Hello, I'm currently working with a new parametric spectral estimation technique (it achieves better resolution frequency than the FFT for instance) and I would like to use it so as to find similarities between two or more signals based on their frequency components. I could use the cross correlation or the correlation coefficient but by this way I do not take advantage of the tool that I have in my disposal. Is there any way to make a comparison of signals based on the their frequency values?? Thanks, Kostas
Similarity measure for signals
Started by ●August 8, 2011
Reply by ●August 8, 20112011-08-08
On Mon, 08 Aug 2011 10:45:41 -0500, "fidaki35" <fidaki35@n_o_s_p_a_m.hotmail.com> wrote:> Hello, > > I'm currently working with a new parametric spectral estimation technique >(it achieves better resolution frequency than the FFT for instance) and I >would like to use it so as to find similarities between two or more signals >based on their frequency components. > I could use the cross correlation or the correlation coefficient but by >this way I do not take advantage of the tool that I have in my disposal. Is >there any way to make a comparison of signals based on the their frequency >values?? > >Thanks, >KostasIs there a reason not to use correlation in the frequency domain? Eric Jacobsen http://www.ericjacobsen.org http://www.dsprelated.com/blogs-1//Eric_Jacobsen.php
fidaki35 wrote:> Hello, > > I'm currently working with a new parametric spectral estimation technique > (it achieves better resolution frequency than the FFT for instance) and I > would like to use it so as to find similarities between two or more signals > based on their frequency components. > I could use the cross correlation or the correlation coefficient but by > this way I do not take advantage of the tool that I have in my disposal. Is > there any way to make a comparison of signals based on the their frequency > values?? > > Thanks, > Kostas > >
