Frequency Resolution
Started by Simeon ●October 2, 2011
On Oct 3, 12:45�pm, me0...@yahoo.com wrote:
> On Oct 3, 7:46&#4294967295;am, dbd <d...@ieee.org> wrote: > > > > > On Oct 3, 6:24&#4294967295;am, me0...@yahoo.com wrote: > > > > ... > > > The author of the article is trying to convey something the guys in > > > early DSO development use to to talk about all the time, &#4294967295;number of > > > data pts per display&#4294967295;. &#4294967295;It was an esthetic issue. > > > To put it into words, add more time samples and gain spectral > > > resolution. > > > The number of "data pts per display" is constant. The number of sample > > points in the rectangular window is what varies. The data points > > plotted all come from a transform of size 1024. To understand why the > > author considers the "One Sine and One Cosine" case, look at the > > difference between the plots in Figure 5.7 of the "Two Cosines" case > > and those in Figure 5.8. > > > This author is calculating a 1024 point transform implementation of > > what I referred to as "The power spectrum of the FFT of arbitrarily > > large > > size with arbitrarily large zero-fill". I guess that that was enough > > points for the author's "esthetic". > > > The author demonstrates both the "Two cosines" case and the "One Sine > > and One Cosine" case because relative phase does affect the ability to > > resolve two components. > > > Dale B. Dalrymple > > Hmm, > > I didn&#4294967295;t see the info re the size of the FFT, but what I thought he > was doing was removing zero padding and replacing it with real data. > In my simple mind he eventually ends up on bin &#4294967295; > > Call me an idiot .. I give.
The transform size N is given on the previous page (hit "Prev") from the url. (While you are at it, look at the rest of the book.) The number of data point varies, zeros fill out the transform size. Didn't you think the response curves a little too smooth to be produced by 20, 30, 40 or 80 points? Dale B. Dalrymple
On Oct 4, 7:10=A0pm, dbd <d...@ieee.org> wrote:
> On Oct 3, 12:45=A0pm, me0...@yahoo.com wrote: > > > > > > > On Oct 3, 7:46=A0am, dbd <d...@ieee.org> wrote: > > > > On Oct 3, 6:24=A0am, me0...@yahoo.com wrote: > > > > > ... > > > > The author of the article is trying to convey something the guys in > > > > early DSO development use to to talk about all the time, =93number =
of
> > > > data pts per display=94. =A0It was an esthetic issue. > > > > To put it into words, add more time samples and gain spectral > > > > resolution. > > > > The number of "data pts per display" is constant. The number of sampl=
e
> > > points in the rectangular window is what varies. The data points > > > plotted all come from a transform of size 1024. To understand why the > > > author considers the "One Sine and One Cosine" case, look at the > > > difference between the plots in Figure 5.7 of the "Two Cosines" case > > > and those in Figure 5.8. > > > > This author is calculating a 1024 point transform implementation of > > > what I referred to as "The power spectrum of the FFT of arbitrarily > > > large > > > size with arbitrarily large zero-fill". I guess that that was enough > > > points for the author's "esthetic". > > > > The author demonstrates both the "Two cosines" case and the "One Sine > > > and One Cosine" case because relative phase does affect the ability t=
o
> > > resolve two components. > > > > Dale B. Dalrymple > > > Hmm, > > > I didn=92t see the info re the size of the FFT, but what I thought he > > was doing was removing zero padding and replacing it with real data. > > In my simple mind he eventually ends up on bin =85 > > > Call me an idiot .. I give. > > The transform size N is given on the previous page (hit "Prev") from > the url. (While you are at it, look at the rest of the book.) =A0The > number of data point varies, zeros fill out the transform size. Didn't > you think the response curves a little too smooth to be produced by > 20, 30, 40 or 80 points? > > Dale B. Dalrymple- Hide quoted text - > > - Show quoted text -
ugh, i think that's what i did say ... twice. the only way to get frequency resolution is to gain time information. zero padding does nothing to increase freq res. and no i didn't poke around his site.
On Oct 5, 8:04=A0am, me0...@yahoo.com wrote:
> ... > > - Show quoted text - > > ugh, i think that's what i did say ... twice.
If so, then you missed the information content relevant to the OP's question ... twice.
> > the only way to get frequency resolution is to gain time > information. > > zero padding does nothing to increase freq res.
No one has suggested that zero padding increases frequency resolution. Zero padding has been used here to determine if a set of samples is able "to resolve" (by the OP's chosen definition) the two signals. What method do you suggest to determine "resolution' from the set of samples?
It might have allowed you to understand the point of the url figures as well as cure your ignorance of the display processing parameters. People often don't find things ("I didn=92t see the info re the size of the FFT") when they don't look. Dale B. Dalrymple
On Oct 5, 8:50=A0am, dbd <d...@ieee.org> wrote:
> On Oct 5, 8:04=A0am, me0...@yahoo.com wrote: > > > ... > > > - Show quoted text - > > > ugh, i think that's what i did say ... twice. > > If so, then you missed the information content relevant to the OP's > question ... twice. > > > > > the only way to get frequency resolution is to gain time > > information. > > > zero padding does nothing to increase freq res. > > No one has suggested that zero padding increases frequency resolution. > Zero padding has been used here to determine if a set of samples is > able "to resolve" (by the OP's chosen definition) the two signals. > What method do you suggest to determine "resolution' from the set of > samples? > > > > > and no i didn't poke around his site. > > It might have allowed you to understand the point of the url figures > as well as cure your ignorance of the display processing parameters. > People often don't find things ("I didn=92t see the info re the size of > the FFT") when they don't look. > > Dale B. Dalrymple
man, i have no idea what you're point is. what do you thing the OP was asking about? you were the one asking for his definition of frequency resolution. what are you claiming the author of the article was trying to demonstrate if not spectral resolution and the effect of time data? not trying to be a butthead here, but i don't understand what you're trying to get at.
On Oct 5, 9:14=A0am, me0...@yahoo.com wrote:
> > what are you claiming the author of the article was trying to > demonstrate if not spectral resolution and the effect of time data?
The OP's url does not refer to an article. It refers to one html page of an entire book posted on CCRMA's site. On that page, the author points out the comparison between Figure 5.8 on the page and the Figure 5.7 on the previous page. The previous page demonstrates the effect of time data size on resolution. The difference in the Figure 5.8 on the referenced page shows the effect of a change in phase of one of the tones on how "well resolved" to tones are. In particular, for M =3D 20, the phase difference seems to help resolution and for M =3D 40, the phase difference seems to hurt resolution. The point is that the phase change produces effects on resolution that are not a simple function of the data sample size. The author also points out the effect of the phase difference on the values of the individual frequency estimates for different data sizes. The point of the page is that phase differences effect resolution and frequency estimation.
> > not trying to be a butthead here, but i don't understand what you're > trying to get at.
As someone who persists in interpreting a page without understanding it's nature or context, without taking time to follow the author's reference to the previous page or mine, I think you may still have found an accurate label for your participation in this thread. Dale B. Dalrymple
On Oct 5, 10:50=A0am, dbd <d...@ieee.org> wrote:
> On Oct 5, 9:14=A0am, me0...@yahoo.com wrote: > > > ... > > > what are you claiming the author of the article was trying to > > demonstrate if not spectral resolution and the effect of time data? > > The OP's url does not refer to an article. It refers to one html page > of an entire book posted on CCRMA's site. On that page, the author > points out the comparison between Figure 5.8 on the page and the > Figure 5.7 on the previous page. The previous page demonstrates the > effect of time data size on resolution. The difference in the Figure > 5.8 on the referenced page shows the effect of a change in phase of > one of the tones on how "well resolved" to tones are. In particular, > for M =3D 20, the phase difference seems to help resolution and for M =3D > 40, the phase difference seems to hurt resolution. The point is that > the phase change produces effects on resolution that are not a simple > function of the data sample size. The author also points out the > effect of the phase difference on the values of the individual > frequency estimates for different data sizes. The point of the page is > that phase differences effect resolution and frequency estimation. > > > > > not trying to be a butthead here, but i don't understand what you're > > trying to get at. > > As someone who persists in interpreting a page without understanding > it's nature or context, without taking time to follow the author's > reference to the previous page or mine, I think you may still have > found an accurate label for your participation in this thread. > > Dale B. Dalrymple
blablabla --- the bottom line, what's the solution to spectral resolution when you have no tweek on phase???? think, think --- haha ---
On Oct 5, 12:49=A0pm, me0...@yahoo.com wrote:
> On Oct 5, 10:50=A0am, dbd <d...@ieee.org> wrote: > > > > > > > On Oct 5, 9:14=A0am, me0...@yahoo.com wrote: > > > > ... > > > > what are you claiming the author of the article was trying to > > > demonstrate if not spectral resolution and the effect of time data? > > > The OP's url does not refer to an article. It refers to one html page > > of an entire book posted on CCRMA's site. On that page, the author > > points out the comparison between Figure 5.8 on the page and the > > Figure 5.7 on the previous page. The previous page demonstrates the > > effect of time data size on resolution. The difference in the Figure > > 5.8 on the referenced page shows the effect of a change in phase of > > one of the tones on how "well resolved" to tones are. In particular, > > for M =3D 20, the phase difference seems to help resolution and for M =
=3D
> > 40, the phase difference seems to hurt resolution. The point is that > > the phase change produces effects on resolution that are not a simple > > function of the data sample size. The author also points out the > > effect of the phase difference on the values of the individual > > frequency estimates for different data sizes. The point of the page is > > that phase differences effect resolution and frequency estimation. > > > > not trying to be a butthead here, but i don't understand what you're > > > trying to get at. > > > As someone who persists in interpreting a page without understanding > > it's nature or context, without taking time to follow the author's > > reference to the previous page or mine, I think you may still have > > found an accurate label for your participation in this thread. > > > Dale B. Dalrymple > > blablabla --- > > the bottom line, what's the solution to spectral resolution when you > have no tweek on phase???? > > think, think --- > > haha ---- Hide quoted text - > > - Show quoted text -
btw, some people don't need to read the whole book to figure out what's going! you missed this on the link: " Only the well resolved case at the lower right (spanning two full cycles of the difference frequency) appears unaffected by the relative phase of the two sinusoids under analysis." now i'm being an ass! do you actually have a job or are just a student???
On Wed, 5 Oct 2011 14:00:09 -0700 (PDT), me0223@yahoo.com wrote:
>On Oct 5, 12:49=A0pm, me0...@yahoo.com wrote: >> On Oct 5, 10:50=A0am, dbd <d...@ieee.org> wrote: >> >> >> >> >> >> > On Oct 5, 9:14=A0am, me0...@yahoo.com wrote: >> >> > > ... >> >> > > what are you claiming the author of the article was trying to >> > > demonstrate if not spectral resolution and the effect of time data? >> >> > The OP's url does not refer to an article. It refers to one html page >> > of an entire book posted on CCRMA's site. On that page, the author >> > points out the comparison between Figure 5.8 on the page and the >> > Figure 5.7 on the previous page. The previous page demonstrates the >> > effect of time data size on resolution. The difference in the Figure >> > 5.8 on the referenced page shows the effect of a change in phase of >> > one of the tones on how "well resolved" to tones are. In particular, >> > for M =3D 20, the phase difference seems to help resolution and for M = >=3D >> > 40, the phase difference seems to hurt resolution. The point is that >> > the phase change produces effects on resolution that are not a simple >> > function of the data sample size. The author also points out the >> > effect of the phase difference on the values of the individual >> > frequency estimates for different data sizes. The point of the page is >> > that phase differences effect resolution and frequency estimation. >> >> > > not trying to be a butthead here, but i don't understand what you're >> > > trying to get at. >> >> > As someone who persists in interpreting a page without understanding >> > it's nature or context, without taking time to follow the author's >> > reference to the previous page or mine, I think you may still have >> > found an accurate label for your participation in this thread. >> >> > Dale B. Dalrymple >> >> blablabla --- >> >> the bottom line, what's the solution to spectral resolution when you >> have no tweek on phase???? >> >> think, think --- >> >> haha ---- Hide quoted text - >> >> - Show quoted text - > > >btw, > >some people don't need to read the whole book to figure out what's >going! > >you missed this on the link: > >" Only the well resolved case at the lower right (spanning two full >cycles of the difference frequency) appears unaffected by the relative >phase of the two sinusoids under analysis." > >now i'm being an ass! > >do you actually have a job or are just a student???
Dale knows what he's doing in this area more than most. You would do well to consider his advice. Eric Jacobsen Anchor Hill Communications www.anchorhill.com
On Oct 5, 2:24=A0pm, eric.jacob...@ieee.org (Eric Jacobsen) wrote:
> On Wed, 5 Oct 2011 14:00:09 -0700 (PDT), me0...@yahoo.com wrote: > >On Oct 5, 12:49=3DA0pm, me0...@yahoo.com wrote: > >> On Oct 5, 10:50=3DA0am, dbd <d...@ieee.org> wrote: > > >> > On Oct 5, 9:14=3DA0am, me0...@yahoo.com wrote: > > >> > > ... > > >> > > what are you claiming the author of the article was trying to > >> > > demonstrate if not spectral resolution and the effect of time data=
> > >> > The OP's url does not refer to an article. It refers to one html pag=
e
> >> > of an entire book posted on CCRMA's site. On that page, the author > >> > points out the comparison between Figure 5.8 on the page and the > >> > Figure 5.7 on the previous page. The previous page demonstrates the > >> > effect of time data size on resolution. The difference in the Figure > >> > 5.8 on the referenced page shows the effect of a change in phase of > >> > one of the tones on how "well resolved" to tones are. In particular, > >> > for M =3D3D 20, the phase difference seems to help resolution and fo=
r M =3D
> >=3D3D > >> > 40, the phase difference seems to hurt resolution. The point is that > >> > the phase change produces effects on resolution that are not a simpl=
e
> >> > function of the data sample size. The author also points out the > >> > effect of the phase difference on the values of the individual > >> > frequency estimates for different data sizes. The point of the page =
is
> >> > that phase differences effect resolution and frequency estimation. > > >> > > not trying to be a butthead here, but i don't understand what you'=
re
> >> > > trying to get at. > > >> > As someone who persists in interpreting a page without understanding > >> > it's nature or context, without taking time to follow the author's > >> > reference to the previous page or mine, I think you may still have > >> > found an accurate label for your participation in this thread. > > >> > Dale B. Dalrymple > > >> blablabla --- > > >> the bottom line, what's the solution to spectral resolution when you > >> have no tweek on phase???? > > >> think, think --- > > >> haha ---- Hide quoted text - > > >> - Show quoted text - > > >btw, > > >some people don't need to read the whole book to figure out what's > >going! > > >you missed this on the link: > > >" Only the well resolved case at the lower right (spanning two full > >cycles of the difference frequency) appears unaffected by the relative > >phase of the two sinusoids under analysis." > > >now i'm being an ass! > > >do you actually have a job or are just a student??? > > Dale knows what he's doing in this area more than most. =A0You would do > well to consider his advice. > > Eric Jacobsen > Anchor Hill Communicationswww.anchorhill.com- Hide quoted text - > > - Show quoted text -
so tell me --- what's the up shot of what that author had to say? my cut he has a rule of thumb for setting min time seq in order to achieve spectral res. the authors, point re phase, was that you can end up with an error in the freq domain if you don't have time time info to resolve the frequance domain. the idea isn't to get the wrong answer, it's to get the right answer or as close as possible. however you cut i,t you need min time info to get reliable freq resolution. that's the author's point. regards
On Oct 5, 2:00=A0pm, me0...@yahoo.com wrote:
> ... > you missed this on the link: > > " Only the well resolved case at the lower right (spanning two full > cycles of the difference frequency) appears unaffected by the relative > phase of the two sinusoids under analysis." > > now i'm being an ass!
Well, yes, perhaps you are. The well resolved case (M =3D 80) is not the situation the Op and you have asked about. As long as you expect a simple description of the performance limit, you are in error. Dale B. Dalrymple
