Hi all I m trying to fix this weird behavior that I see from a data obtained from a terahertz spectroscopy analysis. The final data generated out of the spectrometer software and i have perform some analysis on them. The first step I need do is take fft of the data to able to see its features in frequency domain but i observe a bizarre pattern. The power spectrum shows echo type of patterns . This behavior is also consistent for various different runs of the spectrometer. I have been doing a lot of search about this sort of problem but i m clueless. Has anyone ever noticed this type of issue? If so , please point me in right direction. I would appreciate any input as i have been wracking my brains over this for months now. Thanks Anu
Has anyone seen echo patterns in the frequency (power) spectrum ?
Started by ●October 14, 2011
Reply by ●October 14, 20112011-10-14
anu22 wrote:> Hi all > > I m trying to fix this weird behavior that I see from a data obtained from > a terahertz spectroscopy analysis.Dear Academy of Sciences. There is a strange underground knocking in the basement of my house. Because of that, I did not go down the basement for two years. This is unbearable. Let the scientists will explain me this knocking.
On 10/14/2011 1:04 PM, anu22 wrote:> The power spectrum shows > echo type of patterns .Please tell us what that means, would you? Fred
On Oct 14, 3:04�pm, "anu22" <anu.p.selvaraj@n_o_s_p_a_m.gmail.com> wrote:> The power spectrum shows > echo type of patterns . This behavior is also consistent for various > different runs of the spectrometer.Are you trying to say that the spectra exhibit harmonic structures? If so, then why are you surprised?
Reply by ●October 15, 20112011-10-15
anu22 wrote:> Hi all > > I m trying to fix this weird behavior that I see from a data obtained from > a terahertz spectroscopy analysis.Spectrogram of what? Of cosmic background? Of a sample whose structure &/or composition to be determined? I suspect the later.> The final data generated out of the > spectrometer software and i have perform some analysis on them. The first > step I need do is take fft of the data to able to see its features in > frequency domain but i observe a bizarre pattern. The power spectrum shows > echo type of patterns . This behavior is also consistent for various > different runs of the spectrometer.If it is consistent you may be unexpectedly measuring a physical parameter of your setup. What is characteristic time delay of the "echo"? Considering the mediums propagation velocity, does the corresponding distance match something in your setup. I remember many years ago one of my tasks as an Instrument Technician was to run NMR spectra for those outside the department. This one biochemist kept giving the same sample size ass he gave the mass spectrometer team. He wondered why I kept giving him very nice spectra of the hydrogen impurity of his deuterated solvent ;/> > I have been doing a lot of search about this sort of problem but i m > clueless. Has anyone ever noticed this type of issue? If so , please point > me in right direction. > > I would appreciate any input as i have been wracking my brains over this > for months now. > > Thanks > Anu > >
Reply by ●October 18, 20112011-10-18
Hi Sorry about getting back late. its not harmonics structure. And its possible maybe i m measuring a convoluted signal which has my actual signal and some other signal (maybe from the measuring probe or something).I would liek to show the spectra plot but this is my first time posting and i m not sure how to do that? if anyone can tell me that , then i can show my plot versus teh expected plot .>anu22 wrote: >> Hi all >> >> I m trying to fix this weird behavior that I see from a data obtainedfrom>> a terahertz spectroscopy analysis. > >Spectrogram of what? Of cosmic background? Of a sample whose >structure &/or composition to be determined? I suspect the >later. > > >> The final data generated out of the >> spectrometer software and i have perform some analysis on them. Thefirst>> step I need do is take fft of the data to able to see its features in >> frequency domain but i observe a bizarre pattern. The power spectrumshows>> echo type of patterns . This behavior is also consistent for various >> different runs of the spectrometer. > >If it is consistent you may be unexpectedly measuring a >physical parameter of your setup. What is characteristic >time delay of the "echo"? Considering the mediums >propagation velocity, does the corresponding distance match >something in your setup. > >I remember many years ago one of my tasks as an Instrument >Technician was to run NMR spectra for those outside the >department. This one biochemist kept giving the same sample >size ass he gave the mass spectrometer team. He wondered why >I kept giving him very nice spectra of the hydrogen impurity >of his deuterated solvent ;/ > > > > >> >> I have been doing a lot of search about this sort of problem but i m >> clueless. Has anyone ever noticed this type of issue? If so , pleasepoint>> me in right direction. >> >> I would appreciate any input as i have been wracking my brains overthis>> for months now. >> >> Thanks >> Anu >> >> >
On 10/18/2011 10:56 AM, anu22 wrote:> Hi > > Sorry about getting back late. > its not harmonics structure. And its possible maybe i m measuring a > convoluted signal which has my actual signal and some other signal (maybe > from the measuring probe or something).I would liek to show the spectra > plot but this is my first time posting and i m not sure how to do that? > > if anyone can tell me that , then i can show my plot versus teh expected > plot .Put your plot on an accessible web site and post a link to it. Jerry -- Engineering is the art of making what you want from things you can get.
Reply by ●October 19, 20112011-10-19
thanks jerry. i have the links for the spectrum so that u can see that i talking abt . they are not supposed to be identical but look generally similar. this is the one for the ideal spectrum http://www.scribd.com/doc/69446056/freqdomainsnrideal where as mine looks like this : http://www.scribd.com/doc/69445630/freqdomainsnrdb regards Anu>On 10/18/2011 10:56 AM, anu22 wrote: >> Hi >> >> Sorry about getting back late. >> its not harmonics structure. And its possible maybe i m measuring a >> convoluted signal which has my actual signal and some other signal(maybe>> from the measuring probe or something).I would liek to show the spectra >> plot but this is my first time posting and i m not sure how to do that? >> >> if anyone can tell me that , then i can show my plot versus tehexpected>> plot . > >Put your plot on an accessible web site and post a link to it. > >Jerry >-- >Engineering is the art of making what you want from things you can get. >
On Wed, 19 Oct 2011 09:37:29 -0500, "anu22" <anu.p.selvaraj@n_o_s_p_a_m.gmail.com> wrote:>i have the links for the spectrum so that u can see that i talking abt . >they are not supposed to be identical but look generally similar. >this is the one for the ideal spectrum >http://www.scribd.com/doc/69446056/freqdomainsnrideal > >where as mine looks like this : >http://www.scribd.com/doc/69445630/freqdomainsnrdbFirst and foremost: you need to put them both on the same scale, especially in the horizontal. Second: these are not spectra, they are ratios of spectra -- ratio of signal spectrum to noise spectrum. Your measurements are evidently very noisy, and at frequencies where you have larger-than-expected noise components, your SNR is reduced (and vice-versa). Taking all of this into account, the measured curve does not look all that unreasonable to me. Can you eliminate some noise sources and repeat the measurements, to be certain? Greg
the horizontal scale can be made till 7 thz but i expanded to 10 so that everyone can see the entire replication. Also in the second spectrum the long dips that you see are due the features of the sample and it has to be there. I think i gave wrong examples: please disregard the prev links and use these as an example of what i m describing: http://www.scribd.com/doc/69458803/Freqdomain-Ideal the same data when i perform my processing looks like this: http://www.scribd.com/doc/69458941/freqdomain Also the second plot is till 20thz cos i want to show the how the features get repetitive .>On Wed, 19 Oct 2011 09:37:29 -0500, "anu22" ><anu.p.selvaraj@n_o_s_p_a_m.gmail.com> wrote: > >>i have the links for the spectrum so that u can see that i talking abt . >>they are not supposed to be identical but look generally similar. >>this is the one for the ideal spectrum >>http://www.scribd.com/doc/69446056/freqdomainsnrideal >> >>where as mine looks like this : >>http://www.scribd.com/doc/69445630/freqdomainsnrdb > >First and foremost: you need to put them both on the same scale,especially in>the horizontal. > >Second: these are not spectra, they are ratios of spectra -- ratio ofsignal>spectrum to noise spectrum. Your measurements are evidently very noisy,and at>frequencies where you have larger-than-expected noise components, your SNRis>reduced (and vice-versa). > >Taking all of this into account, the measured curve does not look allthat>unreasonable to me. Can you eliminate some noise sources and repeat the >measurements, to be certain? > >Greg >
