Hello, I wrote an algorithm that designs FIR filters. It can be found here (OctaveForge / Matlab code): http://www.dsprelated.com/showcode/210.php In a nutshell, I generate both a test signal and the result I'd expect to see from an ideal filter. I write out the FIR tap equations and find a LMS solution for the tap coefficients. The LMS solution is too "lazy" in the more "difficult" regions of the frequency response, so I wrap it in an iteration loop that boosts the signal where accuracy is lacking. After a couple of rounds, the outcome is pretty much an equiripple design. The advantage is that it's rather easy to design to arbitrary frequency responses, including nonlinear phase, complex-valued FIR and fractional delay. And so far, failure to convergence has not been an issue. Comments (/bug reports) are welcome, and I hope you find it useful. Cheers Markus
Yet Another FIR Design Algorithm
Started by ●August 21, 2011
Reply by ●August 21, 20112011-08-21
mnentwig wrote:> The LMS solution is too "lazy" in the more "difficult" regions of the > frequency response, so I wrap it in an iteration loop that boosts the > signal where accuracy is lacking. After a couple of rounds, the outcome is > pretty much an equiripple design.Hello Markus, The LMS + dynamic programming approach converges to a solution however this solution is generally not a global optimum. You can get similar results using LMS to find initial guess and then numerically optimizing the filter starting from that guess. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Aug 21, 5:15�pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote:> mnentwig wrote: > > The LMS solution is too "lazy" in the more "difficult" regions of the > > frequency response, so I wrap it in an iteration loop that boosts the > > signal where accuracy is lacking. After a couple of rounds, the outcome is > > pretty much an equiripple design. > > Hello Markus, > > The LMS + dynamic programming approach converges to a solution however > this solution is generally not a global optimum. You can get similar > results using LMS to find initial guess and then numerically optimizing > the filter starting from that guess. > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultanthttp://www.abvolt.comI tried the same algorithm some years ago only for iir filters using the dual-fir equation error method. It worked well except in the case where the ratio of sample rate to cutoff frequency was very high. Have you tried this? For example try a low pass with transition band from 20 hz to 30 hz with 60 db stopband and fs of 50k. Bob
Reply by ●August 22, 20112011-08-22
>It worked well except in the case where the ratio of sample rate to >cutoff frequency was very high.Maybe for this case the problem is not so much the method itself but could be a numerical issue.
>>It worked well except in the case where the ratio of sample rate to >>cutoff frequency was very high. > >Maybe for this case the problem is not so much the method itself butcould>be a numerical issue.I think that most us would say that if there are numerical stability issues with a method, the method has a problem. Steve
Hello, thank you all for your reples. I agree, there is no guarantee that it finds a global optimum. For example, a small change in weights could cause zeros to "jump" from one passband to another, making the weights from the last iteration meaningless. I updated the description.>> try a low pass with transition band from 20 hz to 30 hz with 60 dbstopband and fs of 50k That's a long FIR filter... I tried 2000 taps and it behaves as expected, but that comes nowhere close to the -60 dB at 30 Hz. Maybe CPU power is more a limitation than numerical accuracy. I should verify this, but I suspect the bottleneck is the pinv() on a (n taps) x (n frequency bins) matrix in each iteration. Kind Regards Markus
mnentwig wrote:> Hello, > > thank you all for your reples. > I agree, there is no guarantee that it finds a global optimum. For example, > a small change in weights could cause zeros to "jump" from one passband to > another, making the weights from the last iteration meaningless. > I updated the description.If I am not mistaken, Dilip Sarwate was suggesting a similar approach to manipulate weights using Greg Berchin's FDLS algorithm as a core LS solver. That could allow for an arbitrary equiripple FIR/IIR design; however I don't know how well did it work in reality. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
