All right, I've learned a lot from this group in the past couple of months. Starting from almost zero knowledge of DSP, I learned how to derive digitial IIR filter coefficients from any arbitrary all-pole polynomial filter. I have a layman's understanding of s-plane and z-plane. I published the solution for generalized all-pole filter coefficients at http://unicorn.us.com/alex/allpolefilters.html for any other newbie who needs help. Now, suppose my transfer function for a lowpass filter isn't a ratio of polynomials at all, but rather an exponential function like this: H(s) = exp(-a * s^b) What would you call this? A no-pole filter? I can't very well do a bilinear transformation on it, to express it in the Z plane. Or maybe I can, if I approximate it by a Taylor Series polynomial -- but I suspect that's the wrong approach. Maybe I don't have to convert to Z plane at all? Can anyone offer this newbie guidance (or a solution) on how to determine the corresponding digitial IIR filter coefficients for this thing? Thanks. -Alex
Deriving IIR coefficients for exponential
Started by ●October 6, 2004
Reply by ●October 6, 20042004-10-06
axlq@spamcop.net (axlq) wrote in message news:<ck005h$lg$1@blue.rahul.net>...> All right, I've learned a lot from this group in the past > couple of months. Starting from almost zero knowledge of > DSP, I learned how to derive digitial IIR filter coefficients > from any arbitrary all-pole polynomial filter. I have a > layman's understanding of s-plane and z-plane. I published > the solution for generalized all-pole filter coefficients at > http://unicorn.us.com/alex/allpolefilters.html for any other newbie > who needs help. > > Now, suppose my transfer function for a lowpass filter isn't a ratio > of polynomials at all, but rather an exponential function like this: > > H(s) = exp(-a * s^b) > > What would you call this? A no-pole filter?Nope. It's a non-rational (irrational?) transfer function. Rational functions are fractions of finite-order polynomials, just the same way that rational numbers are fractions of integers. So, what you have here is a H(s) that is analytic in the sense that a Laurent series exists and converges. The down-side is that the Laurent series is infinitely long, which, in turn, means that the RLC network needed to implement this H(s) comprises infinitely many components. If you specified the function as H(z) in the complex z domain, the difference equation would need infinitely many coefficients. Very cumbersome to work with, in other words.> I can't very well do a bilinear transformation on it, to express it > in the Z plane.Neither can I...> Or maybe I can, if I approximate it by a Taylor > Series polynomial -- but I suspect that's the wrong approach.Homework? It's a good question, though, and I suspect you are touching at the correct answer: You need the system to be of finite order in any practical applications. I'd go for a finite-order approximation, i.e. express the exp function as an infinite series and truncate it after a 'suitable' number of terms.> Maybe > I don't have to convert to Z plane at all?If you are going to use the thing in a discrete-time application, you have to. An alternative to the bilinear transform is to compute the time-domain impulse response and use the impulse invariance method. Perhaps a roundabout way, although not quite as cumbersome as the bilinear tranform (it's not easy to generate an IIR filter from a time-domain response, though), but you end up in the z plane no matter what.> Can anyone offer this newbie guidance (or a solution) on how to > determine the corresponding digitial IIR filter coefficients for > this thing?Sorry, no. Filters of infinite order are not quite my cup of tea. If this really is homework, it's just the kind of thing I'd be very happy to give to my own students... < diabolic grin > Rune
In article <f56893ae.0410060344.57a9f510@posting.google.com>, Rune Allnor <allnor@tele.ntnu.no> wrote:>axlq@spamcop.net (axlq) wrote in message news:<ck005h$lg$1@blue.rahul.net>... >> Now, suppose my transfer function for a lowpass filter isn't a ratio >> of polynomials at all, but rather an exponential function like this: >> >> H(s) = exp(-a * s^b)>... what you have here is a H(s) that is analytic in the sense that >a Laurent series exists and converges. The down-side is that the >Laurent series is infinitely long, which, in turn, means that the >RLC network needed to implement this H(s) comprises infinitely many >components. If you specified the function as H(z) in the complex >z domain, the difference equation would need infinitely many >coefficients. Very cumbersome to work with, in other words.Hm. I thought what I described above could be considered a "gaussian filter" of sorts. And I thought that gaussian filters have a finite number of coefficients. Maybe if I knew how to derive THOSE, my curiosity would be satisfied.>Homework?I'm not in school. I got my physics degree back in 1983, and an MBA in 1992. This problem isn't even related to my day job, although potentially it could be (I work for a defense company). My interest in digital filters arose from my personal exploration of technical analysis of financial markets; however, my current question isn't even related to that. I posted my question because I'm curious about about something I cannot solve by myself. This newsgroup was a great help in helping me understand how to derive rational function polynomial filters. I thought perhaps I could get some further understanding of this different problem, for which Google searching has been no help.>It's a good question, though, and I suspect you are touching >at the correct answer: You need the system to be of finite order >in any practical applications. I'd go for a finite-order approximation, >i.e. express the exp function as an infinite series and truncate >it after a 'suitable' number of terms.Isn't the transfer function of a gaussian filter similar? Something like this: H(s) = g * exp(-a * s^2) My own version above simply generalizes s^2 to s^b. If there's something about s^2 that makes it special and finite, how are the digital filter coefficients derived?>> Can anyone offer this newbie guidance (or a solution) on how to >> determine the corresponding digitial IIR filter coefficients for >> this thing? > >Sorry, no. Filters of infinite order are not quite my cup of tea. >If this really is homework, it's just the kind of thing I'd be >very happy to give to my own students... < diabolic grin >Heh. If you would do that, would you share the best or most amusing answers here? When *I* was in school, we didn't learn anything about digital filtering. As I implied in my earlier article, pretty much everything I learned about digital filters came from this newsgroup and related articles. -Alex
axlq wrote:> In article <f56893ae.0410060344.57a9f510@posting.google.com>, > Rune Allnor <allnor@tele.ntnu.no> wrote: > >>axlq@spamcop.net (axlq) wrote in message news:<ck005h$lg$1@blue.rahul.net>... >> >>>Now, suppose my transfer function for a lowpass filter isn't a ratio >>>of polynomials at all, but rather an exponential function like this: >>> >>> H(s) = exp(-a * s^b) > > >>... what you have here is a H(s) that is analytic in the sense that >>a Laurent series exists and converges. The down-side is that the >>Laurent series is infinitely long, which, in turn, means that the >>RLC network needed to implement this H(s) comprises infinitely many >>components. If you specified the function as H(z) in the complex >>z domain, the difference equation would need infinitely many >>coefficients. Very cumbersome to work with, in other words. > > > Hm. I thought what I described above could be considered a > "gaussian filter" of sorts. And I thought that gaussian filters > have a finite number of coefficients. Maybe if I knew how to derive > THOSE, my curiosity would be satisfied. > > >>Homework? > > > I'm not in school. I got my physics degree back in 1983, and an MBA > in 1992. This problem isn't even related to my day job, although > potentially it could be (I work for a defense company). My interest > in digital filters arose from my personal exploration of technical > analysis of financial markets; however, my current question isn't > even related to that. I posted my question because I'm curious > about about something I cannot solve by myself. This newsgroup > was a great help in helping me understand how to derive rational > function polynomial filters. I thought perhaps I could get some > further understanding of this different problem, for which Google > searching has been no help. > > >>It's a good question, though, and I suspect you are touching >>at the correct answer: You need the system to be of finite order >>in any practical applications. I'd go for a finite-order approximation, >>i.e. express the exp function as an infinite series and truncate >>it after a 'suitable' number of terms. > > > Isn't the transfer function of a gaussian filter similar? Something > like this: H(s) = g * exp(-a * s^2) > > My own version above simply generalizes s^2 to s^b. If there's > something about s^2 that makes it special and finite, how are the > digital filter coefficients derived? > > >>>Can anyone offer this newbie guidance (or a solution) on how to >>>determine the corresponding digitial IIR filter coefficients for >>>this thing? >> >>Sorry, no. Filters of infinite order are not quite my cup of tea. >>If this really is homework, it's just the kind of thing I'd be >>very happy to give to my own students... < diabolic grin > > > > Heh. If you would do that, would you share the best or most amusing > answers here? > > When *I* was in school, we didn't learn anything about digital > filtering. As I implied in my earlier article, pretty much > everything I learned about digital filters came from this newsgroup > and related articles. > > -Alexplease join my thread titled "What constitutes a "homework" question?"
Richard Owlett wrote: ...> please join my thread titled "What constitutes a "homework" question?"Maybe "assigned for class" is the description most of us have in mind. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●October 7, 20042004-10-07
axlq@spamcop.net (axlq) wrote in message news:<ck1mlh$b6t$1@blue.rahul.net>...> In article <f56893ae.0410060344.57a9f510@posting.google.com>, > Rune Allnor <allnor@tele.ntnu.no> wrote: > >axlq@spamcop.net (axlq) wrote in message news:<ck005h$lg$1@blue.rahul.net>... > >> Now, suppose my transfer function for a lowpass filter isn't a ratio > >> of polynomials at all, but rather an exponential function like this: > >> > >> H(s) = exp(-a * s^b) > > >... what you have here is a H(s) that is analytic in the sense that > >a Laurent series exists and converges. The down-side is that the > >Laurent series is infinitely long, which, in turn, means that the > >RLC network needed to implement this H(s) comprises infinitely many > >components. If you specified the function as H(z) in the complex > >z domain, the difference equation would need infinitely many > >coefficients. Very cumbersome to work with, in other words. > > Hm. I thought what I described above could be considered a > "gaussian filter" of sorts. And I thought that gaussian filters > have a finite number of coefficients. Maybe if I knew how to derive > THOSE, my curiosity would be satisfied.Gaussian filters would be designed as truncated Gauss curves (i.e. they are of finite length), and would be implemented as FIR filters.> >Homework? > > I'm not in school. I got my physics degree back in 1983, and an MBA > in 1992. This problem isn't even related to my day job, although > potentially it could be (I work for a defense company). My interest > in digital filters arose from my personal exploration of technical > analysis of financial markets; however, my current question isn't > even related to that. I posted my question because I'm curious > about about something I cannot solve by myself. This newsgroup > was a great help in helping me understand how to derive rational > function polynomial filters. I thought perhaps I could get some > further understanding of this different problem, for which Google > searching has been no help.Linear system analysis deals almost exclusively with systems of rational transfer functions. The reasons are that the representations are of finite order. One usually prefers a finite-order approximation to the desired response, than an infinite-order exact response. The reason is that systems of infinite order are cumbersome to work with. This does not necessarily mean that no one have analyzed infinite-order systems. It means that such analyses (if they have ever been done) would be hard to find. I have never seen such an analaysis, and I have never heard or seen it mentioned anywhere, that such analyses have ben done, or are even possible. On the other hand, I'm not omniscient.> >It's a good question, though, and I suspect you are touching > >at the correct answer: You need the system to be of finite order > >in any practical applications. I'd go for a finite-order approximation, > >i.e. express the exp function as an infinite series and truncate > >it after a 'suitable' number of terms. > > Isn't the transfer function of a gaussian filter similar? Something > like this: H(s) = g * exp(-a * s^2) > > My own version above simply generalizes s^2 to s^b. If there's > something about s^2 that makes it special and finite, how are the > digital filter coefficients derived?One usually uses finite-order FIR approximations, as commented above. Rune
Reply by ●October 8, 20042004-10-08
In article <f56893ae.0410062156.15d3e820@posting.google.com>, Rune Allnor <allnor@tele.ntnu.no> wrote:>Gaussian filters would be designed as truncated Gauss curves (i.e. they >are of finite length), and would be implemented as FIR filters.Yes, the only implementation I had ever seen was FIR. I could swear I saw a reference to an IIR Gaussian however. After failing to figure it out, I thought maybe someone else had, so I thought I'd ask. I guess the only practical way to do it is to approximate the gaussian function by a polynomial. Thanks for the explanation. As always, I learn new things here. -Alex
axlq@spamcop.net (axlq) wrote in message news:<ck53d3$tb4$2@blue.rahul.net>...> In article <f56893ae.0410062156.15d3e820@posting.google.com>, > Rune Allnor <allnor@tele.ntnu.no> wrote: > >Gaussian filters would be designed as truncated Gauss curves (i.e. they > >are of finite length), and would be implemented as FIR filters. > > Yes, the only implementation I had ever seen was FIR. I could swear > I saw a reference to an IIR Gaussian however. After failing to > figure it out, I thought maybe someone else had, so I thought I'd > ask.Well, the adjective "Gaussian" appears all over the place ("Gaussian filter", "Gaussian signal", "Gaussian PDF",...), so it's no wonder one some times have a hard time figuring out what's going on. Rune
Hello Alex, You can split the impulse response into two sequences whee one is causal and the other is anticausal. See the paper "Recursive Gaussian Derivative Filters" by van Vliet and Verbeek. They also cover the design of Gaussian filters. http://www.ph.tn.tudelft.nl/People/lucas/publications/1998/ICPR98LVTYPV/ICPR98LVTYPV.pdf Clay "axlq" <axlq@spamcop.net> wrote in message news:ck53d3$tb4$2@blue.rahul.net...> In article <f56893ae.0410062156.15d3e820@posting.google.com>, > Rune Allnor <allnor@tele.ntnu.no> wrote: > >Gaussian filters would be designed as truncated Gauss curves (i.e. they > >are of finite length), and would be implemented as FIR filters. > > Yes, the only implementation I had ever seen was FIR. I could swear > I saw a reference to an IIR Gaussian however. After failing to > figure it out, I thought maybe someone else had, so I thought I'd > ask. > > I guess the only practical way to do it is to approximate the > gaussian function by a polynomial. > > Thanks for the explanation. As always, I learn new things here. > > -Alex
