Interesting artifact of Bose noise cancelling headphones
Started by gretzteam September 6, 2011
Hi,
I'm currently playing with noise cancelling headphones, mostly performing
frequency response measurements etc. I only have the QC15 here, which I
think are a few years old.
I noticed that if you try to listen to any pure sine wave frequency from
about 20-80Hz, you first hear nothing (the sine wave gets fully attenuated
by the ANC system), but after about 4-5 seconds, the amplitude of the sine
wave increases up to the loudest thing the speakers can produce - while
destroying my ears in the process:)
I wonder what this means about their control loop. I understand this isn't
such a common real life use case, but with the type of music that kids
listen to these days, I wonder why there hasn't been a lawsuit yet!!!
Thanks!
Dave
On 9/6/2011 5:06 PM, gretzteam wrote:
> Hi, > I'm currently playing with noise cancelling headphones, mostly performing > frequency response measurements etc. I only have the QC15 here, which I > think are a few years old. > I noticed that if you try to listen to any pure sine wave frequency from > about 20-80Hz, you first hear nothing (the sine wave gets fully attenuated > by the ANC system), but after about 4-5 seconds, the amplitude of the sine > wave increases up to the loudest thing the speakers can produce - while > destroying my ears in the process:) > > I wonder what this means about their control loop. I understand this isn't > such a common real life use case, but with the type of music that kids > listen to these days, I wonder why there hasn't been a lawsuit yet!!!
Why do you think that the headset isn't defective? Jerry -- Engineering is the art of making what you want from things you can get.
isn't
>> such a common real life use case, but with the type of music that kids >> listen to these days, I wonder why there hasn't been a lawsuit yet!!! > >Why do you think that the headset isn't defective? >
I didn't think that they could be defective because I use them all the time and they sound great (at least to me).
On Sep 7, 9:06&#4294967295;am, "gretzteam" <gretzteam@n_o_s_p_a_m.yahoo.com>
wrote:
> Hi, > I'm currently playing with noise cancelling headphones, mostly performing > frequency response measurements etc. I only have the QC15 here, which I > think are a few years old. > I noticed that if you try to listen to any pure sine wave frequency from > about 20-80Hz, you first hear nothing (the sine wave gets fully attenuated > by the ANC system), but after about 4-5 seconds, the amplitude of the sine > wave increases up to the loudest thing the speakers can produce - while > destroying my ears in the process:) > > I wonder what this means about their control loop. I understand this isn't > such a common real life use case, but with the type of music that kids > listen to these days, I wonder why there hasn't been a lawsuit yet!!! > > Thanks! > Dave
Maybe because it's deterministic and modelling a sine-wave. There must be large errors getting in somehow. Write to the manufacturers.. Hardy
Yesterday I was watching TV and poking ears with nail. Suddenly the sound dissapeared. Do you think what could be wrong with TV ?
To my knowledge, there is no control loop in noise canceling headphones. It uses simple analog subtraction. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Vladimir Vassilevsky <nospam@nowhere.com> wrote:
(snip)
> To my knowledge, there is no control loop in noise > canceling headphones. It uses simple analog subtraction.
I believe it is analog subtraction, but maybe not so simple. One must do something to avoid the feedback problems that would naturally occur. I do know that they work less well at higher frequencies, so I presume there is a filter in there somewhere. -- glen
you mean no loop at all? no LMS nor NLMS (or whatever adaptive filter)?
how does it know what to subtract? i would think that not only is the subtraction done analogly, but it's done acoustically (actually with a sign change and addition). that's the whole point. but i would think that in the headphone, close to the orifice of the ear canal (the closer, the better) is a tiny microphone that picks up the official difference signal (that we're trying to minimize) to feed back into the adaptive filter. but, in fact, i have never ever ever done diddly with noise-canceling headphones, so i cannot claim to know diddly about it. i just have an idea for how i would approach the problem. i might suggest to the OP that adaptive filters usually work better on broadbanded signals and a single and pure sinusoid is what i would call "quite narrow banded". -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
robert bristow-johnson wrote:
> On 9/7/11 12:56 PM, Vladimir Vassilevsky wrote: > >> > .... > >> >> To my knowledge, there is no control loop in noise canceling headphones. > > you mean no loop at all? no LMS nor NLMS (or whatever adaptive filter)?
No DSP, nothing adaptive. There is a couple of trimpots inside to adjust gains, that's it.
>> It uses simple analog subtraction. > how does it know what to subtract?
A small mike on the outside of each earpiece.
> i would think that not only is the > subtraction done analogly, but it's done acoustically (actually with a > sign change and addition).
It is done electrically, in the headphone amplifier. The signal from the earpiece mike is subtracted from incoming audio. As noted by Glen, they knock the mic gain down at higher frequencies to avoid stability problems.
> that's the whole point. but i would think > that in the headphone, close to the orifice of the ear canal (the > closer, the better) is a tiny microphone that picks up the official > difference signal (that we're trying to minimize) to feed back into the > adaptive filter.
That would be complicated, expensive and heavy and I am not sure if it would perform considerably better then a simple subtractor.
> but, in fact, i have never ever ever done diddly with noise-canceling > headphones, so i cannot claim to know diddly about it. i just have an > idea for how i would approach the problem. i might suggest to the OP > that adaptive filters usually work better on broadbanded signals and a > single and pure sinusoid is what i would call "quite narrow banded".
I suggest OP replacing the battery. It obviously drops under heavy load. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
>robert bristow-johnson wrote: >> i would think that not only is the >> subtraction done analogly, but it's done acoustically (actually with a >> sign change and addition). > >It is done electrically, in the headphone amplifier. The signal from the >earpiece mike is subtracted from incoming audio. As noted by Glen, they >knock the mic gain down at higher frequencies to avoid stability
problems. Its not just stability. Closed back headphones that fit snuggly to the ear are pretty good at excluding higher frequencies. There are only low frequencies which the electronics needs to remove. Steve
> > Hi, > > I'm currently playing with noise cancelling headphones, mostly performing > > frequency response measurements etc. I only have the QC15 here, which I > > think are a few years old. > > I noticed that if you try to listen to any pure sine wave frequency from > > about 20-80Hz, you first hear nothing (the sine wave gets fully attenuated > > by the ANC system), but after about 4-5 seconds, the amplitude of the sine > > wave increases up to the loudest thing the speakers can produce - while > > destroying my ears in the process:) > > Yesterday I was watching TV and poking ears with nail. Suddenly the > sound dissapeared. Do you think what could be wrong with TV ? > > > I wonder what this means about their control loop. I understand this isn't > > such a common real life use case, but with the type of music that kids > > listen to these days, I wonder why there hasn't been a lawsuit yet!!! > > To my knowledge, there is no control loop in noise canceling headphones. > It uses simple analog subtraction. > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultanthttp://www.abvolt.com
As Einstein pointed out, if it actually is complicated then it must be treated as something complicated. On the other hand always always always look for a more simple solution. &#4294967295;Perfection is achieved not when there is nothing left to add, but when there is nothing left to take away&#4294967295; &#4294967295; Antoine de Saint-Exupery This needs to be posted in every engineering dept. Bret Cahill "Omit needless words." -- Strunk & White
