Vladimir Vassilevsky wrote:> > Quite often, there is a need to test a communication path with a > realistic signal. I am looking for a quick and dirty method to produce a > voice-like signal from random numbers; so it could be integrated into a > project as a small software module. Voice-like: having the statistics > similar to that of "average" voice in time, amplitude and frequency > domains. > > Is there such thing invented already? > > It is certainly possible to feed random numbers into a vocoder decoding > part, or store and manipulate a set of pieces of recorded speech. It > works, however that is pretty heavyweight solution. > > > Vladimir Vassilevsky > DSP and Mixed Signal Design Consultant > http://www.abvolt.comIf you want something like a PSQM or MOS score, you'll have to dig into the standards. -- Les Cargill
Pseudo voice
Started by ●October 14, 2011
Reply by ●October 17, 20112011-10-17
On Oct 14, 11:37�am, Vladimir Vassilevsky <nos...@nowhere.com> wrote:> Quite often, there is a need to test a communication path with a > realistic signal. I am looking for a quick and dirty method to produce a > voice-like signal from random numbers; so it could be integrated into a > project as a small software module. Voice-like: having the statistics > similar to that of "average" voice in time, amplitude and frequency domains. > > Is there such thing invented already? >dunno how to do this purely from math (like a bandlimited white noise generator), but if you could build a library of "diphones" which would be little wavelets or grains that you get using PSOLA (or what i like to call "Lent's algorithm"). get a good representative library of these diphone grains from a variety of speakers, make probabelistic associations between different diphones, and then launch them (overlap- adding as they are created) in a sorta random fashion. just a wild-assed guess from a lifelong stupident. r b-j
Vladimir Vassilevsky <nospam@nowhere.com> wrote:> Quite often, there is a need to test a communication path with a > realistic signal. I am looking for a quick and dirty method to produce a > voice-like signal from random numbers; so it could be integrated into a > project as a small software module. Voice-like: having the statistics > similar to that of "average" voice in time, amplitude and frequency domains.Interesting idea. Though it is so easy to get voice samples, if you don't require "average." There was discussion, well, not productive discussion, on comp.compression on compressing digitized voice...> Is there such thing invented already?> It is certainly possible to feed random numbers into a vocoder decoding > part, or store and manipulate a set of pieces of recorded speech. It > works, however that is pretty heavyweight solution.The comp.compression discussion was pretty bad, but consider compressing digitized voice, and removing as much redundancy as you can. If you actually succeed then random input should produce voice output. The way I was thinking about it, you extract as much of the voice characteristic (assume only one person) as you can, send that through to the other end, then factor it out of the input signal. You still need to code amplitude, tempo, and such variations, along with what is actually being said. I haven't followed vocoder theory much at all, so that might either be obvious, or not make any sense. Still, if one wants to compress voice down to the lowest possibly bit rate, yet have the result still identifiable as the original person, there might be some interesting research left. I don't know, though, what you would call average. -- glen
glen herrmannsfeldt wrote:> Vladimir Vassilevsky <nospam@nowhere.com> wrote: > > >>Quite often, there is a need to test a communication path with a >>realistic signal. >>It is certainly possible to feed random numbers into a vocoder> The comp.compression discussion was pretty bad, but consider > compressing digitized voice, and removing as much redundancy > as you can. If you actually succeed then random input should > produce voice output.I've done exactly that: feeding random numbers into MPMLQ vocoder. That makes very natural sounds. Just plain white random sounds like a noise of a crowd at distance. If you do some tweaking on the statistics of random, the result could be pretty funny: like a cattle barn with different animals. However this is a very heavyweight approach for the pseudo voice generation. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
maury wrote:> On Oct 14, 1:36 pm, Vladimir Vassilevsky <nos...@nowhere.com> wrote: > >>Speech consists of impulses. Spectral shaped noise is not good as a >>substitute for it. >> > > Vlad, > One of the G-Series from ITU had a pseudo-voice signal defined that > mimiced speech, sounded as though you could almost understand it, and > seemed to work well as an input to some of the new coding algorithms.Thank you, colonel Maurice. Indeed, the ITU-T rec. P.50 defines "artificial voice for telephonometry applications". With formulae, numbers, tables, spectral plots and diagrams. It is all pretty clear from there. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
