On Oct 5, 5:25=A0pm, dbd <d...@ieee.org> wrote:> On Oct 5, 2:00=A0pm, me0...@yahoo.com wrote: > > > ... > > you missed this on the link: > > > " Only the well resolved case at the lower right (spanning two full > > cycles of the difference frequency) appears unaffected by the relative > > phase of the two sinusoids under analysis." > > > now i'm being an ass! > > Well, yes, perhaps you are. > > The well resolved case (M =3D 80) is not the situation the Op and you > have asked about. > > As long as you expect a simple description of the performance limit, > you are in error. > > Dale B. Dalrympleugh .... What???? I don=92t know what you=92re smokin=92, but you better stop! You really aren=92t making any sense. All info on the linked page is part of the discussion. I never asked any questions, I=92ve always commented on topic re the author=92s concept. I commented that I missed the FFT size. In retrospect maybe that comment masked my point. The concept the author is trying to get across is so fundamental. The test signals used were nothing more than a vehicle to demonstrate his point. There=92s nothing magical re the phase offset. Read my original post and continue on down =85 I=92ve consistently made the same comment. F =3D 1/t =85 such a difficult concept! Yikes! Regards
Frequency Resolution
Started by ●October 2, 2011
Reply by ●October 5, 20112011-10-05
Reply by ●October 6, 20112011-10-06
me0223@yahoo.com wrote:> Read my original post and continue on down =85 I=92ve consistently made=> the same comment. >=20 > F =3D 1/t =85 such a difficult concept! Yikes!Simply put, this is a wrong statement. Dale was trying to explain you=20 why it is wrong; but it never works to cast pearls before pigs.
On Oct 5, 10:03=A0pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote:> me0...@yahoo.com wrote: > > Read my original post and continue on down =85 I=92ve consistently made > > the same comment. > > > F =3D 1/t =85 such a difficult concept! =A0 =A0 Yikes! > > Simply put, this is a wrong statement. Dale was trying to explain you > why it is wrong; but it never works to cast pearls before pigs.you believe F =3D 1/t is not true? in what world do you live? do you think this is more appropriate, delta F =3D (1/delta t) ? tell me, i'm listening, what is the key to increasing spectral resolution for a given Fs??? gimme a break
On Oct 5, 10:16=A0pm, me0...@yahoo.com wrote:> On Oct 5, 10:03=A0pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote: > > > me0...@yahoo.com wrote: > > > Read my original post and continue on down =85 I=92ve consistently ma=de> > > the same comment. > > > > F =3D 1/t =85 such a difficult concept! =A0 =A0 Yikes! > > > Simply put, this is a wrong statement. Dale was trying to explain you > > why it is wrong; but it never works to cast pearls before pigs. > > you believe F =3D 1/t is not true? =A0in what world do you live? > > do you think this is more appropriate, delta F =3D (1/delta t) ? > > tell me, i'm listening, what is the key to increasing spectral > resolution for a given Fs??? > > gimme a breakmore specifically ... F(res) =3D 1/(n*deltaT) , n =3D window size seriously dale has never said what the point of the article was ... if the point is something other than achieving adequate spectral resolution to make the measurement tell what it is, i'll shut and go away?
On Oct 5, 5:51 pm, me0...@yahoo.com wrote:> ... > Read my original post and continue on down =85 I=92ve consistently made > the same comment. > > F =3D 1/t =85 such a difficult concept! Yikes! > ...By the OP's definition of resolution and algorithm to implement resolution, the referenced url gives an example of a phase offset that resolves at 0.5 of the frequency difference your calculation would suggest. The previous page gives another phase offset that resolves with 0.75 of the frequency difference your calculation would suggest. For the OP's definition and algorithm, your calculation is significantly pessimistic. I'll give you the same consideration I gave the OP. What is your definition of resolution and what is the algorithm that implements it exhibiting the value of resolution you give? If your suggested value of resolution doesn't predict the performance of some operation it is not only simple, but simply meaningless. So, do you have a meaningful concept or a brain-dead knee- jerk response you make because it is supposed to be "what everybody knows"? Dale B. Dalrymple
On 10/06/2011 01:19 AM, dbd wrote: > [...] > I'll give you the same consideration I gave the OP. What is your > definition of resolution and what is the algorithm that implements > it exhibiting the value of resolution you give? What is yours? And don't back out with some lame reason - you obviously feel like you have some knowledge in the subject area since you've repeatedly responded in the thread. --RY
On Oct 6, 3:01=A0am, Randy Yates <ya...@digitalsignallabs.com> wrote:> On 10/06/2011 01:19 AM, dbd wrote: > =A0> [...] > =A0> I'll give you the same consideration I gave the OP. What is your > =A0> definition of resolution and what is the algorithm that implements > =A0> it exhibiting the value of resolution you give? > > What is yours? And don't back out with some lame reason - you > obviously feel like you have some knowledge in the subject area since > you've repeatedly responded in the thread. > > --RYFres =3D Fs/N, N =3D nonzero time samples Clearly Dale and I had two different approaches to this query. I had a brief look at the posted link recognized that there was enough spectral resolution at M=3D80 and not at M=3D40. I don=92t care what created the two tones, I don=92t care if they=92re correlated in phase I just know that if I have enough spectral resolution I can accurately detect them. How they got into the acquisition window is not the issue. The issue is accurate detection. Not a knock against Dale, but this is not an issue that the old swept SA=92s had to deal with, in the sense that all the processing filters were analog. Resolution bandwidth although realted, is a different issue. Fundamentally, every design team engaged in displayed frequency domain test equipment confronts this issue. A a user expects, and rightfully so, to be able to put his two tone or multi-tone signal into the input and as long as the power level is within the dynamic range of the analyzer get an accurate measurement.
On Oct 6, 3:01 am, Randy Yates <ya...@digitalsignallabs.com> wrote:> On 10/06/2011 01:19 AM, dbd wrote: > > [...] > > I'll give you the same consideration I gave the OP. What is your > > definition of resolution and what is the algorithm that implements > > it exhibiting the value of resolution you give? > > What is yours? And don't back out with some lame reason - you > obviously feel like you have some knowledge in the subject area since > you've repeatedly responded in the thread. > > --RYI don't think any god laid down the one true definition. I think that the applications should determine the specific algorithm that you chose and the algorithm is described by a parameter: "resolution". But I do think that you must be able to state what the algorithm is to meaningfully ask for or give a measure of "resolution". I do think that the meaning of resolution should fit one of two types of application. The multicomponent version is where resolution refers to the frequency separation required to answer whether there is one signal or more than one signal (for frequency resolution). The single component case is where resolution is a parameter describing the accuracy of an algorithm's measurement of frequency. The are many signal situations and many alternative algorithms available for each case. That's why it is important to ask what algorithm is being considered and important to be able to answer what algorithm you mean when you use "resolution". The OP started the thread, so I asked the OP what algorithm was meant. If someone thinks there is a different answer, I ask what algorithm that person means. For the multi-component case I think the OP's choice is one that people who have used analog oscilloscopes and swept spectrum analyzers find intuitive: look for the dip between the peaks. For the single component applications the usual response is 1/t and "Algorithms? We don't have no algorithms. We don't have to show you no stinkin' algorithms!". Dale B. Dalrymple
On Oct 6, 10:35=A0am, dbd <d...@ieee.org> wrote:> On Oct 6, 3:01 am, Randy Yates <ya...@digitalsignallabs.com> wrote: > > > On 10/06/2011 01:19 AM, dbd wrote: > > =A0> [...] > > =A0> I'll give you the same consideration I gave the OP. What is your > > =A0> definition of resolution and what is the algorithm that implements > > =A0> it exhibiting the value of resolution you give? > > > What is yours? And don't back out with some lame reason - you > > obviously feel like you have some knowledge in the subject area since > > you've repeatedly responded in the thread. > > > --RY > > I don't think any god laid down the one true definition. I think that > the applications should determine the specific algorithm that you > chose and the algorithm is described by a parameter: "resolution". But > I do think that you must be able to state what the algorithm is to > meaningfully ask for or give a measure of "resolution". I do think > that the meaning of resolution should fit one of two types of > application. The multicomponent version is where resolution refers to > the frequency separation required to answer whether there is one > signal or more than one signal (for frequency resolution). The single > component case is where resolution is a parameter describing the > accuracy of an algorithm's measurement of frequency. The are many > signal situations and many alternative algorithms available for each > case. That's why it is important to ask what algorithm is being > considered and important to be able to answer what algorithm you mean > when you use "resolution". The OP started the thread, so I asked the > OP what algorithm was meant. If someone thinks there is a different > answer, I ask what algorithm that person means. > > For the multi-component case I think the OP's choice is one that > people who have used analog oscilloscopes and swept spectrum analyzers > find intuitive: look for the dip between the peaks. For the single > component applications the usual response is 1/t and "Algorithms? We > don't have no algorithms. We don't have to show you no stinkin' > algorithms!". > > Dale B. DalrympleDale, My definition of spectral resolution is the classic one, simple equation. Completely independent of any algorithm. I suspect any DSP book would support that. Back in the mid 80=92s to early 90=92s there was a mass transition from analog instrumentation to digital. What I mean by that is that acquisition systems started to utilize digitizers to capture data and processors crunched the numbers and spit them out to displays. FFT analyzers, DSO=92s and Network Analyzers were popping out with these nontraditional interfaces that Analog and RF guys hadn=92t seen before. Back than users were accustom to turning knobs to set user parameters. Concepts like =93windows=94, =93sequence length=94 and =93alia= sing=94 were just vague terms to many a user. Back then, being able to walk an irate customer through his setup on the phone so that he could make a measurement meant you might not have to leave your bench, hop on a plane to solve his problem. I had folks tell me they didn=92t =93trust=94 windows because it made their =93pristine=94 sine waves have all these =93damn=94 spurs. I had guys star= t the conversation, come =93get that boat anchor=94 of a scope because the time base didn=92t work, =93my sinewave is too low in frequency=94. Back then early FFTA=92s and SA=92s and DSO=92s forced the user to understand the significances of all the vague terms in order to use his instrument reliably in his measurement scenario. Today=92s instruments incorporate a human interface that by default couples all that stuff in controls that very much mimic analog instrumentation. For example, in a SA you get sequence length, Res Bw all coupled to Span. The equipment has gotten better and the user is also better educated re digital aspects of his instrument. The point is that I=92m not stating anything mysterious here. The author of that page is using a rectangular window, it=92s pretty fundamental stuff. He=92s got a =93rule=94 of thumb that gives a min dimension for the length of the time sequence. I guess the only reason I pursued this was because the OP missed the whole point of what the author was trying to say. It=92s not algorithmic in nature at all. Bang out some code or simpler yet, get MatLab or SciLab and do the experiment. Btw, I get the impression that you=92re a software type. Is that true? If so get your hands on a Digital SA or even a NA with TDR capability, heck even a DSO with FFT capability. Grab a couple of Arbs and go play. Anyway I think I=92ve beat this to death. Regards and GL
On Oct 6, 11:48=A0am, me0...@yahoo.com wrote:> On Oct 6, 10:35=A0am, dbd <d...@ieee.org> wrote: > > > > > On Oct 6, 3:01 am, Randy Yates <ya...@digitalsignallabs.com> wrote: > > > > On 10/06/2011 01:19 AM, dbd wrote: > > > =A0> [...] > > > =A0> I'll give you the same consideration I gave the OP. What is your > > > =A0> definition of resolution and what is the algorithm that implemen=ts> > > =A0> it exhibiting the value of resolution you give? > > > > What is yours? And don't back out with some lame reason - you > > > obviously feel like you have some knowledge in the subject area since > > > you've repeatedly responded in the thread. > > > > --RY > > > I don't think any god laid down the one true definition. I think that > > the applications should determine the specific algorithm that you > > chose and the algorithm is described by a parameter: "resolution". But > > I do think that you must be able to state what the algorithm is to > > meaningfully ask for or give a measure of "resolution". I do think > > that the meaning of resolution should fit one of two types of > > application. The multicomponent version is where resolution refers to > > the frequency separation required to answer whether there is one > > signal or more than one signal (for frequency resolution). The single > > component case is where resolution is a parameter describing the > > accuracy of an algorithm's measurement of frequency. The are many > > signal situations and many alternative algorithms available for each > > case. That's why it is important to ask what algorithm is being > > considered and important to be able to answer what algorithm you mean > > when you use "resolution". The OP started the thread, so I asked the > > OP what algorithm was meant. If someone thinks there is a different > > answer, I ask what algorithm that person means. > > > For the multi-component case I think the OP's choice is one that > > people who have used analog oscilloscopes and swept spectrum analyzers > > find intuitive: look for the dip between the peaks. For the single > > component applications the usual response is 1/t and "Algorithms? We > > don't have no algorithms. We don't have to show you no stinkin' > > algorithms!". > > > Dale B. Dalrymple > > Dale, > > My definition of spectral resolution is the classic one, simple > equation. =A0Completely independent of any algorithm. =A0I suspect any DS=P> book would support that.Yes. This is the least meaningful and least useful choice.> > Back in the mid 80=92s to early 90=92s there was a mass transition from > analog instrumentation to digital. =A0What I mean by that is that > acquisition systems started to utilize digitizers to capture data and > processors crunched the numbers and spit them out to displays.In 1982 I was hired to (and for the next 25 years continued to) specify, design and deliver digital spectrum analysis instrumentation by Spectral Dynamics.> ...> I had folks tell me they didn=92t =93trust=94 windows because it made the=ir> =93pristine=94 sine waves have all these =93damn=94 spurs. =A0I had guys =start> the conversation, come =93get that boat anchor=94 of a scope because the > time base didn=92t work, =93my sinewave is too low in frequency=94.At Spectral Dynamics we applied the approach of actually educating or customers who didn't understand the capabilities of their instruments instead of shortchanging them with meaningless parameters.> ... > The point is that I=92m not stating anything mysterious here. =A0The > author of that page is using a rectangular window, it=92s pretty > fundamental stuff. =A0He=92s got a =93rule=94 of thumb that gives a min > dimension for the length of the time sequence.I think you still don't understand the content of those pages.> > I guess the only reason I pursued this was because the OP missed the > whole point of what the author was trying to say.I think the OP found an author who was correctly explaining the complexity of usage of the definition of "resolution" that OP had chosen. I think you have still not come to terms with the OP's choice or understood that author.> > Btw, I get the impression that you=92re a software type. =A0Is that true?That's something else you haven't figured out right.> ...Dale B. Dalrymple
