I have been trying in Matlab to model and study the SNR equation of quantisation noise which states that for n bit representation: (1) SNR(dB) = 6.02*n + 1.76 for a single tone signal. (2) when measured by FFT, add 10 *log10(fft resolution/2). (3) A further change occurs when relative bandwidth changes with respect to Fs e.g. upsampling: add 10*log10(Fs/(2*bandwidth)) I managed to model the first two sections but find it difficult to understand and quantify the effect of upsampling/downsampling. Surely it does have effect but this varies with applied method (or chosen filter attenuation) while section (3) above implies fixed effect. Can anybody please shed some light on explaining and quantifying the effect of sampling rate change on SNR. Regards kadhiem Ayob
SNR of quantisation noise
Started by ●October 4, 2011
Reply by ●October 4, 20112011-10-04
On Oct 4, 3:25�pm, "kaz" <kadhiem_ayob@n_o_s_p_a_m.yahoo.co.uk> wrote:> I have been trying in Matlab to model and study the SNR equation of > quantisation noise which states that for n bit representation: > > (1) SNR(dB) = 6.02*n + 1.76 for a single tone signal. > > (2) when measured by FFT, add 10 *log10(fft resolution/2). > > (3) A further change occurs when relative bandwidth changes > with respect to Fs e.g. upsampling: add 10*log10(Fs/(2*bandwidth)) > > I managed to model the first two sections but find it difficult > to understand and quantify the effect of upsampling/downsampling. > Surely it does have effect but this varies with applied method > (or chosen filter attenuation) while section (3) above implies fixed > effect. > > Can anybody please shed some light on explaining and quantifying the effect > of sampling rate change on SNR. > > Regards > > kadhiem AyobSNR is always specified over a specific bandwidth, usually fs/2 Hz If you reduce that bandwidth via signal processing, via FFT or oversampling, the SNR reduces in direct proportion to the reduction in bandwidth
On Oct 4, 3:40�pm, steve <bungalow_st...@yahoo.com> wrote:> On Oct 4, 3:25�pm, "kaz" <kadhiem_ayob@n_o_s_p_a_m.yahoo.co.uk> wrote: > > > > > > > I have been trying in Matlab to model and study the SNR equation of > > quantisation noise which states that for n bit representation: > > > (1) SNR(dB) = 6.02*n + 1.76 for a single tone signal. > > > (2) when measured by FFT, add 10 *log10(fft resolution/2). > > > (3) A further change occurs when relative bandwidth changes > > with respect to Fs e.g. upsampling: add 10*log10(Fs/(2*bandwidth)) > > > I managed to model the first two sections but find it difficult > > to understand and quantify the effect of upsampling/downsampling. > > Surely it does have effect but this varies with applied method > > (or chosen filter attenuation) while section (3) above implies fixed > > effect. > > > Can anybody please shed some light on explaining and quantifying the effect > > of sampling rate change on SNR. > > > Regards > > > kadhiem Ayob > > SNR is always specified over a specific bandwidth, usually fs/2 Hz > > If you reduce that bandwidth via signal processing, via FFT or > oversampling, the SNR reduces in direct proportion to the reduction in > bandwidth- Hide quoted text - > > - Show quoted text -opps, SNR increases...
On Oct 4, 3:40�pm, steve <bungalow_st...@yahoo.com> wrote:> > SNR is always specified over a specific bandwidth, usually fs/2 Hz > > If you reduce that bandwidth via signal processing, via FFT or > oversampling, the SNR reduces in direct proportion to the reduction in > bandwidthDoes signal processing resulting in bandwidth reduction always reduce the SNR, or are there schemes (e.g. matched filtering) that remove "out-of-band" noise etc (thereby effectively decreasing the bandwidth) that might also increase the SNR?
Thanks Steve, I am aware of the rule but wanted to model it and see by myself. In the case of single tone I upsampled the signal using various filters but got different results each time depending on much power residue was left in the stop band. How can we explain these results with the theoretical rule. Thanks Kadhiem
On Tue, 04 Oct 2011 12:46:44 -0700, dvsarwate wrote:> On Oct 4, 3:40 pm, steve <bungalow_st...@yahoo.com> wrote: > > >> SNR is always specified over a specific bandwidth, usually fs/2 Hz >> >> If you reduce that bandwidth via signal processing, via FFT or >> oversampling, the SNR reduces in direct proportion to the reduction in >> bandwidth > > Does signal processing resulting in bandwidth reduction always reduce > the SNR, or are there schemes (e.g. matched filtering) that remove > "out-of-band" noise etc (thereby effectively decreasing the bandwidth) > that might also increase the SNR?Steve meant to say the SNR increases (see his correction). Which is true to an extent: as long as the overall bandwidth is capturing the whole signal, reducing the bandwidth reduces noise without reducing signal, and the SNR goes up. As soon as you start biting into the signal, then (a) your SNR isn't going to improve, and (b) your signal is getting mangled. -- www.wescottdesign.com
kaz wrote:> I have been trying in Matlab to model and study the SNR equation of > quantisation noise which states that for n bit representation:Quantization noise is not a noise, but a nonlinear distortion. Thereby common confusion.
Hi, "assuming" that my quantization noise is white, the in-band part scales proportionally with the bandwidth that I consider "in-band". Simple as that.
On Tue, 04 Oct 2011 14:25:11 -0500, kaz wrote:> I have been trying in Matlab to model and study the SNR equation of > quantisation noise which states that for n bit representation: > > (1) SNR(dB) = 6.02*n + 1.76 for a single tone signal.Presumably this is for a single tone signal that takes up the whole range of the ADC.> (2) when measured by FFT, add 10 *log10(fft resolution/2).I'm not sure just where this comes from, but I suspect that the author is not being rigorous about his definitions -- the total signal power vs. the total noise power is going to be the same after a Fourier transform as before, so the SNR won't change. So either his definitions are loose, or he's taking windowing into account?> (3) A further change occurs when relative bandwidth changes with respect > to Fs e.g. upsampling: add 10*log10(Fs/(2*bandwidth))Again, you need to understand what the author is thinking.> I managed to model the first two sections but find it difficult to > understand and quantify the effect of upsampling/downsampling. Surely it > does have effect but this varies with applied method (or chosen filter > attenuation) while section (3) above implies fixed effect. > > Can anybody please shed some light on explaining and quantifying the > effect of sampling rate change on SNR.Simply changing the sampling rate and looking at the output of the quantization step isn't going to change the SNR: you have the same amount of signal (dictated by the input amplitude) and the same amount of noise (dictated by the ADC step size). There's nothing you can do about either of those. If your quantization noise occurs as broadband noise (which is often, but not always*, the case) then what _does_ change is the power spectral density of the noise. The noise _power_ remains the same, but when you sample faster that noise power is spread out over more spectrum -- so the power spectral density of the noise goes down proportionally to your increase in sampling rate. So if your quantization noise is, indeed, broadband, and if you sample at some sampling rate and then filter the ADC output with a filter appropriate to your signal bandwidth and sampling rate, then with increasing sampling rate you will be filtering out more and more of the noise (but no more of the signal) and you will thus enjoy an improved SNR. * It is nearly always the case that quantization noise will be broadband. With most 16-bit or better ADCs it _is_ the case because the ADC has sufficient thermal noise to guarantee that the quantization noise is scrambled. Only if you are using an ADC that has significantly less excess noise than quantization noise will this happen -- but it can happen. -- www.wescottdesign.com
> > >kaz wrote: > >> I have been trying in Matlab to model and study the SNR equation of >> quantisation noise which states that for n bit representation: > >Quantization noise is not a noise, but a nonlinear distortion. Thereby >common confusion. >But for a single sine tone I compute the ratio of mean signal power/mean of out of band power from dc to Nyquist. If I upsample it by factor of 2 then I measure the same ratio over new bandwidth just like I do with fft resolution. In the case of fft, the out of band power spreads evenly across and results are predictable but this does not happen with upsampling. Regards Kadhiem
