> > The audio was recorded from the speaker and mic channels of a PC sound > card. The DAC sampling rate is slightly different from the ADC sampling > rate. The gradual sliding of the signals with respect to each other means > the canceler never converges. > > Not all sound cards do this, but it is very common. The ADC is locked to > the SP/DIF input, which is slaved to whatever drives the SP/DIF input. If > there is no SP/DIF signal the ADC rate free runs. There may or may not > actually be a SP/DIF connector on the machine. The DAC rate, meanwhile, > comes from a local crystal. The two rates are not locked, though they > remain fairly close to each other. This is hugely annoying for a lot of PC > audio applications, but that's just how it is and you have to live with > it. >Is this something I can verify somehow by analyzing the actual signals??? If so, how?
Echo Cancellation Problem (MATLAB)
Started by ●September 26, 2011
Reply by ●October 4, 20112011-10-04
