j operator in hardware
Started by Krishnakumar Gurumoorthy September 3, 2011
I was thinking of how the j operator is implemented in hardware. this
is with respect to complex down conversion and assumes the A/D's for
each I and Q channels are present (this is NOT quadrature sampling
with digital downconversion).
the "j" operator is a mere phase shift of 90 deg in the
counterclockwise direction. how is the phase shift introduced ?
CORDIC ?
thanks
On Sat, 03 Sep 2011 15:53:25 -0700, Krishnakumar Gurumoorthy wrote:
> I was thinking of how the j operator is implemented in hardware. this is > with respect to complex down conversion and assumes the A/D's for each I > and Q channels are present (this is NOT quadrature sampling with digital > downconversion). > > the "j" operator is a mere phase shift of 90 deg in the counterclockwise > direction. how is the phase shift introduced ? CORDIC ?
When you get to this level of detail, it is dangerous to think that you are dealing with complex numbers -- you aren't. You're dealing with channels that were demodulated in quadrature. You can do _almost_ all of the math assuming that you're dealing with complex numbers, but it's still not the same thing. The way that I/Q downconversion works is that you have a pair of mixers, each fed by a local oscillator that is shifted 90 degrees from the one feeding the other. So you would get your 'inphase' channel by mixing your incoming signal with a mixer that's fed in phase ('cos wt') with the LO, and you would get your 'quadrature' channel by mixing your incoming signal with a mixer that's fed in quadrature phase ('sin wt') with the LO. -- www.wescottdesign.com
On Sep 3, 6:53&#4294967295;pm, Krishnakumar Gurumoorthy <krish...@gmail.com>
wrote:
> I was thinking of how the j operator is implemented in hardware. this > is with respect to complex down conversion and assumes the A/D's for > each I and Q channels are present (this is NOT quadrature sampling > with digital downconversion). > > the "j" operator is a mere phase shift of 90 deg in the > counterclockwise direction. how is the phase shift introduced ? > CORDIC ? > > thanks
(a, b) --> (-b, a), maybe?
.. and assumes the A/D's for each I and Q channels are present ... .. how is the phase shift introduced ?
>> CORDIC ? >> >> thanks >
In a "direct conversion" (DC) radio receiver, the "j" operator can be literally implemented in hardware. It works as follows: - get radio frequency signal from the antenna - generate a local oscillator sine wave with twice the frequency - divide by two with a digital divider that gives two phases for the local oscillator signal. Those look as follows: IQ_I = 0011001100110011... IQ_Q = 0110011001100110... - Use them to drive reversing analog switches (mixers) on the analog radio frequency signal. Those will flip the sign at a pace that matches the channel frequency, one switching cycle per sine wave cycle at carrier frequency. - low-pass filter the outputs. The carrier translates to 0 Hz. - A/D conversion of both branches => two real-valued I and Q signals. This is a so-called "double frequency VCO" variant of the DC receiver that's popular in cellular mobiles, for example.
On Sat, 3 Sep 2011 15:53:25 -0700 (PDT), Krishnakumar Gurumoorthy
<krishk24@gmail.com> wrote:
>I was thinking of how the j operator is implemented in hardware. this >is with respect to complex down conversion and assumes the A/D's for >each I and Q channels are present (this is NOT quadrature sampling >with digital downconversion). > >the "j" operator is a mere phase shift of 90 deg in the >counterclockwise direction. how is the phase shift introduced ? >CORDIC ? > >thanks
That's one way, if you mean multiplying a real signal by the sin and cos terms that one can achieve with a CORDIC. A DDS/NCO does the same thing. It's no different than in software. In software one keeps separate storage for the I and Q channels or the real and imaginary components of a complex number. Likewise in hardware they can be different paths and registers. Eric Jacobsen http://www.ericjacobsen.org http://www.dsprelated.com/blogs-1//Eric_Jacobsen.php
On Sep 4, 11:30&#4294967295;am, eric.jacob...@ieee.org (Eric Jacobsen) wrote:
> On Sat, 3 Sep 2011 15:53:25 -0700 (PDT), Krishnakumar Gurumoorthy > > <krish...@gmail.com> wrote: > >I was thinking of how the j operator is implemented in hardware. this > >is with respect to complex down conversion and assumes the A/D's for > >each I and Q channels are present (this is NOT quadrature sampling > >with digital downconversion). > > >the "j" operator is a mere phase shift of 90 deg in the > >counterclockwise direction. how is the phase shift introduced ? > >CORDIC ? > > >thanks > > That's one way, if you mean multiplying a real signal by the sin and > cos terms that one can achieve with a CORDIC. &#4294967295; A DDS/NCO does the > same thing. > > It's no different than in software. &#4294967295;In software one keeps separate > storage for the I and Q channels or the real and imaginary components > of a complex number. &#4294967295;Likewise in hardware they can be different paths > and registers. > > Eric Jacobsenhttp://www.ericjacobsen.orghttp://www.dsprelated.com/blogs-1//Eric_Jacobsen.php
When designing a chip with imaginary registers it's important to make sure the physical layout of the register is rotated 90 degrees. That way you are gauranteed to have orthogonal signals.
On 09/04/2011 04:04 PM, Robert Adams wrote:
> On Sep 4, 11:30 am, eric.jacob...@ieee.org (Eric Jacobsen) wrote: >> On Sat, 3 Sep 2011 15:53:25 -0700 (PDT), Krishnakumar Gurumoorthy >> >> <krish...@gmail.com> wrote: >>> I was thinking of how the j operator is implemented in hardware. this >>> is with respect to complex down conversion and assumes the A/D's for >>> each I and Q channels are present (this is NOT quadrature sampling >>> with digital downconversion). >> >>> the "j" operator is a mere phase shift of 90 deg in the >>> counterclockwise direction. how is the phase shift introduced ? >>> CORDIC ? >> >>> thanks >> >> That's one way, if you mean multiplying a real signal by the sin and >> cos terms that one can achieve with a CORDIC. A DDS/NCO does the >> same thing. >> >> It's no different than in software. In software one keeps separate >> storage for the I and Q channels or the real and imaginary components >> of a complex number. Likewise in hardware they can be different paths >> and registers. >> >> Eric Jacobsenhttp://www.ericjacobsen.orghttp://www.dsprelated.com/blogs-1//Eric_Jacobsen.php > When designing a chip with imaginary registers it's important to make > sure the physical layout of the register is rotated 90 degrees. That > way you are gauranteed to have orthogonal signals.
And use a high-quality protractor when you rotate, otherwise you'll phase and amplitude imbalance! -- Randy Yates % "Watching all the days go by... Digital Signal Labs % Who are you and who am I?" mailto://yates@ieee.org % 'Mission (A World Record)', http://www.digitalsignallabs.com % *A New World Record*, ELO
On 9/4/2011 7:01 PM, Randy Yates wrote:
> On 09/04/2011 04:04 PM, Robert Adams wrote: >> On Sep 4, 11:30 am, eric.jacob...@ieee.org (Eric Jacobsen) wrote: >>> On Sat, 3 Sep 2011 15:53:25 -0700 (PDT), Krishnakumar Gurumoorthy >>> >>> <krish...@gmail.com> wrote: >>>> I was thinking of how the j operator is implemented in hardware. this >>>> is with respect to complex down conversion and assumes the A/D's for >>>> each I and Q channels are present (this is NOT quadrature sampling >>>> with digital downconversion). >>> >>>> the "j" operator is a mere phase shift of 90 deg in the >>>> counterclockwise direction. how is the phase shift introduced ? >>>> CORDIC ? >>> >>>> thanks >>> >>> That's one way, if you mean multiplying a real signal by the sin and >>> cos terms that one can achieve with a CORDIC. A DDS/NCO does the >>> same thing. >>> >>> It's no different than in software. In software one keeps separate >>> storage for the I and Q channels or the real and imaginary components >>> of a complex number. Likewise in hardware they can be different paths >>> and registers. >>> >>> Eric >>> Jacobsenhttp://www.ericjacobsen.orghttp://www.dsprelated.com/blogs-1//Eric_Jacobsen.php >>> >> When designing a chip with imaginary registers it's important to make >> sure the physical layout of the register is rotated 90 degrees. That >> way you are gauranteed to have orthogonal signals. > > And use a high-quality protractor when you rotate, otherwise you'll > phase and amplitude imbalance!
All of which goes to show the imaginary numbers don't exist in the real (ahem!) world. But you all know that because I've told you before. Jerry -- Engineering is the art of making what you want from things you can get.
On Sep 4, 10:53&#4294967295;am, Krishnakumar Gurumoorthy <krish...@gmail.com>
You use an imaginary wire of course - duh!
