I analytically derive a simple raised cosine filter with a center frequency and width by taking the inverse transform of the idealized profile in spectral space. The transformed analytical function is normalized so the maximum amplitude is one. It is then digitized and truncated at one of the zeros. The mean of the truncated filter is then subtracted from each element. I apply this filter to a triangular wave of amplitude 1 centered about 0.5 (not zero). The convolution (multiplying the truncated filter length successivly along each point of the triangular wave) gives the correct shape (it pulls out the 1, 3, 5, etc. harmonics just fine) but the resulting amplitude is absurdly magnified! I expected an amplitude less than unity, but for the fundamental frequency its up near 200! What kind of normalization am I missing?
What am I missing normalizing a FIR filter?
Started by ●January 7, 2004
Reply by ●January 7, 20042004-01-07
Brian Reinhold wrote:> I analytically derive a simple raised cosine filter with a center frequency > and width by taking the inverse transform of the idealized profile in > spectral space. The transformed analytical function is normalized so the > maximum amplitude is one. It is then digitized and truncated at one of the > zeros. The mean of the truncated filter is then subtracted from each > element. I apply this filter to a triangular wave of amplitude 1 centered > about 0.5 (not zero). The convolution (multiplying the truncated filter > length successivly along each point of the triangular wave) gives the > correct shape (it pulls out the 1, 3, 5, etc. harmonics just fine) but the > resulting amplitude is absurdly magnified! I expected an amplitude less > than unity, but for the fundamental frequency its up near 200! > > What kind of normalization am I missing?"... So that the maximum amplitude is one." Amplitude of what? The signal, or each coefficient? The filter's output is the sum of all the accumulation (sum) of all the products. (That's what "MAC" stands for.) Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●January 8, 20042004-01-08
"Brian Reinhold" <breinhold@comcast.net> wrote in message news:_J3Lb.762808$HS4.6034109@attbi_s01...> I analytically derive a simple raised cosine filter with a centerfrequency> and width by taking the inverse transform of the idealized profile in > spectral space. The transformed analytical function is normalized so the > maximum amplitude is one. It is then digitized and truncated at one ofthe> zeros. The mean of the truncated filter is then subtracted from each > element. I apply this filter to a triangular wave of amplitude 1 centered > about 0.5 (not zero). The convolution (multiplying the truncated filter > length successivly along each point of the triangular wave) gives the > correct shape (it pulls out the 1, 3, 5, etc. harmonics just fine) but the > resulting amplitude is absurdly magnified! I expected an amplitude less > than unity, but for the fundamental frequency its up near 200! > > What kind of normalization am I missing?Brian, Not a very clear description. Hard to duplicate from this. "simple raised cosine filter" "with a center frequency and width" ... ??? "the idealized profile in spectral space" is.. ? "the transformed analytical function" is.. ? "digitized" do you mean sampled? not the same thing.... "one of the zeros" ... must refer to the vague analytical function above... Fred
Sorry about the confusion.
The raised cosine filter is
H(w) = .5 * [1 - cos((w - w0)/wf)] for w0 - pi*wf < w < w0 + pi*wf,
H(w) = 0 otherwise.
where 'w0' is the center frequency
'wf' is the "width" of the filter and
'w' is, well, the frequency.
This function should rise continuously from 0 at 'w = w0-pi*wf', reach its
maximum at 'w = w0' and return back to zero at 'w = w0 + pi*wf'. At least
that's the idea. So what I want it to do is retain the 'w0' frequency and
get rid of everything else. Of course the smaller 'wf' is the more taps I
will need on this.
The inverse transform of this function (the filter to be convolved with the
input signal) is
h(t) = cos(w0 * t) * sin(pi*wf*t) /[pi * (1 - wf*wf*t*t) * t]
The maximum amplitude of the function is 1 if I divide the whole thing by
'wf'.
So that's what I mean by the maximum amplitude of the filter is 1.
Since 'wf << w0' for my applications, a good way to truncate this filter
that gets the bulk of the meaty part is to take the zeros of 'sin(pi*wf*t).
They are given by
't = n/wf' where 'n > 1' and 'n' is an integer. Picking 'n=2' seems to do
quite well. Then I have the range of 't' or the convolution range over which
the filter will be used. After making discrete, this gives me the number of
taps.
By 'digitizing' I should say making 'h(t)' discrete. 't' is only valid for
discrete times.
So I convolve h(nt) * x(nt) = y(nt). Bad notation, perhaps, but you know,
for each y(nt) I have to sum up the product of x(nt) * h(nt - T) where each
sum is over the truncated range of the filter. Lots of computations.
So what I meant by all these amplitudes is that
h(t) has a maximum value of 1 and a mean of zero over the truncated range.
x(t) is a triangle wave with a maximum value of 1 and a minimum of 0, so
it's mean over the truncated range of the filter would be .5 * (the number
of taps). But I figured the 0 mean of the filter should take care of it.
However, even though this effectively filters out the proper harmonics of
the trianglular wave, the resulting amplitude of the components is much
greater than 1. Near 200 for the fundamental! Is that due to the mean of
x(nt)?
In the end I wish I could find a narrow band pass filter that had very few
taps that would do the same job as this filter. Perhaps some IIR filter?
But I have no idea how to derive one. It is conceptually pretty easy to see
how inverse transforming a spectral window over the desired frequencies
works (even if it is a pain trying to get all my 2*pi factors, angular
versus standard frequency notations, and other normalizations correct). But
I have no idea what to base an IIR filter on.
All I want to do is grab an FSK signal out of a bunch of noise. I thought
my integrate and dump would do the job by itself (since you are essentially
applying a matched filter to the signal) but when I simply sang into a mike
on top of the signal, the noises I could make readily defeated the FSK
detector. Granted, my voice noise was a few orders of magnitude more
intense than the signal but it was also at much lower frequencies. So began
the search for an input filter BEFORE the integrate and dump.
Brian
"Brian Reinhold" <breinhold@comcast.net> wrote in message news:3pcLb.314270$_M.1815441@attbi_s54...> Sorry about the confusion. > > The raised cosine filter is > > H(w) = .5 * [1 - cos((w - w0)/wf)] for w0 - pi*wf < w < w0 + pi*wf, > H(w) = 0 otherwise. > > where 'w0' is the center frequency > 'wf' is the "width" of the filter and > 'w' is, well, the frequency. > This function should rise continuously from 0 at 'w = w0-pi*wf', reach its > maximum at 'w = w0' and return back to zero at 'w = w0 + pi*wf'. At least > that's the idea. So what I want it to do is retain the 'w0' frequency and > get rid of everything else. Of course the smaller 'wf' is the more taps I > will need on this. > > The inverse transform of this function (the filter to be convolved withthe> input signal) is > > h(t) = cos(w0 * t) * sin(pi*wf*t) /[pi * (1 - wf*wf*t*t) * t] > > The maximum amplitude of the function is 1 if I divide the whole thing by > 'wf'. > > So that's what I mean by the maximum amplitude of the filter is 1. > > Since 'wf << w0' for my applications, a good way to truncate this filter > that gets the bulk of the meaty part is to take the zeros of'sin(pi*wf*t).> They are given by > 't = n/wf' where 'n > 1' and 'n' is an integer. Picking 'n=2' seems to do > quite well. Then I have the range of 't' or the convolution range overwhich> the filter will be used. After making discrete, this gives me the numberof> taps. > > By 'digitizing' I should say making 'h(t)' discrete. 't' is only valid for > discrete times. > > So I convolve h(nt) * x(nt) = y(nt). Bad notation, perhaps, but you know, > for each y(nt) I have to sum up the product of x(nt) * h(nt - T) whereeach> sum is over the truncated range of the filter. Lots of computations. > > So what I meant by all these amplitudes is that > h(t) has a maximum value of 1 and a mean of zero over the truncated range. > x(t) is a triangle wave with a maximum value of 1 and a minimum of 0, so > it's mean over the truncated range of the filter would be .5 * (the number > of taps). But I figured the 0 mean of the filter should take care of it. > > However, even though this effectively filters out the proper harmonics of > the trianglular wave, the resulting amplitude of the components is much > greater than 1. Near 200 for the fundamental! Is that due to the mean of > x(nt)? > > In the end I wish I could find a narrow band pass filter that had very few > taps that would do the same job as this filter. Perhaps some IIR filter? > But I have no idea how to derive one. It is conceptually pretty easy tosee> how inverse transforming a spectral window over the desired frequencies > works (even if it is a pain trying to get all my 2*pi factors, angular > versus standard frequency notations, and other normalizations correct).But> I have no idea what to base an IIR filter on. > > All I want to do is grab an FSK signal out of a bunch of noise. I thought > my integrate and dump would do the job by itself (since you areessentially> applying a matched filter to the signal) but when I simply sang into amike> on top of the signal, the noises I could make readily defeated the FSK > detector. Granted, my voice noise was a few orders of magnitude more > intense than the signal but it was also at much lower frequencies. Sobegan> the search for an input filter BEFORE the integrate and dump. >Brian, OK - I'm looking at it. First off, it appears you aren't generating the raised cosine you had in mind. It seems to me that you want something more like: H[w0]=1 but it looks like you have H[w0]=0 How about: H(i) = .5 * [1 + cos(2*pi*(w(i)-w0)/wf)]; and, then you have to include the flipped values at H[-w] as well H(N-i) = .5 * [1 + cos(2*pi*(w(i)-w0)/wf)]; Next, scaling between transforms is often a question. You started with a filter with peak value of 1.0 in frequency (which is how I prefer to scale things usually). Then, when you divided by wf to get a peak value of 1.0 in time, you scaled up the result by wf! So, that accounts for the large scaling of the result. Then, you find that you have to truncate the result in the time domain because you started with a finite-length spectral character in the frequency domain. Doing this changes the raised cosine in frequency. You'd do better to do this: Design a FIR bandpass filter with the length you want and the bandpass character you want. There are quite a few programs on the web that will do this for you. It's a whole lot easier and gets rid of a lot of the steps you're needing to take with the process you've defined. Here's one of many: http://www.systolix.co.uk/feintro.htm Using this or some other design program you'll find that a decent FIR filter will be of length 100 or more depending on your spec's. On the other hand an IIR filter might be done in 3 biquads or 15 coefficients. Fred
Reply by ●January 9, 20042004-01-09
Thanks Fred. I made a typo. I do exactly as you suggested (including the mirror profile to make the final form real) except that I don't have the 2*pi factor. I put that in later. But I shouldn't normalize the final real expression such that it's maximum value is one (by dividing by 'wf')? What I did find was that I got a much closer answer if I normalized the convolution by the integral of the truncated version of h(t)*h(t). But the answer was still off the theoretical. I will try it without first normalizing by 'wf' and see if that works. In the end a filter with that many taps will kill me. I guess I'd betterlook for some IIR stuff. Brian> > OK - I'm looking at it. First off, it appears you aren't generating the > raised cosine you had in mind. > > It seems to me that you want something more like: > H[w0]=1 but it looks like you have H[w0]=0 > How about: > H(i) = .5 * [1 + cos(2*pi*(w(i)-w0)/wf)]; > and, then you have to include the flipped values at H[-w] as well > H(N-i) = .5 * [1 + cos(2*pi*(w(i)-w0)/wf)]; > > Next, scaling between transforms is often a question. You started with a > filter with peak value of 1.0 in frequency (which is how I prefer to scale > things usually). Then, when you divided by wf to get a peak value of 1.0in> time, you scaled up the result by wf! So, that accounts for the large > scaling of the result. > > Then, you find that you have to truncate the result in the time domain > because you started with a finite-length spectral character in thefrequency> domain. Doing this changes the raised cosine in frequency. > > You'd do better to do this: Design a FIR bandpass filter with the lengthyou> want and the bandpass character you want. There are quite a few programson> the web that will do this for you. It's a whole lot easier and gets ridof> a lot of the steps you're needing to take with the process you've defined. > Here's one of many: > > http://www.systolix.co.uk/feintro.htm > > Using this or some other design program you'll find that a decent FIRfilter> will be of length 100 or more depending on your spec's. On the other hand > an IIR filter might be done in 3 biquads or 15 coefficients. > > Fred > >
Reply by ●January 10, 20042004-01-10
"Brian Reinhold" <breinhold@comcast.net> wrote in message news:ITwLb.5510$5V2.10651@attbi_s53...> Thanks Fred. > > I made a typo. I do exactly as you suggested (including the mirrorprofile> to make the final form real) except that I don't have the 2*pi factor. Iput> that in later. > > But I shouldn't normalize the final real expression such that it's maximum > value is one (by dividing by 'wf')? What I did find was that I got a much > closer answer if I normalized the convolution by the integral of the > truncated version of h(t)*h(t). But the answer was still off the > theoretical. I will try it without first normalizing by 'wf' and see if > that works. > > In the end a filter with that many taps will kill me. I guess I'd > betterlook for some IIR stuff.Brian, h(t)*h(t) ????? what's that about?> But I shouldn't normalize the final real expression such that it's maximum > value is one (by dividing by 'wf')?No, you shouldn't. Consider this: Start with a temporal cosine of peak amplitude 1.0 with an integral number of cycles in 256 seconds- period of some integer multiple of 1/256Hz like 10/256. Window it (multiply it) with a rectangular window of length 256 and amplitude 1.0 - from t=0 to t=255. This does nothing to the original samples within that time span. Now, let's do the corresponding dual operation in the frequency domain. FFT the window. You get a single sample at index 1 (f=0) with amplitude 256 - not 1.0 FFT the cosine. You get a pair of samples at indices 11 and 247 with amplitudes of 128 each - not 1.0 Convolve the filter with the cosine in frequency. You get a pair of samples of amplitude 128*256. You can either look at this and decide to scale by 1/256 right away or inverse transform the result with scaling of 1/256 in *addition* to the built in scaling typical in an IFFT. You get a cosine in time of amplitude 1.0 - which is what you better get! The bottom line: If you start with a signal or function that has peak amplitude of 1.0 in one domain then it is unlikely to have peak amplitude of 1.0 in the dual domain. You generally can't have both. You defined the raised cosine to have a peak of 1.0 in frequency - so don't expect the peak in time to also be 1.0. Since the dual transform pair scales together, dividing by wf divides in both domains so the 1.0 cosine you started with is thus perturbed by the same factor. Fred
THanks for all your comments and help Fred. It has been very helpful for an unseasoned DSP person like me. I realize there is an amplitude normalization problem, just as there is with fourier integrals. So I tried to normalize h(t) that I had derived analytically such that if I convolved it with itself, the maximum amplitude of the convolution (which would occur when the two 'functions' were exactly in phase) would be 1. The scaling factor would be computed by Integral[h(t)*h(t)dt] from plus or minus infinity (where '*' means product and not convolution. Of course I truncate the range to that of the truncated function. I removed the 'wf' normalization. In this way if the signal was identical to h(t), then it should be 'passed through' perfectly. At least that was the idea. It did not work unless I normaized by 'wf' first, however, but I don't rule out a program bug yet. It's probably something stupid that I am doing in the code, because every other aspect of the filter behaves as anticipated! Brian "Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote in message news:6NydnXlCNfUE0Z3dRVn-jg@centurytel.net...> > "Brian Reinhold" <breinhold@comcast.net> wrote in message > news:ITwLb.5510$5V2.10651@attbi_s53... > > Thanks Fred. > > > > I made a typo. I do exactly as you suggested (including the mirror > profile > > to make the final form real) except that I don't have the 2*pi factor. I > put > > that in later. > > > > But I shouldn't normalize the final real expression such that it'smaximum> > value is one (by dividing by 'wf')? What I did find was that I got amuch> > closer answer if I normalized the convolution by the integral of the > > truncated version of h(t)*h(t). But the answer was still off the > > theoretical. I will try it without first normalizing by 'wf' and see if > > that works. > > > > In the end a filter with that many taps will kill me. I guess I'd > > betterlook for some IIR stuff. > > > Brian, > > h(t)*h(t) ????? what's that about? > > > But I shouldn't normalize the final real expression such that it'smaximum> > value is one (by dividing by 'wf')? > > No, you shouldn't. Consider this: > > Start with a temporal cosine of peak amplitude 1.0 with an integral number > of cycles in 256 seconds- period of some integer multiple of 1/256Hz like > 10/256. > Window it (multiply it) with a rectangular window of length 256 and > amplitude 1.0 - from t=0 to t=255. > This does nothing to the original samples within that time span. > > Now, let's do the corresponding dual operation in the frequency domain. > FFT the window. You get a single sample at index 1 (f=0) with amplitude > 256 - not 1.0 > FFT the cosine. You get a pair of samples at indices 11 and 247 with > amplitudes of 128 each - not 1.0 > Convolve the filter with the cosine in frequency. You get a pair ofsamples> of amplitude 128*256. > You can either look at this and decide to scale by 1/256 right away or > inverse transform the result with scaling of 1/256 in *addition* to the > built in scaling typical in an IFFT. > You get a cosine in time of amplitude 1.0 - which is what you better get! > > The bottom line: > If you start with a signal or function that has peak amplitude of 1.0 inone> domain then it is unlikely to have peak amplitude of 1.0 in the dualdomain.> You generally can't have both. You defined the raised cosine to have apeak> of 1.0 in frequency - so don't expect the peak in time to also be 1.0. > Since the dual transform pair scales together, dividing by wf divides in > both domains so the 1.0 cosine you started with is thus perturbed by the > same factor. > > Fred > > > > > >
Reply by ●January 11, 20042004-01-11
"Brian Reinhold" <breinhold@comcast.net> wrote in message news:wb2Mb.19459$nt4.41120@attbi_s51...> THanks for all your comments and help Fred. It has been very helpful foran> unseasoned DSP person like me. > > I realize there is an amplitude normalization problem, just as there iswith> fourier integrals. So I tried to normalize h(t) that I had derived > analytically such that if I convolved it with itself, the maximumamplitude> of the convolution (which would occur when the two 'functions' wereexactly> in phase) would be 1.I don't see why normalizing that way makes sense. For example, if you convolve 1 2 3 with itself, the peak result is 10. It should be. If you convolve 1 2 3 with 4 4 4, the result has a peak of 24. Now, the convolution of 1 2 3 and 4 4 4 should not be 24/10 = 2.4 - there's no reason I can think of for this normalization. Maybe it's just that I don't know of one. You may need to differentiate between continuous, infinite analytical expressions and discrete, finite or possibly periodic expressions. Here is your original post heavily edited with changes made so the process is correct: I analytically derive a simple raised cosine filter with peak 1.0 and a center frequency and width according to my specifications. This is a bandpass filter with band center gain of 1.0 I get the time domain version by taking the inverse transform of this idealized spectral function. The IFFT that I use scales by 1/N internally as is the usual thing (but not what FFTW does). The transformed temporal function or impulse response has been obviously pre-normalized so the maximum amplitude if the filter at band center is 1.0, so no further normalization is necessary. The continuous, infinite impulse response is then sampled and truncated. Just to be sure the stopband at f=0 has zero response, the very small mean of the truncated filter is then subtracted from each filter coefficient divided by the length of the filter -> i.e. subtracting mean/N. I apply this filter to a cosine wave of amplitude 1 centered at amplitude 1.0 with frequency 0.25 (the center of the bandpass) - so it is sampled exactly at 4 samples per period and is indistinguishable from a triangular wave which would be undersampled. The convolution (multiplying the truncated filter length successivly along each point of the triangular wave) gives the correct temporal shape of a cosine sampled 4 times per cycle. Obviously no harmonics can be seen because the sample rate doesn't allow. The resulting amplitude is +1 to -1 at the peaks as expected. The average value of 1.0 of the input is effectively filtered out. Now, if the bandpass is narrow enough to attenuate the harmonics, even if we move the bandpass to a lower frequency so the relative sample rate is higher, no harmonics will emerge the bandpass. Fred
"Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote in message news:_L6dnSpEcJxclpzdRVn-hw@centurytel.net...>Brian, I want to modify this one thing that I said:> The continuous, infinite impulse response is then sampled and truncated. > Just to be sure the stopband at f=0 has zero response, the very small mean > of the truncated filter is then subtracted from each filter coefficient > divided by the length of the filter -> i.e. subtracting mean/N.It would have been correct to say "subtracting the mean" if the objective was to set the response at f=0 identically to zero. However, I think this is an unusual thing to to and isn't guaranteed to work in the general case. What if the filter unit sample response is 1 1 1 ? Then the mean is 1 and subtracting the mean yields all zero coefficients. I rather think that the response at f=0 is the same sort of thing as the response at any other stopband frequency. So, you just accept it along with all the other non-zero responses in the stop band and don't subtract the mean. In the case you have, it probably doesn't hurt either - the "correction" should be pretty small. Fred
