Lingo for layfolk?
Started by Rune Allnor ●September 2, 2011
Hi all,
I am preparing a course for math layfolk, but need
to communicate the concepts of 'continuous' and
'discrete' variables. Users of a software package
will need to use these concepts in order to select
the proper analysis methods for whatever data
they need to proces.
I can't use those terms, or participants will likely
flee the course. So I have tried to come up with
simpler terms:
Continous variable = measurable variable
Discrete variable = countable variable
Does this make sense to others than me?
Rune
On Fri, 2 Sep 2011 15:49:48 -0700 (PDT), Rune Allnor
<allnor@tele.ntnu.no> wrote:
>Hi all, > >I am preparing a course for math layfolk, but need >to communicate the concepts of 'continuous' and >'discrete' variables. Users of a software package >will need to use these concepts in order to select >the proper analysis methods for whatever data >they need to proces. > >I can't use those terms, or participants will likely >flee the course. So I have tried to come up with >simpler terms: > >Continous variable = measurable variable >Discrete variable = countable variable > >Does this make sense to others than me?
Continuous = like a string Discrete = like beads on the string Not rigorous but intuitive. -- Rich Webb Norfolk, VA
On 02/09/2011 23:59, Rich Webb wrote:
> On Fri, 2 Sep 2011 15:49:48 -0700 (PDT), Rune Allnor > <allnor@tele.ntnu.no> wrote: > >> Hi all, >> >> I am preparing a course for math layfolk, but need >> to communicate the concepts of 'continuous' and >> 'discrete' variables. Users of a software package >> will need to use these concepts in order to select >> the proper analysis methods for whatever data >> they need to proces. >> >> I can't use those terms, or participants will likely >> flee the course.
That is really a bit worrying! So I have tried to come up with
>> simpler terms: >> >> Continous variable = measurable variable >> Discrete variable = countable variable >> >> Does this make sense to others than me? > > Continuous = like a string > Discrete = like beads on the string > > Not rigorous but intuitive. >
Or: the difference between a fretless bass and a standard bass (or violin v viol). The frets enforce discrete pitch steps (and can be counted and measured); without them you can traverse the fingerboard, er, continuously. Any number of similar analogies suggest themselves. The ribbon controller on a Moog keyboard. A flute with finger holes versus a swanee whistle! Teach them some music, and the math will (almost) take care if itself :-). Inasmuch as it is a vocabulary issue: continuous is a commonly used word in daily life, only discrete is relatively unusual, and could be confused with "discreet". All it needs is the definition and you should be up and away. Richard Dobson
Rune Allnor <allnor@tele.ntnu.no> wrote:
> I am preparing a course for math layfolk, but need > to communicate the concepts of 'continuous' and > 'discrete' variables. Users of a software package > will need to use these concepts in order to select > the proper analysis methods for whatever data > they need to proces.
(snip)
> Continous variable = measurable variable > Discrete variable = countable variable
It doesn't sound right mathematically (discrete can be infinite), but otherwise is probably about right. The less than/fewer than distinction has always bothered me. Many things we think of as continuous really aren't, but usually close enough. There are an integer number of water molecules in a cup of water, but we still can't count them. Some years ago someone (CS person) corrected me (in a non-CS context) regarding fewer than vs. less than. My reply was that couldn't be rigth, otherwise Fortran would need a .FT. operator for integer comparison. (and .FE. also). Always my favorite quantization problem, how many different velocities can a baseball pitcher pitch at? If you consider a stadium as a quantum well, an integer number of half wavelengths have to fit inside a (closed) stadium. The problem is easier in a square stadium than a round one, but that doesn't make a huge difference in the answer. Semiconductor band theory is the continuous limit of molecular orbital theory from chemistry. Many discrete problems are easier in the continuous approximation. But I like the beads vs. string that someone else suggested. -- glen
Hi,
the terms "analog" and "digital" come to mind.
Or "sampled", "stepped", "discrete" and "continuous" as proposed earlier.
"Floating point" and "integer" in programming, for example.
I was thinking only a few days ago about analog (film) photography and audio magnetic tape. In the case of film photography, it is usual that each silver grain is either completely developed or removed by the fixer. That is, it is discrete in some sense. But, unlike digital, the grains vary in size so it isn't band limited in the sampled digital sense. For magnetic tape, each magnetic crystal is magnetized on way or the other, on average representing the amplitude of the analog signal. Again grains vary in size, but are large on the atomic scale. For phonograph (vinyl) records, the resolution limit in the continuous/discrete determination, should be close to the atomic (or molecular) scale. Otherwise, outside the DSP context, analog and digital can be very confusing to people. Many believe that as DSL and cable are digital, the device at the end isn't a modem. (Even though it usually has modem in its name.)
> Or "sampled", "stepped", "discrete" and "continuous" as > proposed earlier.
That might work, but note that floating point isn't continuous, either. -- glen
On Sep 3, 1:56&#4294967295;am, Richard Dobson <richarddob...@blueyonder.co.uk>
wrote:
> On 02/09/2011 23:59, Rich Webb wrote: > > > On Fri, 2 Sep 2011 15:49:48 -0700 (PDT), Rune Allnor > > <all...@tele.ntnu.no> &#4294967295;wrote: > > >> Hi all, > > >> I am preparing a course for math layfolk, but need > >> to communicate the concepts of 'continuous' and > >> 'discrete' variables. Users of a software package > >> will need to use these concepts in order to select > >> the proper analysis methods for whatever data > >> they need to proces. > > >> I can't use those terms, or participants will likely > >> flee the course. > > That is really a bit worrying!
The context is simple data analysis (statistical process control, SPC), for layfolk users where nothing can be assumed or expected wrt prior education. I have found that most people understand the concepts when described to them, but that terminology and nomenclature might become unnecessary hurdles foe learning, if introduced at the wrong time. I usually explain the concepts as accurately as possible in everyday language first, and then wrap up with something like 'mathematicians or engineers use the term <whatever> fot these things'. For some reason this works better than first stating the term and then explaining it. Rune
On 3 Sep, 01:56, Richard Dobson <richarddob...@blueyonder.co.uk>
It's not as bad as it sounds. This is a class for people who want to use Statistical Process Control, SPC, but where nothing can be assumed or expected wrt prior education. Choosing the correct method is crucial, even if the nasty bits are wrapped inside some software package. I have found that first explaining whatever concept accurately but in familiar language, and only introducing the terminology afterwards, works far better than introducing terminology first and then explaining it. I don't know why, but it seems seeing 'complicated' words or terms tend to intimidate people. Particularly people who haven's got that much of an academic education. Rune
On 3 Sep, 13:54, Rune Allnor <all...@tele.ntnu.no> wrote:
> On 3 Sep, 01:56, Richard Dobson <richarddob...@blueyonder.co.uk> > wrote: > > > > > > > On 02/09/2011 23:59, Rich Webb wrote: > > > > On Fri, 2 Sep 2011 15:49:48 -0700 (PDT), Rune Allnor > > > <all...@tele.ntnu.no> &#4294967295;wrote: > > > >> Hi all, > > > >> I am preparing a course for math layfolk, but need > > >> to communicate the concepts of 'continuous' and > > >> 'discrete' variables. Users of a software package > > >> will need to use these concepts in order to select > > >> the proper analysis methods for whatever data > > >> they need to proces. > > > >> I can't use those terms, or participants will likely > > >> flee the course. > > > That is really a bit worrying! > > It's not as bad as it sounds.
Right... sorry for the double (now tripple) posting: Nothing to do with early onset of Alzheimer (at least not on my part). Google Groups didn't show the first post half an hour after I attempted to post, another post I wrote I wrote in a different thread showed up immediately, so I thought the first reply in this thread had been lost. Excuses, excuses... Rune
Well, I usually don't feel bad talking about "reconstructing an analog
waveform from a digital signal", for example. As long as it's my
presentation, it's me who's defining the terms, no one else.
If somebody comes up with an incompatible definition, that's his problem,
not mine.
