I'm playing around with estimating the signal fading on a signal while ignoring amplitude variations due to a non-constant amplitude. Let's say I've got an antenna with a clear line of sight to a signal, it collects something like: x(t) = s(t) + v(t) where v is AWGN Then I have another antenna that's sees the signal, but with fading on it, so it receives something like: y(t) = A(t)*s(t) + u(t) where u is AWGN I'm not an estimation guy so I was wondering if someone could get me started on a reasonable way to estimate A(t) given x(t) and y(t). How about if I want to integrate to pull s(t) out of the noise?
Estimating signal fading while ignoring envelope variation?
Started by ●August 15, 2011
Reply by ●August 15, 20112011-08-15
On Mon, 15 Aug 2011 10:32:09 -0500, "gct" <smcallis@n_o_s_p_a_m.gmail.com> wrote:>I'm playing around with estimating the signal fading on a signal while >ignoring amplitude variations due to a non-constant amplitude. > >Let's say I've got an antenna with a clear line of sight to a signal, it >collects something like: > >x(t) = s(t) + v(t) where v is AWGN > >Then I have another antenna that's sees the signal, but with fading on it, >so it receives something like: > >y(t) = A(t)*s(t) + u(t) where u is AWGN > >I'm not an estimation guy so I was wondering if someone could get me >started on a reasonable way to estimate A(t) given x(t) and y(t). How >about if I want to integrate to pull s(t) out of the noise?If the system has a single AGC then A(t) will be estimated by the AGC signal. You probably don't even need x(t). Eric Jacobsen http://www.ericjacobsen.org http://www.dsprelated.com/blogs-1//Eric_Jacobsen.php
gct wrote:> I'm playing around with estimating the signal fading on a signal while > ignoring amplitude variations due to a non-constant amplitude. > > Let's say I've got an antenna with a clear line of sight to a signal, it > collects something like: > > x(t) = s(t) + v(t) where v is AWGN > > Then I have another antenna that's sees the signal, but with fading on it, > so it receives something like: > > y(t) = A(t)*s(t) + u(t) where u is AWGN > > I'm not an estimation guy so I was wondering if someone could get me > started on a reasonable way to estimate A(t) given x(t) and y(t). How > about if I want to integrate to pull s(t) out of the noise?If the fading is slow compared to the baud rate (which is the usual case) you can estimate the fading pattern from decision error vector at every received symbol using the Kalman-like algorithm. It is even possible to predict the fading pattern into the future so to avoid the expected deep fades by maneuvering the signal in time or frequency in advance. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
>If the system has a single AGC then A(t) will be estimated by the AGC >signal. You probably don't even need x(t). > >The problem comes when the signal itself isn't steady. An AGC can't distinguish fading from things like the signal not being constant-modulus.
Eric Jacobsen wrote:> On Mon, 15 Aug 2011 10:32:09 -0500, "gct" > <smcallis@n_o_s_p_a_m.gmail.com> wrote: > > >>I'm playing around with estimating the signal fading on a signal while >>ignoring amplitude variations due to a non-constant amplitude. >> >>Let's say I've got an antenna with a clear line of sight to a signal, it >>collects something like: >> >>x(t) = s(t) + v(t) where v is AWGN >> >>Then I have another antenna that's sees the signal, but with fading on it, >>so it receives something like: >> >>y(t) = A(t)*s(t) + u(t) where u is AWGN >> >>I'm not an estimation guy so I was wondering if someone could get me >>started on a reasonable way to estimate A(t) given x(t) and y(t). How >>about if I want to integrate to pull s(t) out of the noise? > > > If the system has a single AGC then A(t) will be estimated by the AGC > signal.Dear doctor Jacobsen, A(t) is complex. VLV
>If the fading is slow compared to the baud rate (which is the usual >case) you can estimate the fading pattern from decision error vector at >every received symbol using the Kalman-like algorithm. It is even >possible to predict the fading pattern into the future so to avoid the >expected deep fades by maneuvering the signal in time or frequency in >advance. > >Vladimir Vassilevsky >DSP and Mixed Signal Design Consultant >http://www.abvolt.com >I'd actually like to be able to estimate the fading in a modulation-agnostic way.
gct wrote:>>If the fading is slow compared to the baud rate (which is the usual >>case) you can estimate the fading pattern from decision error vector at >>every received symbol using the Kalman-like algorithm. It is even >>possible to predict the fading pattern into the future so to avoid the >>expected deep fades by maneuvering the signal in time or frequency in >>advance. >> > > I'd actually like to be able to estimate the fading in a > modulation-agnostic way.I think you are actually a stupident. Right?> Let's say I've got an antenna with a clear line of sight to a signal, it > collects something like: > > x(t) = s(t) + v(t) where v is AWGN > > Then I have another antenna that's sees the signal, but with fading on it, > so it receives something like: > > y(t) = A(t)*s(t) + u(t) where u is AWGN > > I'm not an estimation guy so I was wondering if someone could get me > started on a reasonable way to estimate A(t) given x(t) and y(t).Make an LMS algorithm using x(t) as a reference. Track the coefficients of the resulting filter. VLV
>Make an LMS algorithm using x(t) as a reference. Track the coefficients >of the resulting filter. > >VLVCan you elaborate on this?
gct wrote:>>Make an LMS algorithm using x(t) as a reference. Track the coefficients >>of the resulting filter. >> > Can you elaborate on this?Sure. And I'll send you the bill also. The contact is at the web site in the signature. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
