Can somebody explain phase velocity to me. There is an entry in Wikipedia but it is a little confusing. http://en.wikipedia.org/wiki/Phase_velocity They have what looks like a double sideband suppressed carrier waveform and seem to suggest that it is the envelope that is the phase velocity? Apparently the phase velocity can be faster than the waveform itself. As an EE normally the carrier is a higher frequency than the envelope... F
Phase Velocity
Started by ●August 9, 2011
Reply by ●August 9, 20112011-08-09
fitlike <naespamboy@scotland.co.uk> wrote:> Can somebody explain phase velocity to me. There is an entry in > Wikipedia but it is a little confusing.> http://en.wikipedia.org/wiki/Phase_velocity> They have what looks like a double sideband suppressed carrier waveform > and seem to suggest that it is the envelope that is the phase velocity? > Apparently the phase velocity can be faster than the waveform itself. As > an EE normally the carrier is a higher frequency than the envelope...When I learned it, phase velocity was w/k, group velocity dw/dk, where w (omega) is the angular frequency and k the wave number (or wave vector in more than one dimension). (w is 2pi over the time period, k is 2pi over the spatial period.) But no, the envelope travels at group velocity and, in the usual case, is where the information travels. Phase velocity is often faster than c, where group velocity should be less than c. One example uses a Gaussian envelope which is a good representation for a quantum mechanical (with uncertainty) particle. In DSP context, phase delay and group delay are more usual, but they are related. -- glen
Reply by ●August 10, 20112011-08-10
On Aug 10, 12:58�am, fitlike <naespam...@scotland.co.uk> wrote:> Can somebody explain phase velocity to me. There is an entry in > Wikipedia but it is a little confusing. > > http://en.wikipedia.org/wiki/Phase_velocity > > They have what looks like a double sideband suppressed carrier waveform > and seem to suggest that it is the envelope that is the phase velocity? > Apparently the phase velocity can be faster than the waveform itself. As > an EE normally the carrier is a higher frequency than the envelope... > > FThis is very confusing material, that really requires you to contemplate. With a not insignificant risk of your going crackpot. Have a look at bow waves off ships or boats. The wave fronts internsl to the wave train propagate at phase velocity; the wave front travels at group velocity. Rune
On Aug 10, 10:09�am, Rune Allnor <all...@tele.ntnu.no> wrote:> On Aug 10, 12:58�am, fitlike <naespam...@scotland.co.uk> wrote: > > > Can somebody explain phase velocity to me. There is an entry in > > Wikipedia but it is a little confusing. > > >http://en.wikipedia.org/wiki/Phase_velocity > > > They have what looks like a double sideband suppressed carrier waveform > > and seem to suggest that it is the envelope that is the phase velocity? > > Apparently the phase velocity can be faster than the waveform itself. As > > an EE normally the carrier is a higher frequency than the envelope... > > > F > > This is very confusing material, that really requires > you to contemplate. With a not insignificant risk of > your going crackpot. > > Have a look at bow waves off ships or boats. The wave > fronts internsl to the wave train propagate at phase > velocity; the wave front travels at group velocity. > > RuneFor small boats, this is easier to observe in the wake. Close examination reveals that individual waves arise at the inner part of the vee, move to the outer part, then decay. the individual waves therefore travel faster than the vee as a whole. Jerry -- Engineering is the art of making what you want from things you can get.
Rune Allnor <allnor@tele.ntnu.no> wrote: (snip on phase velocity)> Have a look at bow waves off ships or boats. The wave > fronts internsl to the wave train propagate at phase > velocity; the wave front travels at group velocity.I haven't thought about this one for a while. As with another recently asked question, and without looking at Wikipedia, which quantities would you expect the angle of a bow wave (relative to the boat direction) to depend on? a) The speed of sound in water (or other liquid) b) The viscosity of the liquid (which might not be water) c) The depth of the liquid d) The local gravity (small g) e) The speed of the boat (Note that the phase velocity of surface waves depends on two of the quanities listed above.) Also, liquid surface waves are an interesting case for phase velocity, as the phase velocity can depend on wavelength. -- glen
On Aug 10, 8:40�pm, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:> Rune Allnor <all...@tele.ntnu.no> wrote: > > (snip on phase velocity) > > > Have a look at bow waves off ships or boats. The wave > > fronts internsl to the wave train propagate at phase > > velocity; the wave front travels at group velocity. > > I haven't thought about this one for a while. �As with another > recently asked question, and without looking at Wikipedia, > which quantities would you expect the angle of a bow wave > (relative to the boat direction) to depend on? > > a) The speed of sound in water (or other liquid) > b) The viscosity of the liquid (which might not be water) > c) The depth of the liquid > d) The local gravity (small g) > e) The speed of the boat > > (Note that the phase velocity of surface waves depends on > two of the quanities listed above.) > > Also, liquid surface waves are an interesting case for phase > velocity, as the phase velocity can depend on wavelength. > > -- glenAll of the above? I remember I used this example when i attempted to wrap my mind around these concepts ages ago. Very visual. Very useful. Rune
On Aug 10, 2:40�pm, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:> Rune Allnor <all...@tele.ntnu.no> wrote: > > (snip on phase velocity) > > > Have a look at bow waves off ships or boats. The wave > > fronts internsl to the wave train propagate at phase > > velocity; the wave front travels at group velocity. > > I haven't thought about this one for a while. �As with another > recently asked question, and without looking at Wikipedia, > which quantities would you expect the angle of a bow wave > (relative to the boat direction) to depend on?The wake angle depends on the velocity of surface waves (which depends on depth and g) and on the speed of the boat. The effect (and equations) are the same as for hypersonic passage through air. Below the wave speed, i.e., "tranquil flow", there is no wake. ... Jerry -- Engineering is the art of making what you want from things you can get.
Jerry Avins <jya@ieee.org> wrote: (snip, I wrote)>> I haven't thought about this one for a while. �As with another >> recently asked question, and without looking at Wikipedia, >> which quantities would you expect the angle of a bow wave >> (relative to the boat direction) to depend on?> The wake angle depends on the velocity of surface waves (which depends > on depth and g) and on the speed of the boat. The effect (and > equations) are the same as for hypersonic passage through air. Below > the wave speed, i.e., "tranquil flow", there is no wake.So when a boat goes twice as fast, the wake angle is reduced by (about) a factor of two? Sounds good, but compare the wake of a duck to the wake of a ski boat. The ski boat might go 50mi/h, the duck maybe 1mi/h. Or just watch the ski boat at different speeds. -- glen
Reply by ●August 11, 20112011-08-11
fitlike <naespamboy@scotland.co.uk> wrote:> Can somebody explain phase velocity to me. There is an entry in > Wikipedia but it is a little confusing.> http://en.wikipedia.org/wiki/Phase_velocityTo continue the discussion about boat wakes, and get back to phase velocity, see the page: http://en.wikipedia.org/wiki/Wake The dispersion relation for deep water waves is w=sqrt(g k) where w is the angular frequency (radians/sec), g is the acceleration due to gravity (m/s**2), and k is the wave number in radians/meter, that is, 2pi/wavelength. For deep water waves, depth greater than about half the wavelength, the phase velocity is then w/k = sqrt(g k)/k = sqrt(g/k) the group velocity, dw/dk, or sqrt(g/k)/2. The wake angle is then arctan(Vp/Vg), (Phase velocity/group velocity) which is arctan(1/2), or about 26.5 degrees. As to the original question regarding DSB-AM modulation, the phase velocity is the velocity of the carrier, the group velocity of modulation to the carrier, assuming it is sufficiently slow relative to the carrier itself. Consider a wave with a Guassian envelope. There is a combination of pure sines that add up to such localized wave packet. If you look closely at the wake, you will see that it is a sum, or interference pattern, of a range of wavelengths (and frequencies). For real boats, the boat shape has some effect on the wake, but the angle doesn't get far from arctan(1/2) in most real cases. That is, independent of boat velocity, viscosity, g, density, etc. -- glen
On Aug 11, 5:21�am, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote: ...> For real boats, the boat shape has some effect on the wake, > but the angle doesn't get far from arctan(1/2) in most real cases. > That is, independent of boat velocity, viscosity, g, density, etc.Wow! I need to dust off some old texts and straighten myself out. Thanks for the start on that. Jerry -- Engineering is the art of making what you want from things you can get.
