Noob to DSP and NOT a math major!
Started by dugernaut ●September 23, 2011
I'd like to get started working with DSPs for music synthesis, but I have
no idea where to start.  I flunked HS math (big time) so it seems I've
started with a huge disadvantage.
However, I'm a pretty clever guy and have been designing analog synths and
(simple) embedded hardware stuff for years.
My question???
Where do I start.  TI is offering a $55 development kit that's almost too
tempting, but will I need an advanced math degree to pull off relatively
simple stuff?
Thanks
On 9/23/2011 1:54 PM, dugernaut wrote:
> I'd like to get started working with DSPs for music synthesis, but I have > no idea where to start. I flunked HS math (big time) so it seems I've > started with a huge disadvantage. > > However, I'm a pretty clever guy and have been designing analog synths and > (simple) embedded hardware stuff for years. > > My question??? > > Where do I start. TI is offering a $55 development kit that's almost too > tempting, but will I need an advanced math degree to pull off relatively > simple stuff? > > Thanks > >
advanced math degree: for designing dsp systems/software: probably (mostly yes) for implementing dsp systems/software: probably (mostly no).
On Fri, 23 Sep 2011 14:54:21 -0500, "dugernaut"
<dsprelated1@n_o_s_p_a_m.dougslocum.com> wrote:
>I'd like to get started working with DSPs for music synthesis, but I have >no idea where to start. I flunked HS math (big time) so it seems I've >started with a huge disadvantage. > >However, I'm a pretty clever guy and have been designing analog synths and >(simple) embedded hardware stuff for years. > >My question??? > >Where do I start. TI is offering a $55 development kit that's almost too >tempting, but will I need an advanced math degree to pull off relatively >simple stuff?
Get ye to http://www.dspguide.com/ and download the PDF. It's genuinely, no-shit free to download and use. It's also a pretty good place to start, as it's aimed at the "how to" more than the "heavy math." Example programs are in a simplified BASIC dialect with emphasis on clarity more than speed or clever programming. Buy the hardcover, too, but PDFs are so nice for searching. Once you've digested that, "the Lyons book" <http://www.amazon.com/Understanding-Digital-Signal-Processing-3rd/dp/0137027419> is an excellent next step. You may find that you actually enjoy it. ;-) -- Rich Webb Norfolk, VA
getting a DSK or whatever they call it now is not such a bad thing to do, but might not get you to where you need to be to be "working with DSPs for music synthesis". how do you expect to design algorithms without doing math? if you're familiar with analog synths and start doing stuff like emulating oscillators or generators, you might have some problems you aren't expecting (like aliasing) without thinking about the relevant math. i would say it's also a good thing to get some kinda software environment where you can program algs and run them on your computer (to see how well they work and to tweek them) before coding them into dedicated DSPs. anyway, good luck. the TI kit sounds like it's priced right. dunno what chip (TI has lot's of 'em) it's using. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
a PC is a much more powerful platform than a hardware DSP. Especially if
you don't care about math - you can get away with simple but inefficient
solutions.
Here's what you need (portaudio):
http://www.dsprelated.com/showcoderequest/29.php
It provides a soundcard input and output. You put your code in-between.
MIDI code, for example, can be borrowed from open-source fluidsynth.
Compared to a hardware DSP, I'd expect that the learning curve is much more
beginner-friendly.
You can also convert PC code to a VST plugin for Cubase etc, even though
it's no good as a development environment for experimenting.
On Sep 23, 3:54&#4294967295;pm, "dugernaut"
> I'd like to get started working with DSPs for music synthesis, but I have > no idea where to start. &#4294967295;I flunked HS math (big time) so it seems I've > started with a huge disadvantage. > > However, I'm a pretty clever guy and have been designing analog synths and > (simple) embedded hardware stuff for years. > > My question??? > > Where do I start. &#4294967295;TI is offering a $55 development kit that's almost too > tempting, but will I need an advanced math degree to pull off relatively > simple stuff? > > Thanks
You can try my website for some background material on math and DSP www.fourier-series.com
On Sep 24, 8:54&#4294967295;am, "dugernaut"
You Americans study Math, do you also study Home Economic or Home Economics?
On Sat, 24 Sep 2011 15:20:06 -0700 (PDT), HardySpicer
<gyansorova@gmail.com> wrote:
>On Sep 24, 8:54&#4294967295;am, "dugernaut" ><dsprelated1@n_o_s_p_a_m.dougslocum.com> wrote: >> I'd like to get started working with DSPs for music synthesis, but I have >> no idea where to start. &#4294967295;I flunked HS math (big time) so it seems I've >> started with a huge disadvantage. >> >> However, I'm a pretty clever guy and have been designing analog synths and >> (simple) embedded hardware stuff for years. >> >> My question??? >> >> Where do I start. &#4294967295;TI is offering a $55 development kit that's almost too >> tempting, but will I need an advanced math degree to pull off relatively >> simple stuff? >> >> Thanks > >You Americans study Math, do you also study Home Economic or Home >Economics?
We do seem to disagree with usage when it comes to collective nouns. Take this headline from the BBC sports web site today, for example: "Have England turned the corner? England finally give Johnson something to smile about" sounds very strange over on this side of the pond, where it would be phrased "Has England turned the corner? England finally gives Johnson something to smile about." -- Rich Webb Norfolk, VA
To do exactly what?
Having not started yet, you are already indulging yourself.
There is only one way to make something: just do it.
> My question??? > Where do I start.
It doesn't matter as you are going to abandon the idea very soon.
The advanced math degree is a tag required for employment with a big company or univercity; it is unrelated to abilities to put together any real stuff. VLV
Warning to OP - Vlad hates those who admit ignorance.
'nuff said ;/
Vladimir Vassilevsky wrote:
> > > dugernaut wrote: > >> I'd like to get started working with DSPs for music synthesis, > > To do exactly what? > >> but I have >> no idea where to start. I flunked HS math (big time) so it seems I've >> started with a huge disadvantage. > > Having not started yet, you are already indulging yourself. > >> However, I'm a pretty clever guy and have been designing analog synths >> and >> (simple) embedded hardware stuff for years. > > There is only one way to make something: just do it. > >> My question??? >> Where do I start. > > It doesn't matter as you are going to abandon the idea very soon. > >> TI is offering a $55 development kit that's almost too >> tempting, but will I need an advanced math degree to pull off relatively >> simple stuff? > > The advanced math degree is a tag required for employment with a big > company or univercity; it is unrelated to abilities to put together any > real stuff. > > VLV
