Jerry Avins wrote:> 2. Why are push-pull amplifiers standard for low-distortion > applications?BTW, the push-pull amplifies are no-no for the real low distortion applications. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
FFT and Sine Waves Question
Started by ●August 26, 2011
Reply by ●September 1, 20112011-09-01
Vladimir Vassilevsky <nospam@nowhere.com> wrote:> Jerry Avins wrote:>> 2. Why are push-pull amplifiers standard for low-distortion >> applications?> BTW, the push-pull amplifies are no-no for the real low distortion > applications.It would seem to depend on what kind of distortion you were looking at. -- glen
On 9/1/11 3:18 PM, dvsarwate wrote:> > On a semi-related matter, I have no problems > with the FIRST overtone being the same as the > SECOND harmonic. After all, one cannot have > an OVERtone unless one has a tone to begin > with! But, I do worry that r b-j and Dijkstra will > want to call it the zero-th overtone..... :-) >damn straight! maybe i'll call it the minus-oneth overtone just to fuck with your brains. Edgar Dijkstra will have to speak for himself (from the grave). speaking of graves, Hurricane Irene caused a bunch of acute flooding at various places in the mountains of Vermont (not *my* place, thankfully). these flash floods washed out roads in scores of places in the state. besides that, in the town of Rochester VT, part of the cemetery was washed out: http://www.csmonitor.com/CSM-Photo-Galleries/In-Pictures/Hurricane-Irene the Burlington Free Press had a closer ground-level pic of the washed out cemetery (coffins strewn about), but i can't find it on their website and my DSL is too slow to look any more. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
glen herrmannsfeldt wrote:> Vladimir Vassilevsky <nospam@nowhere.com> wrote: > > >>Jerry Avins wrote: > > >>>2. Why are push-pull amplifiers standard for low-distortion >>> applications? > > >>BTW, the push-pull amplifies are no-no for the real low distortion >>applications. > > > It would seem to depend on what kind of distortion you were > looking at.I thought I made it clear: real low distortion :-) Whether it is in the audio or in RF, small signal or power amplification, the single ended amplifiers achieve the topmost specmanship. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Vladimir Vassilevsky <nospam@nowhere.com> wrote: (snip)>>>BTW, the push-pull amplifies are no-no for the real low distortion >>>applications.>> It would seem to depend on what kind of distortion you were >> looking at.> I thought I made it clear: real low distortion :-)> Whether it is in the audio or in RF, small signal or power > amplification, the single ended amplifiers achieve the topmost > specmanship.That should be true, but is it always true? Are higher power output devices naturally less linear? As I understand it, the usual problem with push-pull amplifiers is at smaller signal levels. If you know you always have large signals, does that change the decision? Now, to be even less obvious, how about a push-pull class A amplifier, such that both drivers are always on. It will dissipate a lot of power, but might be even lower distortion than a single ended class A. -- glen
glen herrmannsfeldt wrote:> Vladimir Vassilevsky <nospam@nowhere.com> wrote: > > (snip) > >>>>BTW, the push-pull amplifies are no-no for the real low distortion >>>>applications. > >>>It would seem to depend on what kind of distortion you were >>>looking at.>>I thought I made it clear: real low distortion :-) > >>Whether it is in the audio or in RF, small signal or power >>amplification, the single ended amplifiers achieve the topmost >>specmanship. > > That should be true, but is it always true? > > Are higher power output devices naturally less linear? > > As I understand it, the usual problem with push-pull amplifiers > is at smaller signal levels. If you know you always have large > signals, does that change the decision? > > Now, to be even less obvious, how about a push-pull class A > amplifier, such that both drivers are always on.The real life signals aren't symmetrical; as such, there is no inherent distortion advantage in the push-pull. There are specific difficulties with the availability of the true complimentary devices and with the accurate splitting of the signal and then adding it back.> It will > dissipate a lot of power, but might be even lower distortion > than a single ended class A.It depends; We are down to the details here. Questions about particular applications are welcome. VLV
