Hi all - Apologies for what is probably a horribly naive question - but Google has been no help and I'm extraordinarily rusty with this stuff at the moment. Say I have a signal sampled at a depth of 8bits, 10kHz, and I take an N-Point FFT. I understand there will be N/2 bands, each representing a width of 10000/N Hz, but what will be the quantization/depth of the levels represented by each bin? Is it just the same as the input bit depth? Is it dependent on N? Both? Neither? Best! Scott
Quantization of bands in frequency domain?
Started by ●September 22, 2011
Reply by ●September 22, 20112011-09-22
>Hi all - > >Apologies for what is probably a horribly naive question - but Google has >been no help and I'm extraordinarily rusty with this stuff at the moment. >Say I have a signal sampled at a depth of 8bits, 10kHz, and I take an >N-Point FFT. > >I understand there will be N/2 bands, each representing a width of10000/N>Hz, but what will be the quantization/depth of the levels represented by >each bin? Is it just the same as the input bit depth? Is it dependent onN?>Both? Neither? > >Best! >Scott > > >Figured it out playing with Matlab. # of possible levels for each bin seems to be about N/2 and dynamic range about ~0.5 (if signal is normalized) - independent of quantization or sampling rate (which makes sense)
sno <boomtechnology@n_o_s_p_a_m.gmail.com> wrote:> Apologies for what is probably a horribly naive question - but Google has > been no help and I'm extraordinarily rusty with this stuff at the moment. > Say I have a signal sampled at a depth of 8bits, 10kHz, and I take an > N-Point FFT.Actually, this is a good question. Not at all obvious.> I understand there will be N/2 bands, each representing a width of 10000/N > Hz, but what will be the quantization/depth of the levels represented by > each bin? Is it just the same as the input bit depth? Is it dependent on N? > Both? Neither?Consider first the DC, or 0Hz bin. It can be zero, or, in the unlikely case that all input samples are of maximum value, N times the maximum input value. With the appropriate input values, other bins can be almost as large. If done in floating point, one trusts the floating point arithmetic rounding to give a reasonable result. In fixed point, one can do the transform with additional depth, and adjust, as needed, at the end. That requires one additional bit for each base 2 transform stage, or log2(N) additional bits. For typical data, that is more bits than are needed. Adding one bit for each two transform stages, or log2(N)/2, might not be so far off. If one wants to keep a fixed depth, that can be done by dividing by two every two transform stages. The DC level, average of all the input points, can be computed separately. More generally, the more you know about your data the better you can choose where to place the bits. -- glen
Hi, maybe it helps to look at the noise (or maybe not, it depends on what you're trying to achieve) For a fullscale sine wave, the quantization noise in n bit resolution is 6.02n+1.77 dB below the power of the sine wave. Often you can assume that quantization noise is white. In that case, it distributes evenly over all bins. For example, for 8 bits and 10000 bins, the noise in each bin should be 6.02 * 8 + 1.77 + 10 log10(10000) = 90 dB below the value of the sine wave in its assigned bin. Things get messy, when quantization noise is _not_ white anymore. For example, listen to a piano note that slowly decays into the noise floor. When the amplitude reaches the level of the final bit, the noise is anything but white, it gets "attracted" to bins near the sine wave frequency.
Reply by ●September 23, 20112011-09-23
>Hi all - > >Apologies for what is probably a horribly naive question - but Google has >been no help and I'm extraordinarily rusty with this stuff at the moment. >Say I have a signal sampled at a depth of 8bits, 10kHz, and I take an >N-Point FFT. > >I understand there will be N/2 bands, each representing a width of10000/N>Hz, but what will be the quantization/depth of the levels represented by >each bin? Is it just the same as the input bit depth? Is it dependent onN?>Both? Neither? > >Best! >Scott > > >Hi, If I get your question correctly, I think it will depend both on the input quantization and the number of FFTs you select.Unless, you take care of the scaling during FFT. If your data is quanitized at 8 bit level with some amplitude, your FFT of the data will change in scale by nFFT. If you use the same quantization level, your specturm will have higher quantization error. To avoid this, you need to scale your FFT to the level where it fits 8 Bits for low quantization noise. So, your dependency is on the scaling which inturn depends on nFFT. Regards Hozefa
