Hi all i am working on reverberation rejection algorithm based on AR prewhitening. According to my understanding i can model a time-domain signal (say A) using AR method and if i pass a unit variance white noise through the filter based on AR parameters, i should get a signal approximate to original signal(A). I have tried to implement same theory in MATLAB using ar, armcov etc for AR parameter estimation* and 'filter' command to filter wgn noise using ar parameters but could not approximate the original signal anyway. *I created the original signal using random noise inserted with some peak signals in it Kindly help me Best Regards
Started by ●October 4, 2011
Reply by ●October 4, 20112011-10-04
abraham007 wrote:> i am working on reverberation rejection algorithm based on AR prewhitening. > > According to my understanding i can model a time-domain signal (say A) > using AR method and if i pass a unit variance white noise through the > filter based on AR parameters, i should get a signal approximate to > original signal(A).So far so good.> I have tried to implement same theory in MATLAB using ar, armcov etc for AR > parameter estimation* and 'filter' command to filter wgn noise using ar > parameters but could not approximate the original signal anyway."MATLAB: dumb methods for dumb people" (tm)> *I created the original signal using random noise inserted with some peak > signals in it > > Kindly help meHelp you what? What is the problem?
Reply by ●October 5, 20112011-10-05
> > >abraham007 wrote: > >> i am working on reverberation rejection algorithm based on ARprewhitening.>> >> According to my understanding i can model a time-domain signal (say A) >> using AR method and if i pass a unit variance white noise through the >> filter based on AR parameters, i should get a signal approximate to >> original signal(A). > >So far so good. > >> I have tried to implement same theory in MATLAB using ar, armcov etc forAR>> parameter estimation* and 'filter' command to filter wgn noise using ar >> parameters but could not approximate the original signal anyway. > >"MATLAB: dumb methods for dumb people" (tm) > >> *I created the original signal using random noise inserted with somepeak>> signals in it >> >> Kindly help me > >Help you what? What is the problem? >Thanks for reply dear.Problem is that i am not being able to recover the original signal as theory says.I have tried different orders of AR models but result is always incorrect.
On Oct 5, 12:08�am, "abraham007" <abrahamnick73@n_o_s_p_a_m.yahoo.com> wrote:> >abraham007 wrote: > > >> i am working on reverberation rejection algorithm based on AR > prewhitening. > > >> According to my understanding i can model a time-domain signal (say A) > >> using AR method and if i pass a unit variance white noise through the > >> filter based on AR parameters, i should get a signal approximate to > >> original signal(A). > > >So far so good. > > >> I have tried to implement same theory in MATLAB using ar, armcov etc for > AR > >> parameter estimation* and 'filter' command to filter wgn noise using ar > >> parameters but could not approximate the original signal anyway. > > >"MATLAB: dumb methods for dumb people" (tm) > > >> *I created the original signal using random noise inserted with some > peak > >> signals in it > > >> Kindly help me > > >Help you what? What is the problem? > > Thanks for reply dear.Problem is that i am not being able to recover the > original signal as theory says.I have tried different orders of AR models > but result is always incorrect.You need to review the theory. The signal you construct with your white noise input will have (approximately) the same spectral density - it will not give you an exact reconstruction of some deterministic signal. If you use linear prediction (of sufficient order) the output is decorrelated an should therefore be white. Note that it is not necessarily gaussian, just white. Therefore, running the filter in the reverse direction i.e. switching inputs and outputs, feeding in a white input signal will generate a signal which has the same spectral density as your input signal. Cheers, Dave
Reply by ●October 10, 20112011-10-10
>You need to review the theory. The signal you construct with your >white noise input will have (approximately) the same spectral density >- it will not give you an exact reconstruction of some deterministic >signal. > >If you use linear prediction (of sufficient order) the output is >decorrelated an should therefore be white. Note that it is not >necessarily gaussian, just white. > >Therefore, running the filter in the reverse direction i.e. switching >inputs and outputs, feeding in a white input signal will generate a >signal which has the same spectral density as your input signal. > >Cheers, >Dave >Thanks much Dave. Yes, you are right, it is the spectral density that will be reconstructed not the original signal. Now i come to the original problem. I want to cancel out reverberations using AR Prewhitening before match filter operation. AR prewhitening actually design an inverse filter using AR parameters estimated from data set A and apply this inverse filter to immediate adjacent data set B. If there is a time domain signal A in which only reverberations are present and there is a time domain signal B in which reverberations plus some target is present, does signals A and B have different spectral densities (although reflections from surface and bottom(reverberation) and from target are of same frequency pulse )? Can you kindly put some light on how this prewhitener works?
