spope33@speedymail.org (Steve Pope) writes:> Hopefully there's a word "discrete" missing from the above. "Among > the zoo of Fourier-related distrete transforms..."Yes, I meant "discrete", sorry about that. (But this is comp.dsp after all.) However, I fail to see why the continous case should be any different. Do you have a specific example in mind of where the continuity makes a difference? And just to be clear, I consider the Fourier-, real Fourier-, sine- and cosine-, and the Hartley transforms to be "Fourier-related". I do not consider the Hankel transform to be Fourier-related, although it can be reduced to a FT if one tries hard enough. I.e., for Fourier-related transforms the basis is some solution of the Poisson equation on a N-dimensional rectangular region, as opposed to cylindrical regions or whatever.
FFT vs DCT
Started by ●September 26, 2011
Reply by ●October 3, 20112011-10-03
On Sep 26, 3:55=A0pm, Jerry Avins <j...@ieee.org> wrote:> On 9/26/2011 11:15 AM, Raeldor wrote: > > > You Again? > > > You know, I feel a little sorry for you. =A0It's obvious you've been > > bullied or abused at some point and now feel like you need to prove > > yourself by name-calling people who are taking an interest in a > > subject you know something about. =A0It doesn't make you look any > > smarter, it just makes you look like someone who needs help. =A0I've me=t> > people like you before. =A0You might know a lot, and you might even be > > smart, but you will never be content until you start treating people > > with respect, because no matter how much you know or how clever you > > are they'll never respect YOU until you do. > > Vlad, like me, he has little patience for those who ask here before > looking for elementary answers in likely places. We differ mostly in my > ignoring lazy questioners and his berating them. > > "Is DCT basically the same as an FFT that operates on real numbers?" is > a classic stupid question. It is stupid as a question to others because > it can be easily answered by looking up (say, in MathWorld or Wikipedia) > what DCT and FFT are. Asking others to do your scut work is a sign of > disrespect. You don't get respect without showing respect.Wiki used to be pretty good, over the years though many topics have been refined by various experts to the point that every intuitive explanation is removed because it isn't precisely correct. Technically it is hard to argue that evolution. But what survives is a listing of spaghetti equations using non standard formats. Technical writing by committee doesn't work very well.Just read some of the discussions.
Matteo Frigo <athena@fftw.org> wrote:>spope33@speedymail.org (Steve Pope) writes:>> Hopefully there's a word "discrete" missing from the above. "Among >> the zoo of Fourier-related discrete transforms..." > >Yes, I meant "discrete", sorry about that. (But this is comp.dsp after >all.) > >However, I fail to see why the continous case should be any different. >Do you have a specific example in mind of where the continuity makes a >difference?I've discussed this in the past, offering the viewpoint that (for example) you can evaluate a cosine transform at any frequency f where f is on the real line, whereas for a DCT (or DFT, or FFT) f must be a discrete frequency. I recall when I've said this, there have been responses that, if you manipulate it a little, the discrete transform can come up with the all of the same results. But I still think it's intuitive to understand that for any arbitrary frequency that is real-valued, you can have the value of a transform at that frequency that might represent something meaningful, such as power spectral density, but with a discrete transform you do not get the same meaning, that it is not defined for all real frequencies, at least not very directly. Steve
spope33@speedymail.org (Steve Pope) writes:> I've discussed this in the past, offering the viewpoint that (for example) > you can evaluate a cosine transform at any frequency f where f is on > the real line, whereas for a DCT (or DFT, or FFT) f must be a discrete > frequency. I recall when I've said this, there have been responses > that, if you manipulate it a little, the discrete transform can come > up with the all of the same results.Your viewpoint is perfectly legitimate. The way I see it (largely inspired by Oppenheim and Schafer) is this: 1) there exists a (complex) Fourier transform of continuous time into continuous frequencies. If you listen to mathematicians then this transform is not defined even for simple functions like constants and polynomials, and these guys generated a lot of noise trying to make the Fourier integral converge when it doesn't (see Cesaro sums and similar hacks). Because the FT is too important not to be defined for simple functions, the physicists ignored this nonsense and invented the Dirac delta function so that FT is well-defined in all impoerant cases. I fully agree with the physicists' viewpoint. 2) You can consider functions of discrete time that are *not* periodic in time. This leads to what O&S call the "discrete-time Fourier transform" (DTFT). Here frequencies are continuous and the frequency spectrum is periodic. This is a perfectly legitimate setup. 3) You can consider periodic functions of discrete time; this leads to the "discrete Fourier transform". Here frequencies are discrete and the spectrum is still periodic. The "interesting" case computationally is 3, which is the one I was talking about. (A "dual-2" case of periodic continuous time exists as well.) I do maintain that in all three cases the various real/sine/cosine/Hartley transforms have no independent ontological status, and they are best introduced as special cases of the corresponding complex Fourier transform. Any attempt to introduce them independently and tweaking the constants to make them orthogonal is a waste of time and an infinite source of confusion.> But I still think it's intuitive to understand that for any arbitrary > frequency that is real-valued, you can have the value of a transform > at that frequency that might represent something meaningful, such as > power spectral density, but with a discrete transform you do not get the > same meaning, that it is not defined for all real frequencies, at least not > very directly.Yes. See DTFT in O&S. At the end of the day no "periodic" signal exists (at least in the DSP domain), so all of DSP is an attempt to approximate case 2 using computational tools from case 3. Regards, Matteo Frigo
Reply by ●October 4, 20112011-10-04
On 10/3/11 8:17 PM, Matteo Frigo wrote:> spope33@speedymail.org (Steve Pope) writes: > >> I've discussed this in the past, offering the viewpoint that (for example) >> you can evaluate a cosine transform at any frequency f where f is on >> the real line, whereas for a DCT (or DFT, or FFT) f must be a discrete >> frequency. I recall when I've said this, there have been responses >> that, if you manipulate it a little, the discrete transform can come >> up with the all of the same results. > > Your viewpoint is perfectly legitimate. The way I see it (largely > inspired by Oppenheim and Schafer) is this: > > 1) there exists a (complex) Fourier transform of continuous time into > continuous frequencies. If you listen to mathematicians then this > transform is not defined even for simple functions like constants and > polynomials, and these guys generated a lot of noise trying to make > the Fourier integral converge when it doesn't (see Cesaro sums and > similar hacks). Because the FT is too important not to be defined > for simple functions, the physicists ignored this nonsense and > invented the Dirac delta function so that FT is well-defined in all > impoerant cases. I fully agree with the physicists' viewpoint. >dunno what the "physicists' viewpoint" is, but is it the one that sorta deprecates the "Dirac delta is not a function" point of view? can the physicists abide with a Dirac delta expressed as a limit of "nascent deltas" all with unit area, as they get squeezed in the domain of the independent variable (time, freq, whatever).> 2) You can consider functions of discrete time that are *not* periodic > in time. This leads to what O&S call the "discrete-time Fourier > transform" (DTFT). Here frequencies are continuous and the frequency > spectrum is periodic. This is a perfectly legitimate setup.and it's exactly the same as the continuous FT of the dirac sampled function. the Laplace transform is to the continuous FT as the Z transform is to the DTFT.> > 3) You can consider periodic functions of discrete time; this leads to > the "discrete Fourier transform".look at that, Eric or Dale (and whoever other deniers of the equivalence of the DFS and DFT). he said "discrete Fourier transform", not "discrete Fourier series" ...> Here frequencies are discrete and > the spectrum is still periodic.... we fight about that a lot here at comp.dsp, Matteo. but you're on the right side of the issue. even though some here disagree, i make it pretty simple: the DFT and the DFS (as described by O&S) are one and the same. the DFT maps a periodic and discrete sequence of length N in one domain (say, "time) into another periodic and discrete sequence of length N in the reciprocal domain (that would be 1/time or "frequency"). the DFT inherently periodically extends the N discrete samples supplied to it (that coulda come from anywhere, an aperiodic source or not), into such a periodic sequence and transforms it. and there are deniers of this same simple fact. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
robert bristow-johnson <rbj@audioimagination.com> wrote: (snip)> dunno what the "physicists' viewpoint" is, but is it the one that sorta > deprecates the "Dirac delta is not a function" point of view? can the > physicists abide with a Dirac delta expressed as a limit of "nascent > deltas" all with unit area, as they get squeezed in the domain of the > independent variable (time, freq, whatever).When I heard it, that was the mathematicians. Story is that someone rewrote a quantum mechanics book removing all deltas. Physicists don't mind them, though. -- glen
Matteo Frigo <athena@fftw.org> wrote:> FFTW uses this ontology also as an implementation principle. > Specifically, FFTW comes with a special-purpose compiler that generates > C code for complex FFTs, real FFTs, even/odd/whetever FFTs. This > compiler does not know anything about the special cases. It only knows > about the complex FFT and a few algebraic rules of the form 0+x=x and > similar high-school algebra.glen herrmannsfeldt <gah@ugcs.caltech.edu> wrote:> Can it do mixed boundary conditions? Or where the boundary is other > than on or half way between sample points?I have never tried mixed boundary conditions, but there is no reason why they should not work as expected. Regards, MF
