a more >> correct question is what is the derivative of the fraction? >> >> ?-) > >In order for a complex function u(x,y)+i*v(x,y) to have a derivative, >the derivative has to be the same in all directions in the complex >plane, which leads to the the Cauchy-Riemann condition, i.e. > >partial u/partial x = partial v/partial y > >and > >partial v/partial x = - partial u/partial y. > >Complex conjugate doesn't satisfy them, so it has no derivative. > >Cheers > >Phil HobbsWhoosh. I heard that one get by me. I have forgotten too much math. ?8-/
