When a 4 point DFT of a time domain signal x(n) is calculated, 1) I am assuming that each sample represents equivalent value (probably called spectrum) in frequency domain 2) As the sample value increases, the frequency it represents also increases I have one question though - a sample in frequency domain basically implies a single point in a complex plane (as specified by magnitude and angle). So, I am confused as to how this translates (or represents) into frequency of any sort. Somehow, I am not getting a complete picture.
discrete frequency domain sample
Started by ●August 8, 2011
Reply by ●August 8, 20112011-08-08
On Mon, 08 Aug 2011 08:52:34 -0500, "manishp" <manishp.p18@n_o_s_p_a_m.gmail.com> wrote:>When a 4 point DFT of a time domain signal x(n) is calculated, > >1) I am assuming that each sample represents equivalent value (probably >called spectrum) in frequency domain >2) As the sample value increases, the frequency it represents also >increases > >I have one question though - a sample in frequency domain basically implies >a single point in a complex plane (as specified by magnitude and angle). >So, I am confused as to how this translates (or represents) into frequency >of any sort. Somehow, I am not getting a complete picture.The phase of the frequency coefficient is with respect to the basis function for that coefficient (i.e., in the case of a DFT it is a complex exponential/sinusoid). If you shift the window of the DFT in time a little bit, or shift the phase of the basis function, the phase of the frequency coefficient will shift accordingly. Eric Jacobsen http://www.ericjacobsen.org http://www.dsprelated.com/blogs-1//Eric_Jacobsen.php
On Mon, 08 Aug 2011 08:52:34 -0500, manishp wrote:> When a 4 point DFT of a time domain signal x(n) is calculated, > > 1) I am assuming that each sample represents equivalent value (probably > called spectrum) in frequency domain > 2) As the sample value increases, the frequency it represents also > increases > > I have one question though - a sample in frequency domain basically > implies a single point in a complex plane (as specified by magnitude and > angle). So, I am confused as to how this translates (or represents) into > frequency of any sort. Somehow, I am not getting a complete picture.A four-point DFT isn't going to give you a very rich "frequency domain" representation. You're getting DC, half Nyquist, and Nyquist. That's hardly "frequency domain" at all. What are you really trying to do, and why -- perhaps we can suggest a method that will get you there. -- www.wescottdesign.com
manishp wrote:> When a 4 point DFT of a time domain signal x(n) is calculated, > > 1) I am assuming that each sample represents equivalent value (probably > called spectrum) in frequency domain > 2) As the sample value increases, the frequency it represents also > increases > > I have one question though - a sample in frequency domain basically implies > a single point in a complex plane (as specified by magnitude and angle). > So, I am confused as to how this translates (or represents) into frequency > of any sort. Somehow, I am not getting a complete picture.
manishp <manishp.p18@n_o_s_p_a_m.gmail.com> wrote:> When a 4 point DFT of a time domain signal x(n) is calculated,> 1) I am assuming that each sample represents equivalent value (probably > called spectrum) in frequency domain > 2) As the sample value increases, the frequency it represents also > increases> I have one question though - a sample in frequency domain basically > implies a single point in a complex plane (as specified by > magnitude and angle). So, I am confused as to how this translates > (or represents) into frequency of any sort. Somehow, I am not > getting a complete picture.It is hard to see with only four points, but not so hard at 128, or even down to 32. Sample a sine wave with a period of 32 at points from 0 to 31. You can even draw one on graph paper, and connect the dots. Now, graph a sine wave with a period of 32/33. That is, 33 cycles over the interval of 0 to 32, at the same points, and plot it on the same graph. It still works at four, though harder to see. -- glen
On Mon, 08 Aug 2011 08:52:34 -0500, "manishp" <manishp.p18@n_o_s_p_a_m.gmail.com> wrote: Hi,>When a 4 point DFT of a time domain signal x(n) is calculated, > >1) I am assuming that each sample represents equivalent value (probably >called spectrum) in frequency domainWhat does the phrase 'equivalent value mean'?>2) As the sample value increases, the frequency it represents also >increasesWhat do you mean by 'sample value'?>I have one question though - a sample in frequency domain basically implies >a single point in a complex plane (as specified by magnitude and angle). >So, I am confused as to how this translates (or represents) into frequency >of any sort. Somehow, I am not getting a complete picture.Do *NOT* think of frequency-domain samples as points on a complex plane, or else you will confuse yourself There must be a hundred web sites that provide tutorial information regarding the discrete Fourier transform (DFT). Start visiting those web sites. By the way, 4-point DFTs are interesting in the sense that they can be performed without the need for multiplication. [-Rick-]
Rick Lyons <R.Lyons@_bogus_ieee.org> wrote: (snip)> Do *NOT* think of frequency-domain samples as > points on a complex plane, or else you will > confuse yourself(snip)> By the way, 4-point DFTs are interesting in the > sense that they can be performed without the need > for multiplication.If you are interested in minimizing multiplication, look at the ICT. (Integer Cosine Transform) It was designed to run on the CDP1802 processor. (The inverse transform is more complicated.) -- glen
On 8/8/2011 6:52 AM, manishp wrote:> When a 4 point DFT of a time domain signal x(n) is calculated, > > 1) I am assuming that each sample represents equivalent value (probably > called spectrum) in frequency domain > 2) As the sample value increases, the frequency it represents also > increases >Why when the amplitude increases, the frequency increases?
Reply by ●August 9, 20112011-08-09
Thank you all once again for the comments and the feedback. I have put few clarification below ...>On 8/8/2011 6:52 AM, manishp wrote: >> When a 4 point DFT of a time domain signal x(n) is calculated, >> >> 1) I am assuming that each sample represents equivalent value (probably >> called spectrum) in frequency domain >> 2) As the sample value increases, the frequency it represents also >> increases >> > >Why when the amplitude increases, the frequency increases?[Tim Wescott] A four-point DFT isn't going to give you a very rich "frequency domain" representation. You're getting DC, half Nyquist, and Nyquist. That's hardly "frequency domain" at all. What are you really trying to do, and why -- perhaps we can suggest a method that will get you there. [manishp] I am mainly trying to understand the basics of frequency domain representations. I saw this particular example (4-point DTFT) in Proakis book and hence my question. [Rick Lyons ] What do you mean by 'sample value'? [manishp] Maybe I am not using the right formal terms but what I meant is that each sample in frequency domain represents a particular frequency component that makes up the time domain behavior. [Nasser M. Abbasi ] Why when the amplitude increases, the frequency increases? [manishp] No. What I meant is that as the frequency domain sample increases X(1) compared to X(0), it represents a higher frequency (compared to X(0))
On 8/8/2011 9:30 AM, Tim Wescott wrote:> On Mon, 08 Aug 2011 08:52:34 -0500, manishp wrote: > >> When a 4 point DFT of a time domain signal x(n) is calculated, >> >> 1) I am assuming that each sample represents equivalent value (probably >> called spectrum) in frequency domain >> 2) As the sample value increases, the frequency it represents also >> increases >> >> I have one question though - a sample in frequency domain basically >> implies a single point in a complex plane (as specified by magnitude and >> angle). So, I am confused as to how this translates (or represents) into >> frequency of any sort. Somehow, I am not getting a complete picture. > > A four-point DFT isn't going to give you a very rich "frequency domain" > representation. You're getting DC, half Nyquist, and Nyquist. That's > hardly "frequency domain" at all. > > What are you really trying to do, and why -- perhaps we can suggest a > method that will get you there. >Tim, I would have said: DC, fs/4 fs/2 and 3fs/4 'cause I don't know what "Nyquist" means in this context and yet I'm sure it doesn't mean 3fs/4! Fred
