Hi, On SDH signal, clock jitter can be removed by PLL. How about wander? The definition of wander is below 10 Hz. I am curious on how to decrease it. Thanks
How to decrease wander in SDH
Started by ●October 9, 2011
Reply by ●October 9, 20112011-10-09
fl wrote:> Hi, > On SDH signal, clock jitter can be removed by PLL. How about wander? > The definition of wander is below 10 Hz. I am curious on how to > decrease it.Kalman. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Oct 9, 9:25�am, Vladimir Vassilevsky <nos...@nowhere.com> wrote:> fl wrote: > > Hi, > > On SDH signal, clock jitter can be removed by PLL. How about wander? > > The definition of wander is below 10 Hz. I am curious on how to > > decrease it. > > Kalman. > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultanthttp://www.abvolt.comKalman to do what? Idiot answer! Try bumping it with a long term stable clock! Ask the idiot above if he has any ideas!
me0223@yahoo.com wrote:> On Oct 9, 9:25 am, Vladimir Vassilevsky <nos...@nowhere.com> wrote: > >>fl wrote: >> >>>Hi, >>>On SDH signal, clock jitter can be removed by PLL. How about wander? >>>The definition of wander is below 10 Hz. I am curious on how to >>>decrease it. >> >>Kalman. >> > Kalman to do what? Idiot answer! > Try bumping it with a long term stable clock! > Ask the idiot above if he has any ideas!The anonimous pig does too much of bumping around the clock. If he does it for stable, it won't be long. I design data acquisition systems for geophysics. This is one of my works: http://www.abvolt.com/projects_and_solutions/data_acquisition_board.htm Among other options, it supports for clock synchronization via wired or wireless channels. Timing accuracy is one of the performance parameters, and it took some effort to get the algorithms right. As for PLL, it is in no way optimal. The only virtue of PLL is simplicity. If the goal is the best tracking accuracy, then Kalman-like control algorithm is the way to go. The issue of a slow variations of phase is tackled by this approach very well. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Oct 9, 12:54�pm, me0...@yahoo.com wrote:> On Oct 9, 9:25�am, Vladimir Vassilevsky <nos...@nowhere.com> wrote: > > > fl wrote: > > > Hi, > > > On SDH signal, clock jitter can be removed by PLL. How about wander? > > > The definition of wander is below 10 Hz. I am curious on how to > > > decrease it. > > > Kalman. > > > Vladimir Vassilevsky > > DSP and Mixed Signal Design Consultanthttp://www.abvolt.com > > Kalman to do what? �Idiot answer! > > Try bumping it with a long term stable clock! > > Ask the idiot above if he has any ideas!Or not an idiot answer, but an advertising strategy. Everything is incredibly easy ... Hire me!
On Oct 9, 10:52�am, Vladimir Vassilevsky <nos...@nowhere.com> wrote:> me0...@yahoo.com wrote: > > On Oct 9, 9:25 am, Vladimir Vassilevsky <nos...@nowhere.com> wrote: > > >>fl wrote: > > >>>Hi, > >>>On SDH signal, clock jitter can be removed by PLL. How about wander? > >>>The definition of wander is below 10 Hz. I am curious on how to > >>>decrease it. > > >>Kalman. > > > Kalman to do what? �Idiot answer! > > Try bumping it with a long term stable clock! > > Ask the idiot above if he has any ideas! > > The anonimous pig does too much of bumping around the clock. If he does > it for stable, it won't be long. > > I design data acquisition systems for geophysics. This is one of my works: > > http://www.abvolt.com/projects_and_solutions/data_acquisition_board.htm > > Among other options, it supports for clock synchronization via wired or > wireless channels. Timing accuracy is one of the performance parameters, > and it took some effort to get the algorithms right. > > As for PLL, it is in no way optimal. The only virtue of PLL is > simplicity. If the goal is the best tracking accuracy, then Kalman-like > control algorithm is the way to go. The issue of a slow variations of > phase is tackled by this approach very well. > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultanthttp://www.abvolt.comwell thank you ... the point is that OP needs to recognize there's long term stable clocks out there for a reason! tracking solutions he can then research.
