Lingo for layfolk?
Started by Rune Allnor September 2, 2011
On 6 Sep, 19:57, Jerry Avins <j...@ieee.org> wrote:
> On 9/6/2011 2:57 AM, Fred Marshall wrote: > > &#4294967295; &#4294967295;... > > > Seems to me that SPC isn't any different. Maybe you calculate mean and > > variance of dimensions over some termporal window and then compare > > results window-to-window. Isn't that essentially what a control chart > > does with mean values? > > SPC isn't necessarily about flaws.
Correct. It's about *change*.
> Suppose a spec on a screw-machine > part is 1' +- 1/64 (+-.015625) and parts have been consistently between > .994 and .996. Now I begin to see some parts at .998 and none as small > as .995. These are actually closer to spec, yet I might have cause for > worry. SPC can allay my unease or prompt action. (The fact is, the tool > bit is wearing.)
If something all of a sudden is closer to spec, it's not necessarily a cause for worry, but rather a cause to investigate why that change happened. If the cause can be identified, replicated and controlled, one all of a sudden has an improved process. Rune
