2*pi frequency term
Started by manishp September 13, 2011
Can anyone let me know how to interpret frequency term 2*pi*n used in
discrete frequency domain transform. Does it refer to any specific
frequency?
On Sep 13, 8:35&#4294967295;am, "manishp" <manishp.p18@n_o_s_p_a_m.gmail.com>
wrote:
> Can anyone let me know how to interpret frequency term 2*pi*n used in > discrete frequency domain transform. Does it refer to any specific > frequency?
2*pi*n is the power to which we must raise exp(j) or e^j to get 1, that is, (e^j)^{2*pi*n} = 1, or equivalently, e^j is a (2*pi*n)-th root of unity. WHERE do you see 2*pi*n in a discrete frequency domain transform? Sheeeesh!
>Can anyone let me know how to interpret frequency term 2*pi*n used in >discrete frequency domain transform. Does it refer to any specific >frequency? >
It is a normalized frequency, normalized with respect to the sampling frequency in Hz. To get the 'specific' frequency (in rad/s) 2*pi*n*Fs/N , where N is the length of the DFT/FFT and Fs is sampling frequency in Hz.
>>Can anyone let me know how to interpret frequency term 2*pi*n used in >>discrete frequency domain transform. Does it refer to any specific >>frequency? >> > >It is a normalized frequency, normalized with respect to the sampling >frequency in Hz. To get the 'specific' frequency (in rad/s) >2*pi*n*Fs/N , where N is the length of the DFT/FFT and Fs is sampling >frequency in Hz. >
thank you ...
On Tue, 13 Sep 2011 21:54:54 -0500, manishp wrote:
>>>Can anyone let me know how to interpret frequency term 2*pi*n used in >>>discrete frequency domain transform. Does it refer to any specific >>>frequency? >>> >>> >>It is a normalized frequency, normalized with respect to the sampling >>frequency in Hz. To get the 'specific' frequency (in rad/s) 2*pi*n*Fs/N >>, where N is the length of the DFT/FFT and Fs is sampling frequency in >>Hz. >> >> > thank you ...
I would advise you to learn a bit more about SHM (simple harmonic motion) and this will force you to learn/revise cosine and sine (i.e. trigonometry). The 2*pi term comes from SHM or the fact that the path (in radians) of a complex number around a unit circle is 2*pi rad. Simeon
Simeon wrote:
> > On Tue, 13 Sep 2011 21:54:54 -0500, manishp wrote: > > >>>Can anyone let me know how to interpret frequency term 2*pi*n used in > >>>discrete frequency domain transform. Does it refer to any specific > >>>frequency? > >>> > >>> > >>It is a normalized frequency, normalized with respect to the sampling > >>frequency in Hz. To get the 'specific' frequency (in rad/s) 2*pi*n*Fs/N > >>, where N is the length of the DFT/FFT and Fs is sampling frequency in > >>Hz. > >> > >> > > thank you ... > > I would advise you to learn a bit more about SHM (simple harmonic motion) > and this will force you to learn/revise cosine and sine (i.e. > trigonometry). The 2*pi term comes from SHM or the fact that the path (in > radians) of a complex number around a unit circle is 2*pi rad.
The "path" will be the same whether you include "2*pi" or not. Using "pi" allows you to periodically repeat the same steps along that path. -jim
> > Simeon
Simeon <kotapaka@yahoo.com> wrote:
(snip)
If you use angular frequency (radians/sec) instead of cycles/sec then many of the 2*pi go away. If more frequency counters were calibrated in radians/second that would be easier. Mostly physics uses angular frequency and EE uses cycle frequency. Also, physics uses wavenumber and wavevector (2*pi/wavelength). -- glen
On 9/19/11 3:09 PM, glen herrmannsfeldt wrote:
> Simeon<kotapaka@yahoo.com> wrote: > > (snip) >> I would advise you to learn a bit more about SHM (simple harmonic motion) >> and this will force you to learn/revise cosine and sine (i.e. >> trigonometry). The 2*pi term comes from SHM or the fact that the path (in >> radians) of a complex number around a unit circle is 2*pi rad. > > If you use angular frequency (radians/sec) instead of cycles/sec > then many of the 2*pi go away. If more frequency counters were > calibrated in radians/second that would be easier. > > Mostly physics uses angular frequency and EE uses cycle frequency. > Also, physics uses wavenumber and wavevector (2*pi/wavelength). >
besides being an EE, one reason i like cycle frequency better than angular frequency is the simplicity offered in the forward and inverse (continuous) Fourier transform. Fourier transform: +inf X(f) = integral{ x(t) * e^(-j*2*pi*f*t) dt} -inf inverse Fourier transform: +inf x(t) = integral{ X(f) * e^(+j*2*pi*f*t) df} -inf the symmetry between inverse and forward F.T. is obvious, which lends itself nicely to the duality property (which makes my life easier when i have to think about the F.T. of sinc() and rect() and the convolution theorem and Parseval's theorem). but you have to remember the 2*pi in the exponent. but nowhere else (unless you are representing capacitors or inductors in the frequency domain). all other representations of the F.T. are scaled versions of the above and have either or both asymmetry in the forward and inverse transform and/or require weird scaling factors of 1/(2*pi) or 1/(sqrt(2*pi) somewhere else, where it is harder to remember. convolution and Parseval's theorem always kill me using the angular frequency representation as well as remembering simple transforms like the rect() or sinc() functions. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
On Sep 19, 3:09=A0pm, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:
> Simeon <kotap...@yahoo.com> wrote: > > (snip) > > > I would advise you to learn a bit more about SHM (simple harmonic motio=
n)
> > and this will force you to learn/revise cosine and sine (i.e. > > trigonometry). The 2*pi term comes from SHM or the fact that the path (=
in
> > radians) of a complex number around a unit circle is 2*pi rad. > > If you use angular frequency (radians/sec) instead of cycles/sec > then many of the 2*pi go away. =A0If more frequency counters were > calibrated in radians/second that would be easier. > > Mostly physics uses angular frequency and EE uses cycle frequency. > Also, physics uses wavenumber and wavevector (2*pi/wavelength). > > -- glen
Depends on what you are measuring. In Astronomy, we tend to use minutes and seconds or arc for common angular measures. I haven't found a protractor ruled in radians yet ;-) But I haven't really looked too hard either. I just use what is convenient. Sometimes I use the 2pi and sometimes I don't. It is sort of like what Lord Rutherford had to say about statisitics and the social sciences. "Some people do and some people don't!" Clay
Clay <clay@claysturner.com> wrote:
(snip, I wrote)
>> If you use angular frequency (radians/sec) instead of cycles/sec >> then many of the 2*pi go away. &#4294967295;If more frequency counters were >> calibrated in radians/second that would be easier.
>> Mostly physics uses angular frequency and EE uses cycle frequency. >> Also, physics uses wavenumber and wavevector (2*pi/wavelength).
> Depends on what you are measuring. In Astronomy, we tend to use > minutes and seconds or arc for common angular measures.
I was thinking of it in terms of wave propagation, but also for simple harmonic motion in general. Maybe not for Keplerian motion, though. Did you ever read the book "Feynman's Lost Lecture" by David Goodstein? It seems that Feynman once gave a lecture on Newton's derivation of Kepler's laws without Calculus, which is the way Newton would have done it. There was no transcript of the lecture, only a few notes about how it would go. While on vacation, Goodstein rederived the equations that Newton and then Feynman might have used.
I think they are in the same drawer with the natural log graph paper.
> But I haven't really looked too hard either. I just use what > is convenient. Sometimes I use the 2pi and sometimes I don't.
-- glen
